libbsd: Conditional compilation of tests
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Oct 4 23:27:57 UTC 2021
Currently debugger01 is the only user of the test-if-library in libbsd
and it doesn't seem to work as expected. The configure step that detects
libdebugger occurs and succeeds as it should for the zynq a9 qemu BSP,
but debugger01.exe never gets compiled. I found this behavior while
working on the implementation for libdebugger for AArch64. Is there some
configuration that I'm missing to actually enable that test? Changing it
to an unconditional test yields a successfully compiled debugger01.exe.
Perhaps someone that has more familiarity with the waf configure scripts
can tell me what I'm missing.
Thanks,
Kinsey
