[PATCH v2 3/3] microblaze: Rework for RTEMS 6
Alex White alex.white at oarcorp.com
Tue Oct 5 19:23:36 UTC 2021
This reworks the existing MicroBlaze architecture port and BSP to
achieve basic functionality using the latest RTEMS APIs.
 bsps/include/bsp/fatal.h                      |    3 +
 .../microblaze/include/bsp}/linker-symbols.h  |    8 +-
 bsps/microblaze/include/common/xil_types.h    |  197 +++
 bsps/microblaze/include/dev/serial/uartlite.h |   62 +
 .../include/dev/serial/uartlite_l.h           |  323 +++++
 bsps/microblaze/microblaze_fpga/clock/clock.c |  145 ++
 .../microblaze_fpga/console/console-io.c      |   57 +
 .../microblaze_fpga/console/debug-io.c        |   60 +-
 .../microblaze/microblaze_fpga/include/bsp.h  |   31 +-
 .../microblaze_fpga/include/bsp/intc.h        |   74 +
 .../microblaze_fpga/include/bsp/irq.h         |   49 +
 .../microblaze_fpga/include/bsp/timer.h       |   69 +
 .../microblaze/microblaze_fpga/include/tm27.h |   26 +-
 bsps/microblaze/microblaze_fpga/irq/irq.c     |  168 +++
 .../start}/_exception_handler.S               |   14 +
 .../start}/_hw_exception_handler.S            |   16 +-
 .../start}/_interrupt_handler.S               |   15 +
 .../microblaze_fpga/start/bspreset.c          |   44 +
 .../microblaze_fpga/start/bspstart.c          |   43 +
 .../microblaze_fpga/start/crtinit.S           |  104 ++
 bsps/microblaze/shared/cache/cache.c          |   36 +
 bsps/microblaze/shared/dev/serial/uartlite.c  |  145 ++
 .../microblaze/shared/dev/serial/uartlite_l.c |   99 ++
 .../microblaze/shared}/start/start.S          |  105 +-
 .../microblaze_fpga/startup/sim-crtinit.S     |   86 --
 cpukit/score/cpu/microblaze/__tls_get_addr.c  |   54 +
 cpukit/score/cpu/microblaze/cpu.c             |  192 +--
 cpukit/score/cpu/microblaze/cpu_asm.S         |  194 +++
 .../cpu/microblaze/{ => include}/rtems/asm.h  |   51 +-
 .../cpu/microblaze/include/rtems/score/cpu.h  |  305 ++++
 .../include/rtems/score/cpuatomic.h           |   41 +
 .../microblaze/include/rtems/score/cpuimpl.h  |   96 ++
 .../{ => include}/rtems/score/microblaze.h    |   70 +-
 .../microblaze/microblaze-context-switch.S    |   30 +-
 .../microblaze/microblaze-context-validate.S  |  117 ++
 .../microblaze-context-volatile-clobber.S     |   28 +
 cpukit/score/cpu/microblaze/rtems/score/cpu.h | 1280 -----------------
 spec/build/bsps/microblaze/grp.yml            |   15 +
 .../bsps/microblaze/microblaze_fpga/abi.yml   |   20 +
 .../microblaze/microblaze_fpga/bspkcu105.yml  |   24 +
 .../microblaze_fpga/bspkcu105_qemu.yml        |   24 +
 .../bsps/microblaze/microblaze_fpga/grp.yml   |   36 +
 .../microblaze/microblaze_fpga/linkcmds.yml   |  242 ++++
 .../bsps/microblaze/microblaze_fpga/obj.yml   |   51 +
 .../microblaze_fpga/optconsoleinterrupts.yml  |   15 +
 .../microblaze_fpga/optintcbaseaddress.yml    |   18 +
 .../microblaze_fpga/opttimerbaseaddress.yml   |   18 +
 .../microblaze_fpga/opttimerfrequency.yml     |   17 +
 .../optuartlitebaseaddress.yml                |   18 +
 .../bsps/microblaze/microblaze_fpga/start.yml |   14 +
 .../microblaze_fpga/tstkcu105_qemu.yml        |   14 +
 spec/build/cpukit/cpumicroblaze.yml           |   29 +
 spec/build/cpukit/librtemscpu.yml             |    2 +
 53 files changed, 3306 insertions(+), 1688 deletions(-)
 rename {c/src/lib/libbsp/microblaze/shared/include => bsps/microblaze/include/bsp}/linker-symbols.h (93%)
 create mode 100644 bsps/microblaze/include/common/xil_types.h
 create mode 100644 bsps/microblaze/include/dev/serial/uartlite.h
 create mode 100644 bsps/microblaze/include/dev/serial/uartlite_l.h
 create mode 100644 bsps/microblaze/microblaze_fpga/clock/clock.c
 create mode 100644 bsps/microblaze/microblaze_fpga/console/console-io.c
 rename c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c => bsps/microblaze/microblaze_fpga/console/debug-io.c (54%)
 rename {c/src/lib/libbsp => bsps}/microblaze/microblaze_fpga/include/bsp.h (69%)
 create mode 100644 bsps/microblaze/microblaze_fpga/include/bsp/intc.h
 create mode 100644 bsps/microblaze/microblaze_fpga/include/bsp/irq.h
 create mode 100644 bsps/microblaze/microblaze_fpga/include/bsp/timer.h
 rename {c/src/lib/libbsp => bsps}/microblaze/microblaze_fpga/include/tm27.h (71%)
 create mode 100644 bsps/microblaze/microblaze_fpga/irq/irq.c
 rename {c/src/lib/libbsp/microblaze/microblaze_fpga/startup => bsps/microblaze/microblaze_fpga/start}/_exception_handler.S (88%)
 rename {c/src/lib/libbsp/microblaze/gdbmbsim/startup => bsps/microblaze/microblaze_fpga/start}/_hw_exception_handler.S (87%)
 rename {c/src/lib/libbsp/microblaze/microblaze_fpga/startup => bsps/microblaze/microblaze_fpga/start}/_interrupt_handler.S (86%)
 create mode 100644 bsps/microblaze/microblaze_fpga/start/bspreset.c
 create mode 100644 bsps/microblaze/microblaze_fpga/start/bspstart.c
 create mode 100644 bsps/microblaze/microblaze_fpga/start/crtinit.S
 create mode 100644 bsps/microblaze/shared/cache/cache.c
 create mode 100644 bsps/microblaze/shared/dev/serial/uartlite.c
 create mode 100644 bsps/microblaze/shared/dev/serial/uartlite_l.c
 rename {c/src/lib/libbsp/microblaze/microblaze_fpga => bsps/microblaze/shared}/start/start.S (53%)
 delete mode 100644 c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
 create mode 100644 cpukit/score/cpu/microblaze/__tls_get_addr.c
 create mode 100644 cpukit/score/cpu/microblaze/cpu_asm.S
 rename cpukit/score/cpu/microblaze/{ => include}/rtems/asm.h (61%)
 create mode 100644 cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
 create mode 100644 cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
 create mode 100644 cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
 rename cpukit/score/cpu/microblaze/{ => include}/rtems/score/microblaze.h (50%)
 create mode 100644 cpukit/score/cpu/microblaze/microblaze-context-validate.S
 create mode 100644 cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S
 delete mode 100644 cpukit/score/cpu/microblaze/rtems/score/cpu.h
 create mode 100644 spec/build/bsps/microblaze/grp.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/abi.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/bspkcu105.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/bspkcu105_qemu.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/grp.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/obj.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optconsoleinterrupts.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optintcbaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opttimerbaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opttimerfrequency.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optuartlitebaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/start.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/tstkcu105_qemu.yml
 create mode 100644 spec/build/cpukit/cpumicroblaze.yml
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index f9b9e39193..a11235d00f 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -174,6 +174,9 @@ typedef enum {
   IMXRT_FATAL_LPI2C_HW_INIT_FAILED,
   IMXRT_FATAL_LPI2C_REGISTER_FAILED,
   IMXRT_FATAL_LPI2C_UNSUPPORTED_HARDWARE,
+  /* MicroBlaze fatal codes */
+  MICROBLAZE_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(16),
 } bsp_fatal_code;
 RTEMS_NO_RETURN static inline void
diff --git a/c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h b/bsps/microblaze/include/bsp/linker-symbols.h
similarity index 93%
rename from c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h
rename to bsps/microblaze/include/bsp/linker-symbols.h
index 60a5057486..da162060b5 100644
--- a/c/src/lib/libbsp/microblaze/shared/include/linker-symbols.h
+++ b/bsps/microblaze/include/bsp/linker-symbols.h
@@ -1,5 +1,7 @@
- *  Copyright (C) 2015 Hesham Almatary
+ * Copyright (C) 2015 Hesham Almatary
  * modification, are permitted provided that the following conditions
@@ -7,8 +9,8 @@
  * 1. Redistributions of source code must retain the above copyright
  *    notice, this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright
- *   notice, this list of conditions and the following disclaimer in the
- *   documentation and/or other materials provided with the distribution.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
diff --git a/bsps/microblaze/include/common/xil_types.h b/bsps/microblaze/include/common/xil_types.h
new file mode 100644
index 0000000000..929e83f8f0
--- /dev/null
+++ b/bsps/microblaze/include/common/xil_types.h
@@ -0,0 +1,197 @@
+* Copyright (c) 2010 - 2020 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_types.h
+* @addtogroup common_types Basic Data types for Xilinx® Software IP
+* The xil_types.h file contains basic types for Xilinx software IP. These data types
+* are applicable for all processors supported by Xilinx.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who    Date   Changes
+* 1.00a hbm  07/14/09 First release
+* 3.03a sdm  05/30/11 Added Xuint64 typedef and XUINT64_MSW/XUINT64_LSW macros
+* 5.00 	pkp  05/29/14 Made changes for 64 bit architecture
+*	srt  07/14/14 Use standard definitions from stdint.h and stddef.h
+*		      Define LONG and ULONG datatypes and mask values
+* 7.00  mus  01/07/19 Add cpp extern macro
+* 7.1   aru  08/19/19 Shift the value in UPPER_32_BITS only if it
+*                     is 64-bit processor
+* </pre>
+#ifndef XIL_TYPES_H	/* prevent circular inclusions */
+#define XIL_TYPES_H	/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+#include <stddef.h>
+/************************** Constant Definitions *****************************/
+#ifndef TRUE
+#  define TRUE		1U
+#endif
+#ifndef FALSE
+#  define FALSE		0U
+#endif
+#ifndef NULL
+#define NULL		0U
+#endif
+#define XIL_COMPONENT_IS_READY     0x11111111U  /**< In device drivers, This macro will be
+                                                 assigend to "IsReady" member of driver
+												 instance to indicate that driver
+												 instance is initialized and ready to use. */
+#define XIL_COMPONENT_IS_STARTED   0x22222222U  /**< In device drivers, This macro will be assigend to
+                                                 "IsStarted" member of driver instance
+												 to indicate that driver instance is
+												 started and it can be enabled. */
+/* @name New types
+ * New simple types.
+#ifndef __KERNEL__
+#ifndef XBASIC_TYPES_H
+ * guarded against xbasic_types.h.
+typedef uint8_t u8;
+typedef uint16_t u16;
+typedef uint32_t u32;
+#define __XUINT64__
+typedef struct
+	u32 Upper;
+	u32 Lower;
+} Xuint64;
+* @brief    Return the most significant half of the 64 bit data type.
+* @param    x is the 64 bit word.
+* @return   The upper 32 bits of the 64 bit word.
+#define XUINT64_MSW(x) ((x).Upper)
+* @brief    Return the least significant half of the 64 bit data type.
+* @return   The lower 32 bits of the 64 bit word.
+#define XUINT64_LSW(x) ((x).Lower)
+#endif /* XBASIC_TYPES_H */
+ * xbasic_types.h does not typedef s* or u64
+typedef char char8;
+typedef int8_t s8;
+typedef int16_t s16;
+typedef int32_t s32;
+typedef int64_t s64;
+typedef uint64_t u64;
+typedef int sint32;
+typedef intptr_t INTPTR;
+typedef uintptr_t UINTPTR;
+typedef ptrdiff_t PTRDIFF;
+#if !defined(LONG) || !defined(ULONG)
+typedef long LONG;
+typedef unsigned long ULONG;
+#endif
+#define ULONG64_HI_MASK	0xFFFFFFFF00000000U
+#define ULONG64_LO_MASK	~ULONG64_HI_MASK
+#else
+#include <linux/types.h>
+#endif
+ * This data type defines an interrupt handler for a device.
+ * The argument points to the instance of the component
+typedef void (*XInterruptHandler) (void *InstancePtr);
+ * This data type defines an exception handler for a processor.
+typedef void (*XExceptionHandler) (void *InstancePtr);
+ * @brief  Returns 32-63 bits of a number.
+ * @param  n : Number being accessed.
+ * @return Bits 32-63 of number.
+ * @note    A basic shift-right of a 64- or 32-bit quantity.
+ *          Use this to suppress the "right shift count >= width of type"
+ *          warning when that quantity is 32-bits.
