[PATCH v2 5/6] cpukit: Add signal mapping support
Mon Oct 4 17:29:22 UTC 2021
On 02/10/2021 01:44, Chris Johns wrote:
>> The fatal extensions have a well defined order (position in the
>> table). The user has the full control over the initial extensions table.
> Is it backwards compatible when this new mode is enabled?
When you enable a new feature you get new behaviour. I am not sure what
you mean with backward compatible in this case. If you don't enable the
exception to signal mapping (default), then nothing changes.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
