waf bsp_defaults appears to be broken
Chris Johns
chrisj at rtems.org
Tue Oct 5 01:26:59 UTC 2021
On 4/10/21 3:06 am, Joel Sherrill wrote:
> No BSP was successfully built in the build sweep Friday. All have
> failures like this:
> $ ./waf bsp_defaults --rtems-bsps=powerpc/psim
> There is no top-level group with UID '/grp' in the specification
> The script fetches the BSP's defaults and then changes settings for
> enable tests, etc.
> Anyone else see this?
I would not use the the bsp_defaults approach to handle BSP testing. The BSP
defaults build target should only be used as a means to find and examine any
options a BSP may have you wish to override. Capturing defaults is counter to
the notion of defaults, ie defaults change?
If you wish to use the defaults then this is all you need:
$ echo "[powerpc/psim]" > config
$ ./waf distclean configure build
If you what to build the tests, POSIX API and debug on:
$ echo "RTEMS_DEBUG = True" >> config
$ echo "RTEMS_POSIX_API = True" >> config
$ echo "BUILD_TESTS = True" >> config
In regards to removing build directories and others things in the lengthy thread
attached to the email, user beware. The recommended solution is:
./waf distclean
