[PATCH 3/3] microblaze: Rework for RTEMS 6
Sat Oct 2 14:10:29 UTC 2021
On Sat, Oct 2, 2021, 3:59 AM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> On Sat, 2 Oct 2021 at 02:44, Chris Johns <chrisj at rtems.org> wrote:
> > On 1/10/21 3:43 pm, Alex White wrote:
> > >  bsps/microblaze/include/common/xil_types.h    |  197 +++
> > >  bsps/microblaze/include/dev/serial/uartlite.h |   62 +
> > >  .../include/dev/serial/uartlite_l.h           |  323 +++++
> > >  bsps/microblaze/shared/dev/serial/uartlite.c  |  145 ++
> > >  .../microblaze/shared/dev/serial/uartlite_l.c |   99 ++
> > Are these Xilinx files shared in the their SDK?
> Yes
> https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/uartlite/src
> > Should we start here and then move to a generic location if used on
> another
> > architecture?
> I agree. It's the same case for uart16550. uartlite IP core can be
> used for other soft-core like RISC-V on Xilinx-based FPGAs
> > >  .../microblaze_fpga/startup/sim-crtinit.S     |   46 +-
> > FPGA or simulator? The naming seems to contradict it self.
> That's likely me building on Joel's first port on GDB, then using the
> same file name and modifying it to run on FPGA. Should be renamed to
> start.S or something.
I took that file from somewhere else with that name. Probably from
libgloss. Alex and I can look at naming it something else though.
--joel
> > Chris
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