+#if defined (__aarch64__) || defined (__arch64__)
+#define UPPER_32_BITS(n) ((u32)(((n) >> 16) >> 16))
+#else
+#define UPPER_32_BITS(n) 0U
+#endif
+ * @brief  Returns 0-31 bits of a number
+ * @return Bits 0-31 of number
+#define LOWER_32_BITS(n) ((u32)(n))
+#ifndef TRUE
+#define TRUE		1U
+#endif
+#ifndef FALSE
+#define FALSE		0U
+#endif
+#ifndef NULL
+#define NULL		0U
+#endif
+#ifdef __cplusplus
+#endif
+#endif	/* end of protection macro */
+* @} End of "addtogroup common_types".
\ No newline at end of file
diff --git a/bsps/microblaze/include/dev/serial/uartlite.h b/bsps/microblaze/include/dev/serial/uartlite.h
index 0000000000..6e288d4dc7
--- /dev/null
+++ b/bsps/microblaze/include/dev/serial/uartlite.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroblaze
+ * @brief MicroBlaze AXI UART Lite terminal definitions
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
+#define LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
+#include <rtems/termiostypes.h>
+#include <dev/serial/uartlite_l.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+typedef struct {
+  rtems_termios_device_context base;
+  uintptr_t address;
+  uint32_t initial_baud;
+#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
+  bool transmitting;
+#endif
+} uart_lite_context;
+extern const rtems_termios_device_handler microblaze_uart_fns;
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_SHARED_UARTLITE_H */
diff --git a/bsps/microblaze/include/dev/serial/uartlite_l.h b/bsps/microblaze/include/dev/serial/uartlite_l.h
index 0000000000..8c0598e191
--- /dev/null
+++ b/bsps/microblaze/include/dev/serial/uartlite_l.h
@@ -0,0 +1,323 @@
+* Copyright (C) 2002 - 2020 Xilinx, Inc.  All rights reserved.
+* @file xuartlite_l.h
+* @addtogroup uartlite_v3_5
+* This header file contains identifiers and low-level driver functions (or
+* macros) that can be used to access the device.  High-level driver functions
+* are defined in xuartlite.h.
+* <pre>
+* 1.00b rpm  04/25/02 First release
+* 1.00b rpm  07/07/03 Removed references to XUartLite_GetControlReg macro
+*                     since the control register is write-only
+* 1.12a mta  03/21/07 Updated to new coding style
+* 1.13a sv   01/21/08 Updated driver to support access through DCR bus
+* 2.00a ktn  10/20/09 Updated to use HAL Processor APIs. The macros have been
+*		      renamed to remove _m from the name.
+* 3.2   sk   11/10/15 Used UINTPTR instead of u32 for Baseaddress CR# 867425.
+*                     Changed the prototypes of XUartLite_SendByte,
+*                     XUartLite_RecvByte APIs.
+* </pre>
+#ifndef XUARTLITE_L_H /* prevent circular inclusions */
+#define XUARTLITE_L_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files ********************************/
+#ifndef __rtems__
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+#else
+#include <common/xil_types.h>
+static inline u32 Xil_In32(UINTPTR Addr)
+	return *(volatile u32 *) Addr;
+static inline void Xil_Out32(UINTPTR Addr, u32 Value)
+	volatile u32 *LocalAddr = (volatile u32 *)Addr;
+	*LocalAddr = Value;
+#endif /* __rtems__ */
+ * XPAR_XUARTLITE_USE_DCR_BRIDGE has to be set to 1 if the UartLite device is
+ * accessed through a DCR bus connected to a bridge.
+#define XPAR_XUARTLITE_USE_DCR_BRIDGE 0
+#if (XPAR_XUARTLITE_USE_DCR_BRIDGE != 0)
+#include "xio_dcr.h"
+#endif
+/************************** Constant Definitions ****************************/
+/* UART Lite register offsets */
+#define XUL_RX_FIFO_OFFSET		0	/* receive FIFO, read only */
+#define XUL_TX_FIFO_OFFSET		1	/* transmit FIFO, write only */
+#define XUL_STATUS_REG_OFFSET		2	/* status register, read only */
+#define XUL_CONTROL_REG_OFFSET		3	/* control reg, write only */
+#else
+#define XUL_TX_FIFO_OFFSET		4	/* transmit FIFO, write only */
+#define XUL_STATUS_REG_OFFSET		8	/* status register, read only */
+#define XUL_CONTROL_REG_OFFSET		12	/* control reg, write only */
+#endif
+/* Control Register bit positions */
+#define XUL_CR_ENABLE_INTR		0x10	/* enable interrupt */
+#define XUL_CR_FIFO_RX_RESET		0x02	/* reset receive FIFO */
+#define XUL_CR_FIFO_TX_RESET		0x01	/* reset transmit FIFO */
+/* Status Register bit positions */
+#define XUL_SR_PARITY_ERROR		0x80
+#define XUL_SR_FRAMING_ERROR		0x40
+#define XUL_SR_OVERRUN_ERROR		0x20
+#define XUL_SR_INTR_ENABLED		0x10	/* interrupt enabled */
+#define XUL_SR_TX_FIFO_FULL		0x08	/* transmit FIFO full */
+#define XUL_SR_TX_FIFO_EMPTY		0x04	/* transmit FIFO empty */
+#define XUL_SR_RX_FIFO_FULL		0x02	/* receive FIFO full */
+#define XUL_SR_RX_FIFO_VALID_DATA	0x01	/* data in receive FIFO */
+/* The following constant specifies the size of the Transmit/Receive FIFOs.
+ * The FIFO size is fixed to 16 in the Uartlite IP and the size is not
+ * configurable. This constant is not used in the driver.
+#define XUL_FIFO_SIZE			16
+/* Stop bits are fixed at 1. Baud, parity, and data bits are fixed on a
+ * per instance basis
+#define XUL_STOP_BITS			1
+/* Parity definitions
+#define XUL_PARITY_NONE			0
+#define XUL_PARITY_ODD			1
+#define XUL_PARITY_EVEN			2
+/**************************** Type Definitions ******************************/
+/***************** Macros (Inline Functions) Definitions ********************/
+ * Define the appropriate I/O access method to memory mapped I/O or DCR.
+#define XUartLite_In32  XIo_DcrIn
+#define XUartLite_Out32 XIo_DcrOut
+#else
+#define XUartLite_In32  Xil_In32
+#define XUartLite_Out32 Xil_Out32
+#endif
+* Write a value to a UartLite register. A 32 bit write is performed.
+* @param	BaseAddress is the base address of the UartLite device.
+* @param	RegOffset is the register offset from the base to write to.
+* @param	Data is the data written to the register.
+* @return	None.
+* @note		C-style signature:
+*		void XUartLite_WriteReg(u32 BaseAddress, u32 RegOffset,
+*					u32 Data)
+#define XUartLite_WriteReg(BaseAddress, RegOffset, Data) \
+	XUartLite_Out32((BaseAddress) + (RegOffset), (u32)(Data))
+* Read a value from a UartLite register. A 32 bit read is performed.
+* @param	RegOffset is the register offset from the base to read from.
+* @return	Data read from the register.
+*		u32 XUartLite_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XUartLite_ReadReg(BaseAddress, RegOffset) \
+	XUartLite_In32((BaseAddress) + (RegOffset))
+* Set the contents of the control register. Use the XUL_CR_* constants defined
+* above to create the bit-mask to be written to the register.
+* @param	BaseAddress is the base address of the device
+* @param	Mask is the 32-bit value to write to the control register
+* @return	None.
+* @note		C-style Signature:
+*		void XUartLite_SetControlReg(u32 BaseAddress, u32 Mask);
+#define XUartLite_SetControlReg(BaseAddress, Mask) \
+	XUartLite_WriteReg((BaseAddress), XUL_CONTROL_REG_OFFSET, (Mask))
+* Get the contents of the status register. Use the XUL_SR_* constants defined
+* above to interpret the bit-mask returned.
+* @return	A 32-bit value representing the contents of the status register.
+*		u32 XUartLite_GetStatusReg(u32 BaseAddress);
+#define XUartLite_GetStatusReg(BaseAddress) \
+		XUartLite_ReadReg((BaseAddress), XUL_STATUS_REG_OFFSET)
+* Check to see if the receiver has data.
+* @return	TRUE if the receiver is empty, FALSE if there is data present.
+*		int XUartLite_IsReceiveEmpty(u32 BaseAddress);
+#define XUartLite_IsReceiveEmpty(BaseAddress) \
+  ((XUartLite_GetStatusReg((BaseAddress)) & XUL_SR_RX_FIFO_VALID_DATA) != \
+	XUL_SR_RX_FIFO_VALID_DATA)
+* Check to see if the transmitter is full.
+* @return	TRUE if the transmitter is full, FALSE otherwise.
+* 		int XUartLite_IsTransmitFull(u32 BaseAddress);
+#define XUartLite_IsTransmitFull(BaseAddress) \
+	((XUartLite_GetStatusReg((BaseAddress)) & XUL_SR_TX_FIFO_FULL) == \
+	  XUL_SR_TX_FIFO_FULL)
+* Check to see if the interrupt is enabled.
+* @return	TRUE if the interrupt is enabled, FALSE otherwise.
+*		int XUartLite_IsIntrEnabled(u32 BaseAddress);
+#define XUartLite_IsIntrEnabled(BaseAddress) \
+	((XUartLite_GetStatusReg((BaseAddress)) & XUL_SR_INTR_ENABLED) == \
+	  XUL_SR_INTR_ENABLED)
+* Enable the device interrupt. We cannot read the control register, so we
+* just write the enable interrupt bit and clear all others. Since the only
+* other ones are the FIFO reset bits, this works without side effects.
+* @return	None.
+* 		void XUartLite_EnableIntr(u32 BaseAddress);
+#define XUartLite_EnableIntr(BaseAddress) \
+		XUartLite_SetControlReg((BaseAddress), XUL_CR_ENABLE_INTR)
+* Disable the device interrupt. We cannot read the control register, so we
+* just clear all bits. Since the only other ones are the FIFO reset bits,
+* this works without side effects.
+* @return	None.
+* 		void XUartLite_DisableIntr(u32 BaseAddress);
+#define XUartLite_DisableIntr(BaseAddress) \
+		XUartLite_SetControlReg((BaseAddress), 0)
+/************************** Function Prototypes *****************************/
+void XUartLite_SendByte(UINTPTR BaseAddress, u8 Data);
+u8 XUartLite_RecvByte(UINTPTR BaseAddress);
+#ifdef __cplusplus
+#endif
diff --git a/bsps/microblaze/microblaze_fpga/clock/clock.c b/bsps/microblaze/microblaze_fpga/clock/clock.c
index 0000000000..a8a5dc38a8
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/clock/clock.c
@@ -0,0 +1,145 @@
+ * @file
+ * @brief MicroBlaze AXI Timer clock support
+ * are met:
+#include <bsp/fatal.h>
+#include <bsp/timer.h>
+#include <rtems.h>
+#include <rtems/irq-extension.h>
+#include <rtems/timecounter.h>
+static rtems_timecounter_simple mblaze_tc;
+static uint32_t microblaze_tc_get( rtems_timecounter_simple *tc )
+  volatile Microblaze_Timer *timer = _Microblaze_Timer;
+  return timer->tcr0;
+static bool microblaze_tc_is_pending( rtems_timecounter_simple *tc )
+  return ( timer->tcsr0 & MICROBLAZE_TIMER_TCSR0_T0INT ) != 0;
+static uint32_t microblaze_tc_get_timecount( struct timecounter *tc )
+  return rtems_timecounter_simple_downcounter_get(
+    tc,
+    microblaze_tc_get,
+    microblaze_tc_is_pending
+static void microblaze_clock_initialize( void )
+  /* Set load register to 0 */
+  timer->tlr0 = 0;
+  /* Reset the timer and interrupt */
+  timer->tcsr0 = MICROBLAZE_TIMER_TCSR0_T0INT | MICROBLAZE_TIMER_TCSR0_LOAD0;
+  /* Release the reset */
+  timer->tcsr0 = 0;
+   * Enable interrupt, auto reload mode, external interrupt signal,
+   * and down counter
+  timer->tcsr0 =  MICROBLAZE_TIMER_TCSR0_ARHT0 | MICROBLAZE_TIMER_TCSR0_ENIT0 |
+                  MICROBLAZE_TIMER_TCSR0_GENT0 | MICROBLAZE_TIMER_TCSR0_UDT0;
+  uint64_t us_per_tick = rtems_configuration_get_microseconds_per_tick();
+  uint32_t counter_frequency_in_hz = BSP_MICROBLAZE_FPGA_TIMER_FREQUENCY;
+  uint32_t counter_ticks_per_clock_tick =
+    ( counter_frequency_in_hz * us_per_tick ) / 1000000;
+  /* Set a reset value for the timer counter */
+  timer->tlr0 = counter_ticks_per_clock_tick;
+  uint32_t control_status_reg = timer->tcsr0;
+  /* Load the reset value into the counter register */
+  timer->tcsr0 = MICROBLAZE_TIMER_TCSR0_LOAD0;
+  /* Enable the timer */
+  timer->tcsr0 = control_status_reg | MICROBLAZE_TIMER_TCSR0_ENT0;
+  rtems_timecounter_simple_install(
+    &mblaze_tc,
+    counter_frequency_in_hz,
+    counter_ticks_per_clock_tick,
+    microblaze_tc_get_timecount
+static void microblaze_clock_at_tick( rtems_timecounter_simple *tc )
+  if ( ( timer->tcsr0 & MICROBLAZE_TIMER_TCSR0_T0INT ) == 0 ) {
+    return;
+  /* Clear the interrupt */
+  timer->tcsr0 |= MICROBLAZE_TIMER_TCSR0_T0INT;
+static void microblaze_tc_tick( void )
+  rtems_timecounter_simple_downcounter_tick(
+    &mblaze_tc,
+    microblaze_clock_at_tick
+static void microblaze_clock_handler_install( rtems_interrupt_handler isr )
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  sc = rtems_interrupt_handler_install(
+    0,
+    "Clock",
+    RTEMS_INTERRUPT_UNIQUE,
+    isr,
+    NULL
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    bsp_fatal( MICROBLAZE_FATAL_CLOCK_IRQ_INSTALL );
+#define Clock_driver_support_initialize_hardware() microblaze_clock_initialize()
+#define Clock_driver_support_install_isr( isr ) \
+  microblaze_clock_handler_install( isr )
+#define Clock_driver_timecounter_tick() microblaze_tc_tick()
+/* Include shared source clock driver code */
+#include "../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/microblaze/microblaze_fpga/console/console-io.c b/bsps/microblaze/microblaze_fpga/console/console-io.c
index 0000000000..cb2e367035
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/console/console-io.c
@@ -0,0 +1,57 @@
+ * @file
+ * @brief MicroBlaze console configuration
+ * are met:
+#include <bsp/console-termios.h>
+#include <dev/serial/uartlite.h>
+#include <bspopts.h>
+uart_lite_context microblaze_qemu_uart_context = {
+  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "UARTLITE" ),
+  .address = BSP_MICROBLAZE_FPGA_UART_BASE,
+  .initial_baud = 115200
+const console_device console_device_table[] = {
+    .device_file = "/dev/ttyS0",
+    .probe = console_device_probe_default,
+    .handler = &microblaze_uart_fns,
+    .context = &microblaze_qemu_uart_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE( console_device_table );
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c b/bsps/microblaze/microblaze_fpga/console/debug-io.c
similarity index 54%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c
rename to bsps/microblaze/microblaze_fpga/console/debug-io.c
index 47592967ac..e88f5468a7 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/console/console-io.c
+++ b/bsps/microblaze/microblaze_fpga/console/debug-io.c
@@ -1,13 +1,16 @@
  * @file
- * @ingroup microblaze_uart
- * @brief Console Configuration.
