[PATCH 3/3] microblaze: Rework for RTEMS 6
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Sat Oct 2 08:58:54 UTC 2021
On Sat, 2 Oct 2021 at 02:44, Chris Johns <chrisj at rtems.org> wrote:
> On 1/10/21 3:43 pm, Alex White wrote:
> >  bsps/microblaze/include/common/xil_types.h    |  197 +++
> >  bsps/microblaze/include/dev/serial/uartlite.h |   62 +
> >  .../include/dev/serial/uartlite_l.h           |  323 +++++
> >  bsps/microblaze/shared/dev/serial/uartlite.c  |  145 ++
> >  .../microblaze/shared/dev/serial/uartlite_l.c |   99 ++
> Are these Xilinx files shared in the their SDK?
Yes
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/uartlite/src
> Should we start here and then move to a generic location if used on another
> architecture?
I agree. It's the same case for uart16550. uartlite IP core can be
used for other soft-core like RISC-V on Xilinx-based FPGAs
> >  .../microblaze_fpga/startup/sim-crtinit.S     |   46 +-
> FPGA or simulator? The naming seems to contradict it self.
That's likely me building on Joel's first port on GDB, then using the
same file name and modifying it to run on FPGA. Should be renamed to
start.S or something.
> Chris
> devel mailing list
> devel at rtems.org
