[PATCH 3/4] sys/tree.h: Add parent rotations
Sebastian Huber
Tue Oct 5 14:16:24 UTC 2021
Add specialized rotations RB_PARENT_ROTATE_LEFT() and RB_PARENT_ROTATE_RIGHT()
which may be used if the parent node exists and the direction of the child is
known. The specialized rotations are derived from RB_ROTATE_LEFT() and
RB_ROTATE_RIGHT() where the RB_SWAP_CHILD() was replaced by a simple
assignment.
newlib/libc/include/sys/tree.h | 36 ++++++++++++++++++++++++++++++----
1 file changed, 32 insertions(+), 4 deletions(-)
diff --git a/newlib/libc/include/sys/tree.h b/newlib/libc/include/sys/tree.h
index 180809e9b..5fc052817 100644
--- a/newlib/libc/include/sys/tree.h
+++ b/newlib/libc/include/sys/tree.h
@@ -381,6 +381,30 @@ struct { \
RB_AUGMENT(elm); \
} while (/*CONSTCOND*/ 0)
+#define RB_PARENT_ROTATE_LEFT(parent, left, tmp, field) do { \
+ (tmp) = RB_RIGHT(left, field); \
+ if ((RB_RIGHT(left, field) = RB_LEFT(tmp, field)) != NULL) { \
+ RB_SET_PARENT(RB_RIGHT(left, field), left, field); \
+ RB_SET_PARENT(tmp, parent, field); \
+ RB_LEFT(parent, field) = (tmp); \
+ RB_LEFT(tmp, field) = (left); \
+ RB_SET_PARENT(left, tmp, field); \
+ RB_AUGMENT(left); \
+} while (/*CONSTCOND*/ 0)
+#define RB_PARENT_ROTATE_RIGHT(parent, elm, tmp, field) do { \
+ (tmp) = RB_LEFT(elm, field); \
+ if ((RB_LEFT(elm, field) = RB_RIGHT(tmp, field)) != NULL) { \
+ RB_SET_PARENT(RB_LEFT(elm, field), elm, field); \
+ RB_RIGHT(parent, field) = (tmp); \
+ RB_RIGHT(tmp, field) = (elm); \
+ RB_SET_PARENT(elm, tmp, field); \
+ RB_AUGMENT(elm); \
/* Generates prototypes and inline functions */
#define RB_PROTOTYPE(name, type, field, cmp) \
RB_PROTOTYPE_INTERNAL(name, type, field, cmp,)
@@ -454,7 +478,8 @@ name##_RB_INSERT_COLOR(struct name *head, struct type *elm) \
continue; \
if (RB_RIGHT(parent, field) == elm) { \
- RB_ROTATE_LEFT(head, parent, tmp, field);\
+ RB_PARENT_ROTATE_LEFT(gparent, parent, \
+ tmp, field); \
tmp = parent; \
parent = elm; \
elm = tmp; \
@@ -470,7 +495,8 @@ name##_RB_INSERT_COLOR(struct name *head, struct type *elm) \
continue; \
if (RB_LEFT(parent, field) == elm) { \
- RB_ROTATE_RIGHT(head, parent, tmp, field);\
+ RB_PARENT_ROTATE_RIGHT(gparent, parent, \
+ tmp, field); \
tmp = parent; \
parent = elm; \
elm = tmp; \
@@ -500,7 +526,8 @@ name##_RB_REMOVE_COLOR(struct name *head, struct type *parent) \
RB_COLOR(RB_RIGHT(tmp, field), field) = RB_BLACK; \
else if (RB_ISRED(RB_LEFT(tmp, field), field)) { \
struct type *oleft; \
- RB_ROTATE_RIGHT(head, tmp, oleft, field); \
+ RB_PARENT_ROTATE_RIGHT(parent, tmp, \
+ oleft, field); \
RB_COLOR(oleft, field) = RB_BLACK; \
tmp = oleft; \
} else { \
@@ -525,7 +552,8 @@ name##_RB_REMOVE_COLOR(struct name *head, struct type *parent) \
RB_COLOR(RB_LEFT(tmp, field), field) = RB_BLACK; \
else if (RB_ISRED(RB_RIGHT(tmp, field), field)) { \
struct type *oright; \
- RB_ROTATE_LEFT(head, tmp, oright, field); \
+ RB_PARENT_ROTATE_LEFT(parent, tmp, \
+ oright, field); \
RB_COLOR(oright, field) = RB_BLACK; \
tmp = oright; \
} else { \
2.26.2