+ * @brief MicroBlaze debug IO support
@@ -15,8 +18,8 @@
@@ -31,44 +34,33 @@
 #include <rtems/bspIo.h>
-#include <libchip/serial.h>
-#include <bsp/uart.h>
-console_tbl Console_Configuration_Ports [] = {
-      .sDeviceName = "/dev/ttyS0",
-      .deviceType = SERIAL_CUSTOM,
-      .pDeviceFns = &microblaze_uart_fns,
-      .deviceProbe = NULL,
-      .pDeviceFlow = NULL,
-      .ulCtrlPort1 = UART_BASEADDRESS,
-      .ulCtrlPort2 = 0,
-      .ulClock = 9600,
-      .ulIntVector = 0
+static void output_char( char c )
+  if ( c == '\n' ) {
+    XUartLite_SendByte( BSP_MICROBLAZE_FPGA_UART_BASE, '\r' );
+  XUartLite_SendByte( BSP_MICROBLAZE_FPGA_UART_BASE, c );
-#define PORT_COUNT \
-  (sizeof(Console_Configuration_Ports) \
-    / sizeof(Console_Configuration_Ports [0]))
+static int xUartLite_RecvByte( int minor )
+  if ( XUartLite_IsReceiveEmpty( BSP_MICROBLAZE_FPGA_UART_BASE ) ) {
+    return -1;
-unsigned long Console_Configuration_Count = PORT_COUNT;
+  return XUartLite_ReadReg( BSP_MICROBLAZE_FPGA_UART_BASE, XUL_RX_FIFO_OFFSET );
-static void output_char(char c)
+static int get_char( void )
-  const console_fns *con =
-    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
-  if (c == '\n') {
-    con->deviceWritePolled((int) Console_Port_Minor, '\r');
-  con->deviceWritePolled((int) Console_Port_Minor, c);
+  return xUartLite_RecvByte( 0 );
 BSP_output_char_function_type BSP_output_char = output_char;
-BSP_polling_getchar_function_type BSP_poll_char = NULL;
+BSP_polling_getchar_function_type BSP_poll_char = get_char;
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h b/bsps/microblaze/microblaze_fpga/include/bsp.h
similarity index 69%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h
rename to bsps/microblaze/microblaze_fpga/include/bsp.h
index cb72835571..e83e632553 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/bsp.h
+++ b/bsps/microblaze/microblaze_fpga/include/bsp.h
@@ -1,5 +1,16 @@
+ * @file
+ * @brief Core BSP definitions
@@ -7,8 +18,8 @@
@@ -23,26 +34,20 @@
-#ifndef _BSP_H
-#define _BSP_H
+#ifndef LIBBSP_MICROBLAZE_FPGA_BSP_H
+#define LIBBSP_MICROBLAZE_FPGA_BSP_H
 #ifdef __cplusplus
 extern "C" {
 #endif
+#include <bsp/default-initial-extension.h>
-#include <rtems/iosupp.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-/* support for simulated clock tick */
-Thread clock_driver_sim_idle_body(uintptr_t);
-#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
 #ifdef __cplusplus
 #endif
-#endif
+#endif /* LIBBSP_MICROBLAZE_FPGA_BSP_H */
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/intc.h b/bsps/microblaze/microblaze_fpga/include/bsp/intc.h
index 0000000000..39b009de4c
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/intc.h
@@ -0,0 +1,74 @@
+ * @file
+ * @brief MicroBlaze AXI Interrupt Controller definitions
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_FPGA_INTC_H
+#define LIBBSP_MICROBLAZE_FPGA_INTC_H
+#include <bsp/utility.h>
+#ifdef __cplusplus
+extern "C" {
+typedef struct {
+  /* Interrupt Status Register */
+  uint32_t isr;
+  uint32_t ipr;
+  /* Interrupt Enable Register */
+  uint32_t ier;
+  /* Interrupt Acknowledge Register */
+  uint32_t iar;
+  uint32_t sie;
+  uint32_t cie;
+  uint32_t ivr;
+#define MICROBLAZE_INTC_MER_HIE BSP_BIT32(1)
+#define MICROBLAZE_INTC_MER_ME BSP_BIT32(0)
+  /* Master Enable Register */
+  uint32_t mer;
+  /* Interrupt Mode Register, this is present only for Fast Interrupt */
+  uint32_t imr;
+  /* Interrupt Level Register */
+  uint32_t ilr;
+} Microblaze_INTC;
+#define _Microblaze_INTC ((volatile Microblaze_INTC *) BSP_MICROBLAZE_FPGA_INTC_BASE)
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_FPGA_INTC_H */
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/irq.h b/bsps/microblaze/microblaze_fpga/include/bsp/irq.h
index 0000000000..0a7c211fb0
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/irq.h
@@ -0,0 +1,49 @@
+ * @file
+ * @brief BSP IRQ definitions
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_FPGA_IRQ_H
+#define LIBBSP_MICROBLAZE_FPGA_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#endif /* ASM */
+#define BSP_INTERRUPT_VECTOR_COUNT 32
+#endif /* LIBBSP_MICROBLAZE_FPGA_IRQ_H */
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/timer.h b/bsps/microblaze/microblaze_fpga/include/bsp/timer.h
index 0000000000..562fdd79b0
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/timer.h
@@ -0,0 +1,69 @@
+ * @file
+ * @brief MicroBlaze AXI Timer definitions
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_FPGA_TIMER_H
+#define LIBBSP_MICROBLAZE_FPGA_TIMER_H
+#ifdef __cplusplus
+extern "C" {
+typedef struct {
+#define MICROBLAZE_TIMER_TCSR0_T0INT BSP_BIT32(8)
+#define MICROBLAZE_TIMER_TCSR0_ENT0 BSP_BIT32(7)
+#define MICROBLAZE_TIMER_TCSR0_ENIT0 BSP_BIT32(6)
+#define MICROBLAZE_TIMER_TCSR0_LOAD0 BSP_BIT32(5)
+#define MICROBLAZE_TIMER_TCSR0_ARHT0 BSP_BIT32(4)
+#define MICROBLAZE_TIMER_TCSR0_GENT0 BSP_BIT32(2)
+#define MICROBLAZE_TIMER_TCSR0_UDT0 BSP_BIT32(1)
+  /* Control/Status register */
+  uint32_t tcsr0;
+  /* Load register */
+  uint32_t tlr0;
+  /* Timer counter register */
+  uint32_t tcr0;
+} Microblaze_Timer;
+#define _Microblaze_Timer ((volatile Microblaze_Timer *) BSP_MICROBLAZE_FPGA_TIMER_BASE)
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_FPGA_TIMER_H */
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h b/bsps/microblaze/microblaze_fpga/include/tm27.h
similarity index 71%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h
rename to bsps/microblaze/microblaze_fpga/include/tm27.h
index 393990157f..f2e384b534 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/include/tm27.h
+++ b/bsps/microblaze/microblaze_fpga/include/tm27.h
@@ -1,6 +1,15 @@
+ * @file
+ * @brief BSP tm27 header
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
@@ -8,8 +17,8 @@
@@ -32,17 +41,18 @@
 #define __tm27_h
- *  Define the interrupt mechanism for Time Test 27
+ * Time Test 27 cannot be implemented reliably because the AXI interrupt
+ * controller is not guaranteed to support software interrupts.
 #define MUST_WAIT_FOR_INTERRUPT 0
 #define Install_tm27_vector( handler ) /* set_vector( (handler), 6, 1 ) */
-#define Cause_tm27_intr()  /* XXX */
+#define Cause_tm27_intr()  /* empty */
-#define Clear_tm27_intr()  /* XXX */
+#define Clear_tm27_intr()  /* empty */
 #define Lower_tm27_intr() /* empty */
-#endif
+#endif /* __tm27_h */
diff --git a/bsps/microblaze/microblaze_fpga/irq/irq.c b/bsps/microblaze/microblaze_fpga/irq/irq.c
index 0000000000..1a5ca981a6
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/irq/irq.c
@@ -0,0 +1,168 @@
+ * @file
+ * @brief MicroBlaze interrupt support
+ * are met:
+#include <bsp/intc.h>
+#include <bsp/irq-generic.h>
+#include <rtems/score/cpu.h>
+static void ack_interrupt( uint8_t source )
+  volatile Microblaze_INTC *intc = _Microblaze_INTC;
+  intc->iar = 0x1 << source;
+rtems_status_code bsp_interrupt_get_attributes(
+  rtems_vector_number         vector,
+  rtems_interrupt_attributes *attributes
+  attributes->is_maskable = true;
+  attributes->maybe_enable = true;
+  attributes->maybe_disable = true;
+  attributes->can_clear = true;
+  attributes->cleared_by_acknowledge = true;
+  return RTEMS_SUCCESSFUL;
+rtems_status_code bsp_interrupt_is_pending(
+  bool               *pending
+  bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) );
+  bsp_interrupt_assert( pending != NULL );
+  *pending = false;
+  return RTEMS_UNSATISFIED;
+rtems_status_code bsp_interrupt_raise( rtems_vector_number vector )
+rtems_status_code bsp_interrupt_clear( rtems_vector_number vector )
+  intc->iar = 0x1 << vector;
+rtems_status_code bsp_interrupt_vector_is_enabled(
+  bool               *enabled
+  bsp_interrupt_assert( enabled != NULL );
+  uint32_t mask = 1 << vector;
+  *enabled = (intc->ier & mask) != 0;
+rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector )
+  intc->ier |= mask;
+rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector )
+  intc->ier &= ~mask;
+void bsp_interrupt_facility_initialize( void )
+   * Enable HW interrupts on the interrupt controller. This happens before
+   * interrupts are enabled on the processor.
