[PATCH 3/3] microblaze: Rework for RTEMS 6
Sebastian Huber
Mon Oct 4 06:35:50 UTC 2021
On 02/10/2021 16:10, Joel Sherrill wrote:
>>>> .../microblaze_fpga/startup/sim-crtinit.S | 46 +-
>>> FPGA or simulator? The naming seems to contradict it self.
>> That's likely me building on Joel's first port on GDB, then using the
>> same file name and modifying it to run on FPGA. Should be renamed to
>> start.S or something.
> I took that file from somewhere else with that name. Probably from
> libgloss. Alex and I can look at naming it something else though.
All the "startup" file should move to "start". It would be nice if the
start file is named "start.S".
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
