waf bsp_defaults appears to be broken
Mon Oct 4 16:05:39 UTC 2021
On Mon, Oct 4, 2021 at 9:13 AM Christian MAUDERER
<christian.mauderer at embedded-brains.de> wrote:
> Am 04.10.21 um 15:51 schrieb Joel Sherrill:
> > On Mon, Oct 4, 2021 at 2:32 AM Christian MAUDERER
> >> Hello Joel,
> >> Am 03.10.21 um 18:06 schrieb Joel Sherrill:
> >>> Hi
> >>> No BSP was successfully built in the build sweep Friday. All have
> >>> failures like this:
> >>> $ ./waf bsp_defaults --rtems-bsps=powerpc/psim
> >> I just tested this command and everything seems to work fine. I get a
> >> default config for the BSP.
> >>> There is no top-level group with UID '/grp' in the specification
> >> Maybe something cache related? The whole build specification files are
> >> parsed and put into a cache as a first step. If that doesn't work
> >> correctly, it might lead to odd results.
> > This must be it. I suppose I should delete the build/ subdirectory as part
> > of setting up for a sweep.
> If you want to get a clean repository again, you could also use a "git
> clean -dxf". But be very careful with that command. It doesn't ask
> before deleting anything that is not versioned.
That might be ok here because this is a directory only used for the
cron driven build sweeps. Nothing should ever be edited here.
> >>> The script fetches the BSP's defaults and then changes settings for
> >>> enable tests, etc.
> >> Do you use a fresh checkout or an update from a previous one?
> > It's an update to minimize what needs to be done. If the RSB changed, tools
> > and RTEMS are built. If only RTEMS changed, only RTEMS BSPs are built.
> > If nothing changed (rare in a week), then nothing is done.
> > I ended up recloning rtems this time and it seems ok now.
> If you get the error again, it would be interesting to find out what
> caused it. That sounds like something that shouldn't happen. It seems
> that the wscript uses a simple file modification time to find out
> whether the cache has to be re-generated. So if your system time changed
> backward, that might could lead to such errors.
Possible but unlikely. The build sweep for 6 starts at 445pm on Fridays. The
directory should be untouched until the next Friday unless something happens
and I poke around like this morning.
Hopefully removing build/ will help keep things clean.
--joel
> Best regards
> Christian
> > Thanks.
> > --joel
> >> Best regards
> >> Christian
> >>> Anyone else see this?
> >>> --joel
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> >> embedded brains GmbH
> >> Herr Christian MAUDERER
> >> Dornierstr. 4
> >> 82178 Puchheim
> >> Germany
> >> email: christian.mauderer at embedded-brains.de
> >> phone: +49-89-18 94 741 - 18
> >> fax:   +49-89-18 94 741 - 08
> >> Registergericht: Amtsgericht München
> >> Registernummer: HRB 157899
> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> >> Unsere Datenschutzerklärung finden Sie hier:
> >> https://embedded-brains.de/datenschutzerklaerung/
> Dornierstr. 4
> 82178 Puchheim
> Germany