+  intc->mer = MICROBLAZE_INTC_MER_ME | MICROBLAZE_INTC_MER_HIE;
+void bsp_interrupt_dispatch( uint32_t source )
+  uint32_t vector_number = 0;
+  if ( source == 0xFF ) {
+    /* Read interrupt controller to get the source */
+    vector_number = intc->isr;
+    /* Handle and the first interrupt that is set */
+    uint8_t interrupt_status = 0;
+    for ( int i = 0; i < 32; i++ ) {
+      interrupt_status = vector_number >> i & 0x1;
+      if ( interrupt_status != 0 ) {
+        /* save current ILR */
+        uint32_t interrupt_levels = intc->ilr;
+        /* set ILR to block out every interrupt less than or equal to priority of i */
+        intc->ilr = 0xFFFFFFFF >> (32 - i);
+        bsp_interrupt_handler_dispatch( i );
+        ack_interrupt( i );
+        /* restore ILR */
+        intc->ilr = interrupt_levels;
+        break;
+  } else {
+    vector_number = source;
+    /* Fast interrupt mode. Handle interrupt. Ack happens automatically */
+    bsp_interrupt_handler_dispatch( vector_number );
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S b/bsps/microblaze/microblaze_fpga/start/_exception_handler.S
similarity index 88%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S
rename to bsps/microblaze/microblaze_fpga/start/_exception_handler.S
index 2224c924f7..a93d31e188 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_exception_handler.S
+++ b/bsps/microblaze/microblaze_fpga/start/_exception_handler.S
@@ -1,3 +1,5 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
 /* Copyright (c) 2001, 2009 Xilinx, Inc.  All rights reserved.
@@ -34,5 +36,17 @@
 	.align 2
 	_exception_handler:
+#ifndef __rtems__
 	rtsd    r17, 0
 	nop
+#else /* __rtems__ */
+	/* Subtract stack frame */
+	addik r1, r1, -52
+	swi r5, r1, 8
+	addi r5, r0, 0xFFFF
+	braid _ISR_Handler
+	nop
diff --git a/c/src/lib/libbsp/microblaze/gdbmbsim/startup/_hw_exception_handler.S b/bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S
similarity index 87%
rename from c/src/lib/libbsp/microblaze/gdbmbsim/startup/_hw_exception_handler.S
rename to bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S
index bb729ca33b..5380a04264 100644
--- a/c/src/lib/libbsp/microblaze/gdbmbsim/startup/_hw_exception_handler.S
+++ b/bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S
@@ -1,3 +1,5 @@
@@ -34,5 +36,17 @@
 	.align 2
 	_hw_exception_handler:
-	rted    r17, 0
+#ifndef __rtems__
+	rtsd    r17, 0
+	nop
+	addik r1, r1, -52
+	swi r5, r1, 8
 	nop
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S b/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
similarity index 86%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S
rename to bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
index 844c7d01bd..bd29cf410f 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/_interrupt_handler.S
+++ b/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
@@ -1,3 +1,5 @@
@@ -34,5 +36,18 @@
 	.align 2
 	_interrupt_handler:
+#ifndef __rtems__
 	rtid    r14, 0
 	nop
+	addik r1, r1, -52
+	swi r5, r1, 8
+	/* Indicate unknown interrupt source */
+	addi r5, r0, 0xFF
+	nop
diff --git a/bsps/microblaze/microblaze_fpga/start/bspreset.c b/bsps/microblaze/microblaze_fpga/start/bspreset.c
index 0000000000..6a7455f522
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/bspreset.c
@@ -0,0 +1,44 @@
+ * @file
+ * @brief BSP Reset
+ * are met:
+#include <rtems.h>
+#include <bsp/bootcard.h>
+void bsp_reset( void )
+  __asm__ volatile (
+    "brai 0xFFFFFFFFFFFFFFFF"
diff --git a/bsps/microblaze/microblaze_fpga/start/bspstart.c b/bsps/microblaze/microblaze_fpga/start/bspstart.c
index 0000000000..0caf385b46
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/bspstart.c
@@ -0,0 +1,43 @@
+ * @file
+ * @brief BSP Startup
+ * are met:
+#include <bsp.h>
+void bsp_start( void )
+  bsp_interrupt_initialize();
diff --git a/bsps/microblaze/microblaze_fpga/start/crtinit.S b/bsps/microblaze/microblaze_fpga/start/crtinit.S
index 0000000000..56bce722ee
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/crtinit.S
@@ -0,0 +1,104 @@
+/* Copyright (c) 2001, 2009 Xilinx, Inc.  All rights reserved.
+   Redistribution and use in source and binary forms, with or without
+   modification, are permitted provided that the following conditions are
+   met:
+   1.  Redistributions source code must retain the above copyright notice,
+   this list of conditions and the following disclaimer.
+   2.  Redistributions in binary form must reproduce the above copyright
+   notice, this list of conditions and the following disclaimer in the
+   documentation and/or other materials provided with the distribution.
+   3.  Neither the name of Xilinx nor the names of its contributors may be
+   used to endorse or promote products derived from this software without
+   specific prior written permission.
+   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER AND CONTRIBUTORS "AS
+   IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+   TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+   PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+   HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+   SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+   TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+   PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+   LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+   NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+   SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+	.globl _crtinit
+	.align 2
+	.ent _crtinit
+	.type _crtinit, @function
+_crtinit:
+	addi	r1, r1, -20			   	/* Save Link register	 */
+	swi	r15, r1, 0
+#ifndef __rtems__
+	addi	r6, r0, __sbss_start		  	/* clear SBSS */
+	addi	r7, r0, __sbss_end
+	rsub	r18, r6, r7
+	blei	r18, .Lendsbss
+.Lloopsbss:
+	swi	r0, r6, 0
+	addi	r6, r6, 4
+	rsub	r18, r6, r7
+	bgti	r18, .Lloopsbss
+.Lendsbss:
+#ifndef __rtems__
+	addi	r6, r0, __bss_start			 /* clear BSS */
+	addi	r7, r0, __bss_end
+#else
+	addi  r6, r0, bsp_section_bss_begin
+	addi  r7, r0, bsp_section_bss_end
+	rsub	r18, r6, r7
+	blei	r18, .Lendbss
+.Lloopbss:
+	swi	r0, r6, 0
+	addi	r6, r6, 4
+	rsub	r18, r6, r7
+	bgti	r18, .Lloopbss
+.Lendbss:
+#ifndef __rtems__
+	brlid	r15, _program_init		 	 /* Initialize the program  */
+	nop
+	brlid   r15, __init					 /* Invoke language initialization functions */
+	nop
+	addi	r6, r0, 0					   /* Initialize argc = 1 and argv = NULL and envp = NULL  */
+	addi	r7, r0, 0
+#ifndef __rtems__
+	brlid	r15, main					   /* Execute the program */
+#else
+	brlid	r15, boot_card
+	addi	r5, r0, 0
+	addik   r19, r3, 0					  /* Save return value */
+#ifndef __rtems__
+	brlid   r15, __fini					 /* Invoke language cleanup functions */
+	nop
+	brlid	r15, _program_clean			 /* Cleanup the program  */
+	nop
+	lw r15, r1, r0					 /* Return back to CRT   */
+	addik r3, r19, 0					  /* Restore return value */
+	rtsd r15, 8
+	addi r1, r1, 20
+	.end _crtinit
diff --git a/bsps/microblaze/shared/cache/cache.c b/bsps/microblaze/shared/cache/cache.c
index 0000000000..472f3c04f4
--- /dev/null
+++ b/bsps/microblaze/shared/cache/cache.c
@@ -0,0 +1,36 @@
+ * @file
+ * @brief MicroBlaze cache support
+ * are met:
+#include "../../../bsps/shared/cache/cacheimpl.h"
diff --git a/bsps/microblaze/shared/dev/serial/uartlite.c b/bsps/microblaze/shared/dev/serial/uartlite.c
index 0000000000..7387e22635
--- /dev/null
+++ b/bsps/microblaze/shared/dev/serial/uartlite.c
@@ -0,0 +1,145 @@
+ * @file
+ * @brief MicroBlaze AXI UART Lite support
+ * are met:
+#include <bsp/irq.h>
+static void microblaze_uart_interrupt( void *arg )
+  rtems_termios_tty *tty = arg;
+  uart_lite_context *ctx = rtems_termios_get_device_context( tty );
+  while ( !XUartLite_IsReceiveEmpty( ctx->address ) ) {
+    char c = (char) XUartLite_ReadReg( ctx->address, XUL_RX_FIFO_OFFSET );
+    rtems_termios_enqueue_raw_characters( tty, &c, 1 );
+  while ( ctx->transmitting && !XUartLite_IsTransmitEmpty( ctx ) ) {
+    rtems_termios_dequeue_characters( tty, 1 );
+#endif
+static bool uart_first_open(
+  struct rtems_termios_tty *tty,
+  rtems_termios_device_context *base,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
+  uart_lite_context *ctx = (uart_lite_context *) base;
+  rtems_status_code sc;
+#endif
+  rtems_termios_set_initial_baud( tty, ctx->initial_baud );
+  XUartLite_EnableIntr( ctx->address );
+    1,
+    "UART",
+    RTEMS_INTERRUPT_SHARED,
+    microblaze_uart_interrupt,
+    tty
+    return false;
+#endif
+  return true;
+static void uart_last_close(
+  rtems_termios_tty *tty,
+  rtems_interrupt_handler_remove( 1, microblaze_uart_interrupt, tty );
+#endif
+#ifndef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
+static int uart_read_polled( rtems_termios_device_context *base )
+  if ( XUartLite_IsReceiveEmpty( ctx->address ) ) {
+    return -1;
+  return XUartLite_ReadReg( ctx->address, XUL_RX_FIFO_OFFSET );
+#endif
+static void uart_write(
+  const char *s,
+  size_t n
+  if ( n > 0 ) {
+    ctx->transmitting = true;
+    XUartLite_SendByte( ctx->address, s[0] );
+  } else {
+    ctx->transmitting = false;
+#else
+  size_t i = 0;
+  for ( i = 0; i < n; ++i ) {
+    XUartLite_SendByte( ctx->address, s[i] );
+#endif
+const rtems_termios_device_handler microblaze_uart_fns = {
+  .first_open = uart_first_open,
+  .last_close = uart_last_close,
+  .write = uart_write,
+  .mode = TERMIOS_IRQ_DRIVEN
+#else
+  .poll_read = uart_read_polled,
+  .mode = TERMIOS_POLLED
+#endif
diff --git a/bsps/microblaze/shared/dev/serial/uartlite_l.c b/bsps/microblaze/shared/dev/serial/uartlite_l.c
index 0000000000..5acbd6c505
--- /dev/null
+++ b/bsps/microblaze/shared/dev/serial/uartlite_l.c
@@ -0,0 +1,99 @@
+* @file xuartlite_l.c
+* This file contains low-level driver functions that can be used to access the
+* device.  The user should refer to the hardware device specification for more
+* details of the device operation.
+* <pre>
+* 1.12a rpm  07/16/07 Fixed arg type for RecvByte
+* 2.00a ktn  10/20/09 The macros have been renamed to remove _m from the name.
+* </pre>
+/***************************** Include Files *********************************/
+#ifndef __rtems__
+#include "xuartlite_l.h"
+#else
+/**************************** Type Definitions *******************************/
+/***************** Macros (Inline Functions) Definitions *********************/
+/************************** Function Prototypes ******************************/
+/************************** Variable Prototypes ******************************/
+* This functions sends a single byte using the UART. It is blocking in that it
+* waits for the transmitter to become non-full before it writes the byte to
+* the transmit register.
+* @param	Data is the byte of data to send
+* @return	None.
+* @note		None.
+	while (XUartLite_IsTransmitFull(BaseAddress));
+	XUartLite_WriteReg(BaseAddress, XUL_TX_FIFO_OFFSET, Data);
+* This functions receives a single byte using the UART. It is blocking in that
+* it waits for the receiver to become non-empty before it reads from the
+* receive register.
+* @return	The byte of data received.
+* @note		None.
