[PATCH 4/4] sys/tree.h: Red child with black sibling rotations
Tue Oct 5 14:16:25 UTC 2021
Add specialized rotations RB_RED_ROTATE_LEFT() and RB_RED_ROTATE_RIGHT() which
may be used if we rotate a red child which has a black sibling.  Such a red
node must have at least two child nodes so that the following red-black tree
invariant is fulfilled:
  Every path from a given node to any of its descendant NULL nodes goes through
  the same number of black nodes.
      PARENT
  BLACK     RED
        BLACK BLACK
 newlib/libc/include/sys/tree.h | 26 ++++++++++++++++++++++++--
 1 file changed, 24 insertions(+), 2 deletions(-)
diff --git a/newlib/libc/include/sys/tree.h b/newlib/libc/include/sys/tree.h
index 5fc052817..ae5e620c9 100644
--- a/newlib/libc/include/sys/tree.h
+++ b/newlib/libc/include/sys/tree.h
@@ -405,6 +405,28 @@ struct {								\
 	RB_AUGMENT(elm);						\
 } while (/*CONSTCOND*/ 0)
+#define RB_RED_ROTATE_LEFT(head, elm, tmp, field) do {			\
+	(tmp) = RB_RIGHT(elm, field);					\
+	RB_RIGHT(elm, field) = RB_LEFT(tmp, field);			\
+	RB_SET_PARENT(RB_RIGHT(elm, field), elm, field);		\
+	RB_SET_PARENT(tmp, RB_PARENT(elm, field), field);		\
+	RB_SWAP_CHILD(head, elm, tmp, field);				\
+	RB_LEFT(tmp, field) = (elm);					\
+	RB_SET_PARENT(elm, tmp, field);					\
+	RB_AUGMENT(elm);						\
+} while (/*CONSTCOND*/ 0)
+#define RB_RED_ROTATE_RIGHT(head, elm, tmp, field) do {			\
+	(tmp) = RB_LEFT(elm, field);					\
+	RB_LEFT(elm, field) = RB_RIGHT(tmp, field);			\
+	RB_SET_PARENT(RB_LEFT(elm, field), elm, field);			\
+	RB_RIGHT(tmp, field) = (elm);					\
 /* Generates prototypes and inline functions */
 #define	RB_PROTOTYPE(name, type, field, cmp)				\
 	RB_PROTOTYPE_INTERNAL(name, type, field, cmp,)
@@ -519,7 +541,7 @@ name##_RB_REMOVE_COLOR(struct name *head, struct type *parent)		\
 			tmp = RB_RIGHT(parent, field);			\
 			if (RB_COLOR(tmp, field) == RB_RED) {		\
 				RB_SET_BLACKRED(tmp, parent, field);	\
-				RB_ROTATE_LEFT(head, parent, tmp, field);\
+				RB_RED_ROTATE_LEFT(head, parent, tmp, field); \
 			if (RB_ISRED(RB_RIGHT(tmp, field), field))	\
@@ -545,7 +567,7 @@ name##_RB_REMOVE_COLOR(struct name *head, struct type *parent)		\
 			tmp = RB_LEFT(parent, field);			\
-				RB_ROTATE_RIGHT(head, parent, tmp, field);\
+				RB_RED_ROTATE_RIGHT(head, parent, tmp, field); \
 			if (RB_ISRED(RB_LEFT(tmp, field), field))	\
2.26.2
