Certificate validation issue when trying to build qemu
Ryan Long
ryan.long at oarcorp.com
Mon Oct 4 21:26:36 UTC 2021
Actually, I was only able to download it on my Linux VM. My FreeBSD 13 VM won't let me download it from the browser. I was using Firefox for both.
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Ryan Long
Sent: Monday, October 4, 2021 2:40 PM
To: devel at rtems.org
Subject: Certificate validation issue when trying to build qemu
Hi,
I'm trying to build qemu, but I keep getting this error message.
RTEMS Source Builder - Set Builder, 6 (3950b1e2d857) Build Set: devel/qemu Build Set: devel/autotools-internal.bset
config: devel/autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-freebsd13.0-1
download: https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz -> sources/autoconf-2.69.tar.gz
download: https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: error: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed
error: downloading https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all paths have failed, giving up Build FAILED
See error report: rsb-report-autoconf-2.69-x86_64-freebsd13.0-1.txt
error: downloading https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all paths have failed, giving up Build Set: Time 0:00:00.807563
error: downloading https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all paths have failed, giving up Build Set: Time 0:00:00.809688 Build FAILED
I am able to download it with a browser, but wget and curl won't work. Wget will work if I use the "-no-check-certificate" flag. Curl doesn't tell me of a flag that could bypass this.
Does anyone know why this is failing?
Thanks,
Ryan
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