+	while (XUartLite_IsReceiveEmpty(BaseAddress));
+	return (u8)XUartLite_ReadReg(BaseAddress, XUL_RX_FIFO_OFFSET);
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S b/bsps/microblaze/shared/start/start.S
similarity index 53%
rename from c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S
rename to bsps/microblaze/shared/start/start.S
index 9a994c33f8..9006402be6 100644
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/start/start.S
+++ b/bsps/microblaze/shared/start/start.S
@@ -1,3 +1,5 @@
@@ -34,76 +36,79 @@
          Address                Vector type                 Label
-    	# 0x00 #		(-- IMM --)
-	# 0x04 #                Reset                       _start1
-	# 0x08 #		(-- IMM --)
-	# 0x0c #		Software Exception          _exception_handler
-	# 0x10 #		(-- IMM --)
-	# 0x14 #		Hardware Interrupt          _interrupt_handler
-        # 0x18 #                (-- IMM --)
-        # 0x1C #                Breakpoint Exception        (-- Don't Care --)
-        # 0x20 #                (-- IMM --)
-        # 0x24 #                Hardware Exception          _hw_exception_handler
+		# 0x00 #				(-- IMM --)
+		# 0x04 #				Reset                       _start1
+		# 0x08 #				(-- IMM --)
+		# 0x0c #				Software Exception          _exception_handler
+		# 0x10 #				(-- IMM --)
+		# 0x14 #				Hardware Interrupt          _interrupt_handler
+		# 0x18 #				(-- IMM --)
+		# 0x1C #				Breakpoint Exception        (-- Don't Care --)
+		# 0x20 #				(-- IMM --)
+		# 0x24 #				Hardware Exception          _hw_exception_handler
 	.globl _start
-        .section .vectors.reset, "ax"
+	.section .vectors.reset, "ax"
 	.align 2
-        .ent _start
-        .type _start, @function
+	.ent _start
+	.type _start, @function
 _start:
-        brai    _start1
-        .end _start
+	brai _start1
+	.end _start
-        .section .vectors.sw_exception, "ax"
-        .align 2
+	.section .vectors.sw_exception, "ax"
+	.align 2
 _vector_sw_exception:
-        brai    _exception_handler
+	brai _exception_handler
-        .section .vectors.interrupt, "ax"
-        .align 2
+	.section .vectors.interrupt, "ax"
+	.align 2
 _vector_interrupt:
-        brai    _interrupt_handler
+	brai _interrupt_handler
-        .section .vectors.hw_exception, "ax"
-        .align 2
+	.section .vectors.hw_exception, "ax"
+	.align 2
 _vector_hw_exception:
-        brai    _hw_exception_handler
+	brai _hw_exception_handler
-        .section .text
-        .globl _start1
-        .align 2
-        .ent _start1
-        .type _start1, @function
+	.section .text
+	.globl _start1
+	.align 2
+	.ent _start1
+	.type _start1, @function
 _start1:
-	//la	r13, r0, _SDA_BASE_         /* Set the Small Data Anchors and the stack pointer */
-	//la	r2, r0, _SDA2_BASE_
-	la	r1, r0, bsp_section_stack_begin-16           /* 16 bytes (4 words are needed by crtinit for args and link reg */
+	//la r13, r0, _SDA_BASE_         /* Set the Small Data Anchors and the stack pointer */
+	//la r2, r0, _SDA2_BASE_
+	la r1, r0, _ISR_Stack_area_end-16           /* 16 bytes (4 words are needed by crtinit for args and link reg */
-	brlid	r15, _crtinit               /* Initialize BSS and run program */
+	brlid r15, _crtinit               /* Initialize BSS and run program */
 	nop
-        brlid   r15, exit                   /* Call exit with the return value of main */
-        addik   r5, r3, 0
+#ifndef __rtems__
+	brlid   r15, exit                   /* Call exit with the return value of main */
+	addik   r5, r3, 0
-        /* Control does not reach here */
-        .end _start1
+	/* Control does not reach here */
+	.end _start1
+#ifndef __rtems__
-        _exit
-        Our simple _exit
+	_exit
+	Our simple _exit
-        .globl _exit
-        .align 2
-        .ent _exit
-        .type _exit, @function
+	.globl _exit
+	.align 2
+	.ent _exit
+	.type _exit, @function
 _exit:
-        bri     0
-	.end _exit
+	bri     0
+	.end _exit
diff --git a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S b/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
deleted file mode 100644
index 6c88272e9e..0000000000
--- a/c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S
+++ /dev/null
@@ -1,86 +0,0 @@
-## Copyright (c) 2015, Hesham Almatary
-## Copyright (c) 2001, 2009 Xilinx, Inc.  All rights reserved.
-## Redistribution and use in source and binary forms, with or without
-## modification, are permitted provided that the following conditions are
-## met:
-## 1.  Redistributions source code must retain the above copyright notice,
-## this list of conditions and the following disclaimer.
-## 2.  Redistributions in binary form must reproduce the above copyright
-## notice, this list of conditions and the following disclaimer in the
-## documentation and/or other materials provided with the distribution.
-## 3.  Neither the name of Xilinx nor the names of its contributors may be
-## used to endorse or promote products derived from this software without
-## specific prior written permission.
-## THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER AND CONTRIBUTORS "AS
-## IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
-## TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
-## PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
-## HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
-## SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
-## TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
-## PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
-## LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
-## NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
-## SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-# sim-crtinit.s
-# Default second stage of C run-time initialization that does not peform
-# BSS initialization to zero. Typical use is on a simulator.
-	.globl _crtinit
-	.align 2
-	.ent _crtinit
-_crtinit:
-	addi	r1, r1, -20               	/* Save Link register	 */
-	swi	r15, r1, 0
-#ifndef __rtems__
-    	brlid	r15, _program_init              /* Initialize the program  */
-	nop
-        brlid   r15, __init                     /* Invoke language initialization functions */
-        nop
-#endif
-  /* Init .bss */
-  addi  r6, r0, bsp_section_bss_begin
-  addi  r7, r0, bsp_section_bss_end
-_clear_bss_loop:
-  swi   r0, r6, 0
-  addi  r6, r6, 4
-  cmpu  r8, r6, r7
-  bgti  r8, _clear_bss_loop
-	addi	r6, r0, 0                       /* Initialize argc = 1 and argv = NULL and envp = NULL  */
-	addi	r7, r0, 0
-      	brlid	r15, boot_card                  /* Execute the program */
-	addi	r5, r0, 0
-        addik   r19, r3, 0                      /* Save return value */
-#ifndef __rtems__
-        brlid   r15, __fini                     /* Invoke language cleanup functions */
-        nop
-	brlid	r15, _program_clean             /* Cleanup the program  */
-	nop
-#endif
-	lw	r15, r1, r0                     /* Return back to CRT   */
-        addik   r3, r19, 0                      /* Restore return value */
-	rtsd	r15, 8
-    	addi	r1, r1, 20
-	.end _crtinit
diff --git a/cpukit/score/cpu/microblaze/__tls_get_addr.c b/cpukit/score/cpu/microblaze/__tls_get_addr.c
index 0000000000..e779a63488
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/__tls_get_addr.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSScoreCPUMicroBlaze
+ * @brief MicroBlaze thread-local storage implementation
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/tls.h>
+#include <assert.h>
+void *__tls_get_addr( const TLS_Index *ti );
+  const Thread_Control *executing = _Thread_Get_executing();
+  void *tls_block = (char *) executing->Start.tls_area
+    + _TLS_Get_thread_control_block_area_size( (uintptr_t) _TLS_Alignment );
+  return (char *) tls_block + ti->offset;
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index ca4a3ec2f6..de8fbfbba1 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -1,7 +1,16 @@
+ * @file
+ * @brief MicroBlaze architecture support implementation
- *  Copyright (c) 2015, Hesham Almatary
+ * Copyright (c) 2015, Hesham Almatary
@@ -9,8 +18,8 @@
@@ -29,31 +38,12 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
 #include <rtems/score/isr.h>
-/*  _CPU_Initialize
- *  This routine performs processor dependent initialization.
- *  INPUT PARAMETERS: NONE
- *  NO_CPU Specific Information:
- *  XXX document implementation including references if appropriate
-void _CPU_Initialize(void)
+void _CPU_Initialize( void )
-   *  If there is not an easy way to initialize the FP context
-   *  during Context_Initialize, then it is usually easier to
-   *  save an "uninitialized" FP context here and copy it to
-   *  the task's during Context_Initialize.
-  /* FP context initialization support goes here */
 void _CPU_Context_Initialize(
@@ -66,136 +56,66 @@ void _CPU_Context_Initialize(
   void *tls_area
-  uint32_t stack = ((uint32_t) stack_area_begin);
+  uint32_t stack = (uint32_t) stack_area_begin;
   uint32_t stack_high = stack + stack_area_size;
-  memset(context, 0, sizeof(*context));
+  memset( context, 0, sizeof(*context) ) ;
-  context->r[0] = stack_high;
-  context->r[3] = (uint32_t) entry_point;
-/*PAGE
- *  _CPU_ISR_Get_level
+  context->r1 = stack_high - 64;
+  context->r15 = (uint32_t) entry_point;
-uint32_t   _CPU_ISR_Get_level( void )
-   *  This routine returns the current interrupt level.
+  uint32_t msr;
+  _CPU_MSR_GET( msr );
+  context->rmsr = msr;
-  return 0;
+  if ( tls_area != NULL ) {
+    _TLS_TCB_at_area_begin_initialize( tls_area );
-/*PAGE
- *  _CPU_ISR_install_raw_handler
-void _CPU_ISR_install_raw_handler(
-  uint32_t    vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
+void _CPU_Exception_frame_print( const CPU_Exception_frame *ctx )
-   *  This is where we install the interrupt handler into the "raw" interrupt
-   *  table used by the CPU to dispatch interrupt handlers.
-/*PAGE
- *  _CPU_ISR_install_vector
- *  This kernel routine installs the RTEMS handler for the
- *  specified vector.
- *  Input parameters:
- *    vector      - interrupt vector number
- *    old_handler - former ISR for this vector number
- *    new_handler - replacement ISR for this vector number
- *  Output parameters:  NONE
-void _CPU_ISR_install_vector(
-  uint32_t    vector,
+void _CPU_ISR_Set_level( uint32_t level )
-   *old_handler = _ISR_Vector_table[ vector ];
+  uint32_t microblaze_switch_reg;
-    *  If the interrupt vector table is a table of pointer to isr entry
-    *  points, then we need to install the appropriate RTEMS interrupt
-    *  handler for this vector number.
+  _CPU_MSR_GET( microblaze_switch_reg );
-   _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
+  if ( level == 0 ) {
+    microblaze_switch_reg |= (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE);
+  } else {
+    microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE);
-    *  We put the actual user ISR address in '_ISR_vector_table'.  This will
-    *  be used by the _ISR_Handler so the user gets control.
-    _ISR_Vector_table[ vector ] = new_handler;
+  _CPU_MSR_SET( microblaze_switch_reg );
-/*PAGE
- *  _CPU_Install_interrupt_stack
-void _CPU_Install_interrupt_stack( void )
+uint32_t _CPU_ISR_Get_level( void )
+  uint32_t level;
+  _CPU_MSR_GET( level );
+  /* This is unique. The MSR register contains an interrupt enable flag where
+   * most other architectures have an interrupt disable flag. */
+  return ( level & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE) ) == 0;
-/*PAGE
- *  _CPU_Thread_Idle_body
- *  NOTES:
- *  1. This is the same as the regular CPU independent algorithm.
- *  2. If you implement this using a "halt", "idle", or "shutdown"
- *     instruction, then don't forget to put it in an infinite loop.
- *  3. Be warned. Some processors with onboard DMA have been known
- *     to stop the DMA if the CPU were put in IDLE mode.  This might
- *     also be a problem with other on-chip peripherals.  So use this
- *     hook with caution.
+void _CPU_ISR_install_vector(
+  uint32_t         vector,
+  CPU_ISR_handler  new_handler,
+  CPU_ISR_handler *old_handler
+  *old_handler = _ISR_Vector_table[ vector ];
+  _ISR_Vector_table[ vector ] = new_handler;
 void *_CPU_Thread_Idle_body( uintptr_t ignored )
-  for( ; ; )
-    /* insert your "halt" instruction here */ ;
-  return NULL;
+  while ( true ) {
+    __asm__ volatile ( "sleep" );
diff --git a/cpukit/score/cpu/microblaze/cpu_asm.S b/cpukit/score/cpu/microblaze/cpu_asm.S
index 0000000000..05f33a2ed8
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/cpu_asm.S
@@ -0,0 +1,194 @@
+ * @file
+ * @brief MicroBlaze interrupt handler implementation
+ * are met:
+#include <rtems/asm.h>
+#include <rtems/score/percpu.h>
+	.text
+	.globl _ISR_Handler
+	.align 2
+_ISR_Handler:
+	/* Save stack frame */
+	swi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
+	swi  r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
+	swi  r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
+	swi  r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
+	swi  r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
+	swi  r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
+	swi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
+	swi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
+	swi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
+	swi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
+	swi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
+	xori r3, r5, 0xFFFF
+	beqi r3, do_exception
+	/* Disable dispatching */
+	lwi r3, r0, _Per_CPU_Information + 16
+	addik r3, r3, 1
+	swi r3, r0, _Per_CPU_Information + 16
+	swi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
+	/* Is SP < INTERRUPT_STACK_LOW? */
+	lwi r4, r0, _Per_CPU_Information
+	rsubk r3, r4, r1
+	blei r3, switch_to_interrupt_stack
+	/* Is SP > INTERRUPT_STACK_HIGH? */
+	lwi r4, r0, _Per_CPU_Information + 4
+	rsubk r3, r4, r1
+	bgei r3, switch_to_interrupt_stack
+	bri on_interrupt_stack
+switch_to_interrupt_stack:
+	add r4, r0, r1
+	lwi r1, r0, _Per_CPU_Information + 4
+	addik r1, r1, -52
+	swi r4, r1, 0
+on_interrupt_stack:
+	/* Add 1 to ISR_NEST_LEVEL */
+	lwi r3, r0, _Per_CPU_Information + 8
+	addik r3, r3, 1
+	swi r3, r0, _Per_CPU_Information + 8
+	bralid r15, bsp_interrupt_dispatch
+	nop
+	/* Subtract 1 from ISR_NEST_LEVEL */
+	addik r3, r3, -1
+	/* Is ISR_NEST_LEVEL > 0? */
+	bgti r3, after_stack_switch
+	/* Switch back to interrupted thread stack */
+	lwi r1, r1, 0
+after_stack_switch:
+	/* Subtract 1 from THREAD_DISPATCH_DISABLE_LEVEL */
+	addik r3, r3, -1
+	/* Is THREAD_DISPATCH_DISABLE_LEVEL != 0? */
+	bnei r3, quick_exit
+	/* Is DISPATCH_NEEDED == 0? */
+	lwi r3, r0, _Per_CPU_Information + 20
+	beqi r3, quick_exit
+	/* Return to interrupted thread and make it do a dispatch */
+	addik r14, r0, thread_dispatch
+	rtid r14, 0
+	nop
+quick_exit:
+	/* Simple return from nested interrupt */
+	/* Restore registers */
+	lwi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
+	lwi  r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
+	lwi  r5, r1, MICROBLAZE_INTERRUPT_FRAME_R5
+	lwi  r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
+	lwi  r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
+	lwi  r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
+	lwi  r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
+	lwi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
+	lwi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
+	lwi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
+	lwi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
+	lwi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
+	lwi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
+	/* Remove stack frame */
+	addik r1, r1, 52
+	rtid r14, 0
+	nop
+thread_dispatch:
+	/* Reserve stack */
+	addik r1, r1, -52
+	/* Save scratch registers */
+	swi  r5, r1, MICROBLAZE_INTERRUPT_FRAME_R5
+	bralid r15, _Thread_Dispatch
+	nop
+	/* Restore scratch registers */
+	/* Free stack space */
+	addik r1, r1, 52
+	bri quick_exit
+do_exception:
+	/* exception no longer in progress */
+	mfs r3, rmsr
+	andni r3, r3, 0x200
+	mts rmsr, r3
+	addi r5, r0, 9
+	add r6, r0, r1
+	brai _Terminate
diff --git a/cpukit/score/cpu/microblaze/rtems/asm.h b/cpukit/score/cpu/microblaze/include/rtems/asm.h
similarity index 61%
rename from cpukit/score/cpu/microblaze/rtems/asm.h
rename to cpukit/score/cpu/microblaze/include/rtems/asm.h
index b5a8702f02..be9611bd30 100644
--- a/cpukit/score/cpu/microblaze/rtems/asm.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/asm.h
@@ -1,29 +1,41 @@
- * @file rtems/asm.h
+ * @file
- *  This include file attempts to address the problems
- *  caused by incompatible flavors of assemblers and
- *  toolsets.  It primarily addresses variations in the
- *  use of leading underscores on symbols and the requirement
- *  that register names be preceded by a %.
