waf bsp_defaults appears to be broken
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Oct 4 07:32:41 UTC 2021
Hello Joel,
Am 03.10.21 um 18:06 schrieb Joel Sherrill:
> Hi
> No BSP was successfully built in the build sweep Friday. All have
> failures like this:
> $ ./waf bsp_defaults --rtems-bsps=powerpc/psim
I just tested this command and everything seems to work fine. I get a
default config for the BSP.
> There is no top-level group with UID '/grp' in the specification
Maybe something cache related? The whole build specification files are
parsed and put into a cache as a first step. If that doesn't work
correctly, it might lead to odd results.
> The script fetches the BSP's defaults and then changes settings for
> enable tests, etc.
Do you use a fresh checkout or an update from a previous one?
Best regards
Christian
> Anyone else see this?
> --joel
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