+ * @brief MicroBlaze assembler support
+ * This include file attempts to address the problems
+ * caused by incompatible flavors of assemblers and
+ * toolsets.  It primarily addresses variations in the
+ * use of leading underscores on symbols and the requirement
+ * that register names be preceded by a %.
- *  NOTE: The spacing in the use of these macros
- *        is critical to them working as advertised.
- *  COPYRIGHT:
- *  This file is based on similar code found in newlib available
- *  from ftp.cygnus.com.  The file which was used had no copyright
- *  notice.  This file is freely distributable as long as the source
- *  of the file is noted.  This file is:
+ * are met:
- *  COPYRIGHT (c) 1994-2006.
- *  $Id: asm.h,v 1.16 2006/01/16 15:12:12 joel Exp $
 #ifndef _RTEMS_ASM_H
@@ -36,6 +48,7 @@
 #ifndef ASM
 #define ASM
 #endif
 #ifndef __USER_LABEL_PREFIX__
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
index 0000000000..4b11625463
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
@@ -0,0 +1,305 @@
+ * @file
+ * are met:
+#ifndef _RTEMS_SCORE_CPU_H
+#define _RTEMS_SCORE_CPU_H
+#include <rtems/score/basedefs.h>
+#include <rtems/score/microblaze.h>
+#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
+#define CPU_ISR_PASSES_FRAME_POINTER FALSE
+#define CPU_HARDWARE_FP FALSE
+#define CPU_SOFTWARE_FP FALSE
+#define CPU_ALL_TASKS_ARE_FP FALSE
+#define CPU_IDLE_TASK_IS_FP FALSE
+#define CPU_USE_DEFERRED_FP_SWITCH FALSE
+#define CPU_STACK_GROWS_UP FALSE
+ * The maximum cache-line size is 16 words.
+#define CPU_CACHE_LINE_BYTES 64
+#define CPU_STRUCTURE_ALIGNMENT
+#define CPU_MODES_INTERRUPT_MASK 0x00000001
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  @ingroup CPUContext Management
+ *  This defines the minimal set of integer and processor state registers
+ *  that must be saved during a voluntary context switch from one thread
+ *  to another.
+typedef struct {
+  uint32_t r1;
+  uint32_t r13;
+  uint32_t r14;
+  uint32_t r15;
+  uint32_t r16;
+  uint32_t r17;
+  uint32_t r18;
+  uint32_t r19;
+  uint32_t r20;
+  uint32_t r21;
+  uint32_t r22;
+  uint32_t r23;
+  uint32_t r24;
+  uint32_t r25;
+  uint32_t r26;
+  uint32_t r27;
+  uint32_t r28;
+  uint32_t r29;
+  uint32_t r30;
+  uint32_t r31;
+  uint32_t rmsr;
+} Context_Control;
+ *  This macro returns the stack pointer associated with @a _context.
+ *  @param[in] _context is the thread context area to access
+ *  @return This method returns the stack pointer.
+#define _CPU_Context_Get_SP( _context ) \
+  (_context)->r1
+#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
+#define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
+#define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
+#define CPU_MAXIMUM_PROCESSORS 32
+ *  @ingroup CPUInterrupt
+ *  This defines the highest interrupt vector number for this port.
+#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
+#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
+#define CPU_STACK_MINIMUM_SIZE (1024*4)
+#define CPU_ALIGNMENT 4
+#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
+#define CPU_STACK_ALIGNMENT        CPU_ALIGNMENT
+#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
+#define MICROBLAZE_MSR_IE (1 << 1)
+#define MICROBLAZE_MSR_EE (1 << 8)
+#define _CPU_MSR_GET( _msr_value ) \
+  do { \
+    (_msr_value) = 0; \
+    __asm__ volatile ("mfs %0, rmsr" : "=&r" ((_msr_value)) : "0" ((_msr_value))); \
+  } while (0)
+#define _CPU_MSR_SET( _msr_value ) \
+{ __asm__ volatile ("mts rmsr, %0" : "=&r" ((_msr_value)) : "0" ((_msr_value))); }
+#define _CPU_ISR_Disable( _isr_cookie ) \
+    unsigned int _new_msr;  \
+    _CPU_MSR_GET(_isr_cookie); \
+    _new_msr = (_isr_cookie) & ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _CPU_MSR_SET(_new_msr); \
+#define _CPU_ISR_Enable( _isr_cookie )  \
+    uint32_t _microblaze_interrupt_enable; \
+    uint32_t _microblaze_switch_reg; \
+    _microblaze_interrupt_enable = (_isr_cookie) & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _CPU_MSR_GET(_microblaze_switch_reg); \
+    _microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _microblaze_switch_reg |= _microblaze_interrupt_enable; \
+    _CPU_MSR_SET(_microblaze_switch_reg); \
+#define _CPU_ISR_Flash( _isr_cookie ) \
+    _CPU_MSR_SET(_isr_cookie); \
+void _CPU_ISR_Set_level( uint32_t level );
+uint32_t _CPU_ISR_Get_level( void );
+RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
+  return ( level & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE) ) != 0;
+void _CPU_Context_Initialize(
+  Context_Control *context,
+  void *stack_area_begin,
+  size_t stack_area_size,
+  uint32_t new_level,
+  void (*entry_point)( void ),
+  bool is_fp,
+  void *tls_area
+#define _CPU_Context_Restart_self( _the_context ) \
+   _CPU_Context_restore( (_the_context) );
+#define _CPU_Context_Initialize_fp( _destination ) \
+   *(*(_destination)) = _CPU_Null_fp_context; \
+/* end of Context handler macros */
+/* Fatal Error manager macros */
+/* TODO */
+#define _CPU_Fatal_halt(_source, _error ) \
+        do { \
+          __asm__ volatile ( "sleep" ); \
+          for(;;) {} \
+        } while (0)
+/* end of Fatal Error manager macros */
+/* Bitfield handler macros */
+#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#define CPU_SIZEOF_POINTER 4
+#define CPU_PER_CPU_CONTROL_SIZE 0
+typedef struct {
+  /* TODO: enumerate registers */
+  uint32_t r[32];
+} CPU_Exception_frame;
+/* end of Priority handler macros */
+/* functions */
+void _CPU_Initialize( void );
+typedef void ( *CPU_ISR_handler )( uint32_t );
+  uint32_t         vector,
+void _CPU_Context_switch(
+  Context_Control  *run,
+  Context_Control  *heir
+RTEMS_NO_RETURN void _CPU_Context_restore(
+  Context_Control *new_context
+static inline uint32_t CPU_swap_u32(
+  uint32_t value
+  uint32_t byte1, byte2, byte3, byte4, swapped;
+  byte4 = (value >> 24) & 0xff;
+  byte3 = (value >> 16) & 0xff;
+  byte2 = (value >> 8)  & 0xff;
+  byte1 =  value        & 0xff;
+  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
+  return swapped;
+#define CPU_swap_u16( value ) \
+  (((value&0xff) << 8) | ((value >> 8)&0xff))
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+typedef uint32_t CPU_Counter_ticks;
+uint32_t _CPU_Counter_frequency( void );
+CPU_Counter_ticks _CPU_Counter_read( void );
+static inline CPU_Counter_ticks _CPU_Counter_difference(
+  CPU_Counter_ticks second,
+  CPU_Counter_ticks first
+  return second - first;
+void *_CPU_Thread_Idle_body( uintptr_t ignored );
+void bsp_interrupt_dispatch( uint32_t source );
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPU_H */
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
index 0000000000..6dc769b95a
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
@@ -0,0 +1,41 @@
+ * @file
+ * @brief MicroBlaze atomic support
+ * are met:
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/cpustdatomic.h>
+#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
new file mode 100644
index 0000000000..3d0167dd40
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
@@ -0,0 +1,96 @@
+ * @file
+ * @brief CPU Port Implementation API
+ * are met:
+#ifndef _RTEMS_SCORE_CPUIMPL_H
+#define _RTEMS_SCORE_CPUIMPL_H
+ * @defgroup RTEMSScoreCPUMicroBlaze MicroBlaze
+ * @brief MicroBlaze Architecture Support
+#define CPU_INTERRUPT_FRAME_SIZE 52
+#define MICROBLAZE_INTERRUPT_FRAME_R3   0
+#define MICROBLAZE_INTERRUPT_FRAME_R4   4
+#define MICROBLAZE_INTERRUPT_FRAME_R5   8
+#define MICROBLAZE_INTERRUPT_FRAME_R6  12
+#define MICROBLAZE_INTERRUPT_FRAME_R7  16
+#define MICROBLAZE_INTERRUPT_FRAME_R8  20
+#define MICROBLAZE_INTERRUPT_FRAME_R9  24
+#define MICROBLAZE_INTERRUPT_FRAME_R10 28
+#define MICROBLAZE_INTERRUPT_FRAME_R11 32
+#define MICROBLAZE_INTERRUPT_FRAME_R12 36
+#define MICROBLAZE_INTERRUPT_FRAME_R14 40
+#define MICROBLAZE_INTERRUPT_FRAME_R15 44
+#define MICROBLAZE_INTERRUPT_FRAME_R18 48
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+void _CPU_Context_volatile_clobber( uintptr_t pattern );
+void _CPU_Context_validate( uintptr_t pattern );
+RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal( void )
+  __asm__ volatile ( ".word 0x0" );
+RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
+  __asm__ volatile ( "nop" );
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/microblaze/rtems/score/microblaze.h b/cpukit/score/cpu/microblaze/include/rtems/score/microblaze.h
similarity index 50%
rename from cpukit/score/cpu/microblaze/rtems/score/microblaze.h
rename to cpukit/score/cpu/microblaze/include/rtems/score/microblaze.h
index df521f1bd7..6310b4b17d 100644
--- a/cpukit/score/cpu/microblaze/rtems/score/microblaze.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/microblaze.h
@@ -1,7 +1,16 @@
+ * @file
- *  COPYRIGHT (c) 1989-2008.
@@ -9,8 +18,8 @@
- *   notice, this list of conditions and the following disclaimer in the
- *   documentation and/or other materials provided with the distribution.
@@ -25,58 +34,15 @@
- *  This file sets up basic CPU dependency settings based on
- *  compiler settings.  For example, it can determine if
- *  floating point is available.  This particular implementation
- *  is specified to the NO CPU port.
- *  $Id: no_cpu.h,v 1.9 2009/12/02 09:48:25 ralf Exp $
-#ifndef _RTEMS_SCORE_NO_CPU_H
-#define _RTEMS_SCORE_NO_CPU_H
+#ifndef _RTEMS_SCORE_MICROBLAZE_H
+#define _RTEMS_SCORE_MICROBLAZE_H
 #ifdef __cplusplus
 extern "C" {
 #endif
- *  This file contains the information required to build
- *  RTEMS for a particular member of the NO CPU family.
- *  It does this by setting variables to indicate which
- *  implementation dependent features are present in a particular
- *  member of the family.
- *  This is a good place to list all the known CPU models
- *  that this port supports and which RTEMS CPU model they correspond
- *  to.
-#if defined(rtems_multilib)
- *  Figure out all CPU Model Feature Flags based upon compiler
- *  predefines.
-#define CPU_MODEL_NAME  "rtems_multilib"
-#define NOCPU_HAS_FPU     1
-#else
-/* if defined(__MICROBLAZE__) */
 #define CPU_MODEL_NAME  "MicroBlaze"
-#else
-#error "Unsupported CPU Model"
-#endif
+#define NOCPU_HAS_FPU   1
  *  Define the name of the CPU family.
@@ -88,4 +54,4 @@ extern "C" {
 #endif
-#endif /* _RTEMS_SCORE_NO_CPU_H */
+#endif /* _RTEMS_SCORE_MICROBLAZE_H */
diff --git a/cpukit/score/cpu/microblaze/microblaze-context-switch.S b/cpukit/score/cpu/microblaze/microblaze-context-switch.S
index c033fb1f5e..1f591e007e 100644
--- a/cpukit/score/cpu/microblaze/microblaze-context-switch.S
+++ b/cpukit/score/cpu/microblaze/microblaze-context-switch.S
@@ -1,5 +1,16 @@
+ * @file
+ * @brief MicroBlaze context switch implementation
@@ -7,8 +18,8 @@
@@ -58,8 +69,12 @@ SYM(_CPU_Context_switch):
     swi     r29, r5, 68
     swi     r30, r5, 72
     swi     r31, r5, 76
+    mfs     r21, rmsr
+    swi     r21, r5, 80
-SYM(restore):
+SYM(restore):
     lwi     r1,  r6, 0
     lwi     r13, r6, 4
     lwi     r14, r6, 8
@@ -79,11 +94,14 @@ SYM(restore):
     lwi     r28, r6, 64
     lwi     r29, r6, 68
     lwi     r30, r6, 72
-    lwi     r31, r6, 76
+    lwi     r31, r6, 80
+    mts     rmsr, r31
+    lwi     r31, r6, 76
     rtsd    r15, 8
 SYM(_CPU_Context_restore):
     add   r6, r5, r0
     brai  restore
diff --git a/cpukit/score/cpu/microblaze/microblaze-context-validate.S b/cpukit/score/cpu/microblaze/microblaze-context-validate.S
index 0000000000..b12d5930f6
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/microblaze-context-validate.S
@@ -0,0 +1,117 @@
+  #include "config.h"
+#endif
+#define FRAME_OFFSET_R19 0
+#define FRAME_OFFSET_R20 4
+#define FRAME_OFFSET_R21 8
+#define FRAME_OFFSET_R22 12
+#define FRAME_OFFSET_R23 16
+#define FRAME_OFFSET_R24 20
+#define FRAME_OFFSET_R25 24
+#define FRAME_OFFSET_R26 28
+#define FRAME_OFFSET_R27 32
+#define FRAME_OFFSET_R28 36
+#define FRAME_OFFSET_R29 40
+#define FRAME_OFFSET_R30 44
+#define FRAME_OFFSET_R31 48
+#define FRAME_SIZE (FRAME_OFFSET_R31 + 4)
+.text
+.align 4
+PUBLIC(_CPU_Context_validate)
+SYM(_CPU_Context_validate):
+	/* Save */
+	addik r1, r1, -FRAME_SIZE
+	swi r19, r1, FRAME_OFFSET_R19
+	swi r20, r1, FRAME_OFFSET_R20
+	swi r21, r1, FRAME_OFFSET_R21
+	swi r22, r1, FRAME_OFFSET_R22
+	swi r23, r1, FRAME_OFFSET_R23
+	swi r24, r1, FRAME_OFFSET_R24
+	swi r25, r1, FRAME_OFFSET_R25
+	swi r26, r1, FRAME_OFFSET_R26
+	swi r27, r1, FRAME_OFFSET_R27
+	swi r28, r1, FRAME_OFFSET_R28
+	swi r29, r1, FRAME_OFFSET_R29
+	swi r30, r1, FRAME_OFFSET_R30
+	swi r31, r1, FRAME_OFFSET_R31
+	/* Fill */
+	add r4, r0, r3
+	/* r7 contains the stack pointer */
+	add r7, r0, r1
+.macro fill_register reg
+	addi r4, r4, 1
+	add \reg, r0, r4
+.endm
+	fill_register r21
+	fill_register r22
+	fill_register r23
+	fill_register r24
+	fill_register r25
+	fill_register r26
+	fill_register r27
+	fill_register r28
+	fill_register r29
+	fill_register r30
+	fill_register r31
+	/* Check */
+check:
+.macro check_register reg
+	addi r4, r4, 1
+	cmp r6, \reg, r4
+	bnei r6, restore
+.endm
+	cmp r6, r7, r1
+	bnei r6, restore
+	add r4, r0, r3
+	check_register r21
+	check_register r22
+	check_register r23
+	check_register r24
+	check_register r25
+	check_register r26
+	check_register r27
+	check_register r28
+	check_register r29
+	check_register r30
+	check_register r31
+	brai check
+	/* Restore */
+restore:
+	lwi r19, r1, FRAME_OFFSET_R19
+	lwi r20, r1, FRAME_OFFSET_R20
+	lwi r21, r1, FRAME_OFFSET_R21
+	lwi r22, r1, FRAME_OFFSET_R22
+	lwi r23, r1, FRAME_OFFSET_R23
+	lwi r24, r1, FRAME_OFFSET_R24
+	lwi r25, r1, FRAME_OFFSET_R25
+	lwi r26, r1, FRAME_OFFSET_R26
+	lwi r27, r1, FRAME_OFFSET_R27
+	lwi r28, r1, FRAME_OFFSET_R28
+	lwi r29, r1, FRAME_OFFSET_R29
+	lwi r30, r1, FRAME_OFFSET_R30
+	lwi r31, r1, FRAME_OFFSET_R31
+	addik r1, r1, FRAME_SIZE
+	bra r15
diff --git a/cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S b/cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S
index 0000000000..fb49dc5e40
--- /dev/null
+++ b/cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S
@@ -0,0 +1,28 @@
+#endif
+.text
+.align 4
+PUBLIC(_CPU_Context_volatile_clobber)
+SYM(_CPU_Context_volatile_clobber):
+.macro clobber_register reg
+	addi r5, r5, -1
+	add \reg, r0, r5
+.endm
+	clobber_register r3
+	clobber_register r4
+	clobber_register r6
+	clobber_register r7
+	clobber_register r8
+	clobber_register r9
+	clobber_register r10
+	rtsd	r15, 8
+	nop
diff --git a/cpukit/score/cpu/microblaze/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/rtems/score/cpu.h
index d9f9e8add5..0000000000
--- a/cpukit/score/cpu/microblaze/rtems/score/cpu.h
+++ /dev/null
@@ -1,1280 +0,0 @@
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
- * @file rtems/score/cpu.h
- *  This include file contains information pertaining to the XXX
- *  processor.
- *  @note This file is part of a porting template that is intended
- *  to be used as the starting point when porting RTEMS to a new
- *  CPU family.  The following needs to be done when using this as
- *  the starting point for a new port:
- *  + Anywhere there is an XXX, it should be replaced
- *    with information about the CPU family being ported to.
- *  + At the end of each comment section, there is a heading which
- *    says "Port Specific Information:".  When porting to RTEMS,
- *    add CPU family specific information in this section
-#ifndef _RTEMS_SCORE_CPU_H
-#define _RTEMS_SCORE_CPU_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <rtems/score/types.h>
-#include <rtems/score/microblaze.h>
-/* conditional compilation parameters */
- *  Should the calls to @ref _Thread_Enable_dispatch be inlined?
- *  If TRUE, then they are inlined.
- *  If FALSE, then a subroutine call is made.
- *  This conditional is an example of the classic trade-off of size
- *  versus speed.  Inlining the call (TRUE) typically increases the
- *  size of RTEMS while speeding up the enabling of dispatching.
- *  @note In general, the @ref _Thread_Dispatch_disable_level will
- *  only be 0 or 1 unless you are in an interrupt handler and that
- *  interrupt handler invokes the executive.]  When not inlined
- *  something calls @ref _Thread_Enable_dispatch which in turns calls
- *  @ref _Thread_Dispatch.  If the enable dispatch is inlined, then
- *  one subroutine call is avoided entirely.
- *  Port Specific Information:
-#define CPU_INLINE_ENABLE_DISPATCH       FALSE
- *  Should the body of the search loops in _Thread_queue_Enqueue_priority
- *  be unrolled one time?  In unrolled each iteration of the loop examines
- *  two "nodes" on the chain being searched.  Otherwise, only one node
- *  is examined per iteration.
- *  If TRUE, then the loops are unrolled.
- *  If FALSE, then the loops are not unrolled.
- *  The primary factor in making this decision is the cost of disabling
- *  and enabling interrupts (_ISR_Flash) versus the cost of rest of the
- *  body of the loop.  On some CPUs, the flash is more expensive than
- *  one iteration of the loop body.  In this case, it might be desirable
- *  to unroll the loop.  It is important to note that on some CPUs, this
- *  code is the longest interrupt disable period in RTEMS.  So it is
- *  necessary to strike a balance when setting this parameter.
-#define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
- *  Does RTEMS manage a dedicated interrupt stack in software?
- *  If TRUE, then a stack is allocated in @ref _ISR_Handler_initialization.
- *  If FALSE, nothing is done.
- *  If the CPU supports a dedicated interrupt stack in hardware,
- *  then it is generally the responsibility of the BSP to allocate it
- *  and set it up.
- *  If the CPU does not support a dedicated interrupt stack, then
- *  the porter has two options: (1) execute interrupts on the
- *  stack of the interrupted task, and (2) have RTEMS manage a dedicated
- *  interrupt stack.
- *  If this is TRUE, @ref CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
- *  Only one of @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK and
- *  @ref CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
- *  possible that both are FALSE for a particular CPU.  Although it
- *  is unclear what that would imply about the interrupt processing
- *  procedure on that CPU.
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE
- *  Does the CPU follow the simple vectored interrupt model?
- *  If TRUE, then RTEMS allocates the vector table it internally manages.
- *  If FALSE, then the BSP is assumed to allocate and manage the vector
- *  table
-#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
- *  Does this CPU have hardware support for a dedicated interrupt stack?
- *  If TRUE, then it must be installed during initialization.
- *  If FALSE, then no installation is performed.
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK TRUE
- *  Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
- *  If TRUE, then the memory is allocated during initialization.
- *  If FALSE, then the memory is allocated during initialization.
- *  This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
-#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
- *  Does the RTEMS invoke the user's ISR with the vector number and
- *  a pointer to the saved interrupt frame (1) or just the vector
- *  number (0)?
-#define CPU_ISR_PASSES_FRAME_POINTER 0
- *  @def CPU_HARDWARE_FP
- *  Does the CPU have hardware floating point?
- *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
- *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
- *  If there is a FP coprocessor such as the i387 or mc68881, then
- *  the answer is TRUE.
- *  The macro name "NO_CPU_HAS_FPU" should be made CPU specific.
- *  It indicates whether or not this CPU model has FP support.  For
- *  example, it would be possible to have an i386_nofp CPU model
- *  which set this to false to indicate that you have an i386 without
- *  an i387 and wish to leave floating point support out of RTEMS.
- *  @def CPU_SOFTWARE_FP
- *  Does the CPU have no hardware floating point and GCC provides a
- *  software floating point implementation which must be context
- *  switched?
- *  This feature conditional is used to indicate whether or not there
- *  is software implemented floating point that must be context
- *  switched.  The determination of whether or not this applies
- *  is very tool specific and the state saved/restored is also
- *  compiler specific.
-#if ( NO_CPU_HAS_FPU == 1 )
-#define CPU_HARDWARE_FP     TRUE
-#else
-#define CPU_HARDWARE_FP     FALSE
-#endif
-#define CPU_SOFTWARE_FP     FALSE
- *  Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
- *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
- *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
- *  So far, the only CPUs in which this option has been used are the
- *  HP PA-RISC and PowerPC.  On the PA-RISC, The HP C compiler and
- *  gcc both implicitly used the floating point registers to perform
- *  integer multiplies.  Similarly, the PowerPC port of gcc has been
- *  seen to allocate floating point local variables and touch the FPU
- *  even when the flow through a subroutine (like vfprintf()) might
- *  not use floating point formats.
- *  If a function which you would not think utilize the FP unit DOES,
- *  then one can not easily predict which tasks will use the FP hardware.
- *  In this case, this option should be TRUE.
- *  If @ref CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
-#define CPU_ALL_TASKS_ARE_FP     TRUE
- *  Should the IDLE task have a floating point context?
- *  If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
- *  and it has a floating point context which is switched in and out.
- *  If FALSE, then the IDLE task does not have a floating point context.
- *  Setting this to TRUE negatively impacts the time required to preempt
- *  the IDLE task from an interrupt because the floating point context
- *  must be saved as part of the preemption.
-#define CPU_IDLE_TASK_IS_FP      FALSE
- *  Should the saving of the floating point registers be deferred
- *  until a context switch is made to another different floating point
- *  task?
- *  If TRUE, then the floating point context will not be stored until
- *  necessary.  It will remain in the floating point registers and not
- *  disturned until another floating point task is switched to.
- *  If FALSE, then the floating point context is saved when a floating
- *  point task is switched out and restored when the next floating point
- *  task is restored.  The state of the floating point registers between
- *  those two operations is not specified.
- *  If the floating point context does NOT have to be saved as part of
- *  interrupt dispatching, then it should be safe to set this to TRUE.
- *  Setting this flag to TRUE results in using a different algorithm
- *  for deciding when to save and restore the floating point context.
- *  The deferred FP switch algorithm minimizes the number of times
- *  the FP context is saved and restored.  The FP context is not saved
- *  until a context switch is made to another, different FP task.
- *  Thus in a system with only one FP task, the FP context will never
- *  be saved or restored.
-#define CPU_USE_DEFERRED_FP_SWITCH       TRUE
- *  Does this port provide a CPU dependent IDLE task implementation?
- *  If TRUE, then the routine @ref _CPU_Thread_Idle_body
- *  must be provided and is the default IDLE thread body instead of
- *  @ref _CPU_Thread_Idle_body.
- *  If FALSE, then use the generic IDLE thread body if the BSP does
- *  not provide one.
- *  This is intended to allow for supporting processors which have
- *  a low power or idle mode.  When the IDLE thread is executed, then
- *  the CPU can be powered down.
- *  The order of precedence for selecting the IDLE thread body is:
- *    -#  BSP provided
- *    -#  CPU dependent (if provided)
- *    -#  generic (if no BSP and no CPU dependent)
-#define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
- *  Does the stack grow up (toward higher addresses) or down
- *  (toward lower addresses)?
- *  If TRUE, then the grows upward.
- *  If FALSE, then the grows toward smaller addresses.
-#define CPU_STACK_GROWS_UP               TRUE
- *  The following is the variable attribute used to force alignment
- *  of critical RTEMS structures.  On some processors it may make
- *  sense to have these aligned on tighter boundaries than
- *  the minimum requirements of the compiler in order to have as
- *  much of the critical data area as possible in a cache line.
- *  The placement of this macro in the declaration of the variables
- *  is based on the syntactically requirements of the GNU C
- *  "__attribute__" extension.  For example with GNU C, use
- *  the following to force a structures to a 32 byte boundary.
- *      __attribute__ ((aligned (32)))
- *  @note Currently only the Priority Bit Map table uses this feature.
- *        To benefit from using this, the data must be heavily
- *        used so it will stay in the cache and used frequently enough
- *        in the executive to justify turning this on.
-#define CPU_STRUCTURE_ALIGNMENT
- *  @defgroup CPUEndian Processor Dependent Endianness Support
- *  This group assists in issues related to processor endianness.
- *  @ingroup CPUEndian
- *  Define what is required to specify how the network to host conversion
- *  routines are handled.
- *  @note @a CPU_BIG_ENDIAN and @a CPU_LITTLE_ENDIAN should NOT have the
- *  same values.
- *  @see CPU_LITTLE_ENDIAN
-#define CPU_BIG_ENDIAN                           TRUE
- *  @note @ref CPU_BIG_ENDIAN and @ref CPU_LITTLE_ENDIAN should NOT have the
- *  same values.
- *  @see CPU_BIG_ENDIAN
-#define CPU_LITTLE_ENDIAN                        FALSE
- *  @ingroup CPUInterrupt
- *  The following defines the number of bits actually used in the
- *  interrupt field of the task mode.  How those bits map to the
- *  CPU interrupt levels is defined by the routine @ref _CPU_ISR_Set_level.
-#define CPU_MODES_INTERRUPT_MASK   0x00000001
- *  Processor defined structures required for cpukit/score.
-/* may need to put some structures here.  */
- * @defgroup CPUContext Processor Dependent Context Management
- *  From the highest level viewpoint, there are 2 types of context to save.
- *     -# Interrupt registers to save
- *     -# Task level registers to save
- *  Since RTEMS handles integer and floating point contexts separately, this
- *  means we have the following 3 context items:
- *     -# task level context stuff::  Context_Control
- *     -# floating point task stuff:: Context_Control_fp
- *     -# special interrupt level context :: CPU_Interrupt_frame
- *  On some processors, it is cost-effective to save only the callee
- *  preserved registers during a task context switch.  This means
- *  that the ISR code needs to save those registers which do not
- *  persist across function calls.  It is not mandatory to make this
- *  distinctions between the caller/callee saves registers for the
- *  purpose of minimizing context saved during task switch and on interrupts.
- *  If the cost of saving extra registers is minimal, simplicity is the
- *  choice.  Save the same context on interrupt entry as for tasks in
- *  this case.
- *  Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
- *  care should be used in designing the context area.
- *  On some CPUs with hardware floating point support, the Context_Control_fp
- *  structure will not be used or it simply consist of an array of a
- *  fixed number of bytes.   This is done when the floating point context
- *  is dumped by a "FP save context" type instruction and the format
- *  is not really defined by the CPU.  In this case, there is no need
- *  to figure out the exact format -- only the size.  Of course, although
- *  this is enough information for RTEMS, it is probably not enough for
- *  a debugger such as gdb.  But that is another problem.
- *  @ingroup CPUContext Management
- *  This defines the minimal set of integer and processor state registers
- *  that must be saved during a voluntary context switch from one thread
- *  to another.
-typedef struct {
-    uint32_t r[32];
-} Context_Control;
- *  This macro returns the stack pointer associated with @a _context.
- *  @param[in] _context is the thread context area to access
- *  @return This method returns the stack pointer.
-#define _CPU_Context_Get_SP( _context ) \
-  (_context)->r[0]
- *  This defines the complete set of floating point registers that must
- *  be saved during any context switch from one thread to another.
-typedef struct {
-    /** FPU registers are listed here */
-    double      some_float_register;
-} Context_Control_fp;
- *  This defines the set of integer and processor state registers that must
- *  be saved during an interrupt.  This set does not include any which are
- *  in @ref Context_Control.
-typedef struct {
-    /** This field is a hint that a port will have a number of integer
-     *  registers that need to be saved when an interrupt occurs or
-     *  when a context switch occurs at the end of an ISR.
-    uint32_t   special_interrupt_register;
-} CPU_Interrupt_frame;
- *  This variable is optional.  It is used on CPUs on which it is difficult
- *  to generate an "uninitialized" FP context.  It is filled in by
- *  @ref _CPU_Initialize and copied into the task's FP context area during
- *  @ref _CPU_Context_Initialize.
-SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
- *  @defgroup CPUInterrupt Processor Dependent Interrupt Management
- *  On some CPUs, RTEMS supports a software managed interrupt stack.
- *  This stack is allocated by the Interrupt Manager and the switch
- *  is performed in @ref _ISR_Handler.  These variables contain pointers
- *  to the lowest and highest addresses in the chunk of memory allocated
- *  for the interrupt stack.  Since it is unknown whether the stack
- *  grows up or down (in general), this give the CPU dependent
- *  code the option of picking the version it wants to use.
- *  @note These two variables are required if the macro
- *        @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK is defined as TRUE.
- *  Nothing prevents the porter from declaring more CPU specific variables.
-/* XXX: if needed, put more variables here */
- *  The size of the floating point context area.  On some CPUs this
- *  will not be a "sizeof" because the format of the floating point
- *  area is not defined -- only the size is.  This is usually on
- *  CPUs with a "floating point save context" instruction.
-#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
- *  Amount of extra stack (above minimum stack size) required by
- *  MPCI receive server thread.  Remember that in a multiprocessor
- *  system this thread must exist and be able to process all directives.
-#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
- *  This defines the number of entries in the @ref _ISR_Vector_table managed
- *  by RTEMS.
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS      32
- *  This defines the highest interrupt vector number for this port.
-#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER  (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
- *  This is defined if the port has a special way to report the ISR nesting
- *  level.  Most ports maintain the variable @a _ISR_Nest_level.
-#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
- *  Should be large enough to run all RTEMS tests.  This ensures
- *  that a "reasonable" small application should not have any problems.
-#define CPU_STACK_MINIMUM_SIZE          (1024*4)
- *  CPU's worst alignment requirement for data types on a byte boundary.  This
- *  alignment does not take into account the requirements for the stack.
-#define CPU_ALIGNMENT              8
- *  This number corresponds to the byte alignment requirement for the
- *  heap handler.  This alignment requirement may be stricter than that
- *  for the data types alignment specified by @ref CPU_ALIGNMENT.  It is
- *  common for the heap to follow the same alignment requirement as
- *  @ref CPU_ALIGNMENT.  If the @ref CPU_ALIGNMENT is strict enough for
- *  the heap, then this should be set to @ref CPU_ALIGNMENT.
- *  @note  This does not have to be a power of 2 although it should be
- *         a multiple of 2 greater than or equal to 2.  The requirement
- *         to be a multiple of 2 is because the heap uses the least
- *         significant field of the front and back flags to indicate
- *         that a block is in use or free.  So you do not want any odd
- *         length blocks really putting length data in that bit.
- *         On byte oriented architectures, @ref CPU_HEAP_ALIGNMENT normally will
- *         have to be greater or equal to than @ref CPU_ALIGNMENT to ensure that
- *         elements allocated from the heap meet all restrictions.
-#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
- *  This number corresponds to the byte alignment requirement for memory
- *  buffers allocated by the partition manager.  This alignment requirement
- *  may be stricter than that for the data types alignment specified by
- *  @ref CPU_ALIGNMENT.  It is common for the partition to follow the same
- *  alignment requirement as @ref CPU_ALIGNMENT.  If the @ref CPU_ALIGNMENT is
- *  strict enough for the partition, then this should be set to
- *  @note  This does not have to be a power of 2.  It does have to
- *         be greater or equal to than @ref CPU_ALIGNMENT.
-#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
- *  stack.  This alignment requirement may be stricter than that for the
- *  data types alignment specified by @ref CPU_ALIGNMENT.  If the
- *  @ref CPU_ALIGNMENT is strict enough for the stack, then this should be
- *  set to 0.
- *  @note This must be a power of 2 either 0 or greater than @ref CPU_ALIGNMENT.
-#define CPU_STACK_ALIGNMENT        0
- *  ISR handler macros
- *  Support routine to initialize the RTEMS vector table after it is allocated.
-#define _CPU_Initialize_vectors()
- *  Disable all interrupts for an RTEMS critical section.  The previous
- *  level is returned in @a _isr_cookie.
- *  @param[out] _isr_cookie will contain the previous level cookie
-#define _CPU_MSR_GET( _msr_value ) \
-  do { \
-    _msr_value = 0; \
-    __asm__ volatile ("mfs %0, rmsr" : "=&r" ((_msr_value)) : "0" ((_msr_value))); \
-  } while (0)
-#define _CPU_MSR_SET( _msr_value ) \
-{ __asm__ volatile ("mts rmsr, %0" : "=&r" ((_msr_value)) : "0" ((_msr_value))); }
-#define _CPU_ISR_Disable( _isr_cookie ) \
-    unsigned int _new_msr;  \
-    _CPU_MSR_GET(_isr_cookie); \
-    _new_msr = _isr_cookie & ~0x02; \
-    _CPU_MSR_SET(_new_msr); \
- *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
- *  This indicates the end of an RTEMS critical section.  The parameter
- *  @a _isr_cookie is not modified.
- *  @param[in] _isr_cookie contain the previous level cookie
-#define _CPU_ISR_Enable( _isr_cookie )  \
-    _CPU_MSR_SET(_isr_cookie); \
- *  This temporarily restores the interrupt to @a _isr_cookie before immediately
- *  disabling them again.  This is used to divide long RTEMS critical
- *  sections into two or more parts.  The parameter @a _isr_cookie is not
- *  modified.
-#define _CPU_ISR_Flash( _isr_cookie ) \
- *  This routine and @ref _CPU_ISR_Get_level
- *  Map the interrupt level in task mode onto the hardware that the CPU
- *  actually provides.  Currently, interrupt levels which do not
- *  map onto the CPU in a generic fashion are undefined.  Someday,
- *  it would be nice if these were "mapped" by the application
- *  via a callout.  For example, m68k has 8 levels 0 - 7, levels
- *  8 - 255 would be available for bsp/application specific meaning.
- *  This could be used to manage a programmable interrupt controller
- *  via the rtems_task_mode directive.
-#define _CPU_ISR_Set_level( new_level ) \
- *  Return the current interrupt disable level for this task in
- *  the format used by the interrupt level portion of the task mode.
- *  @note This routine usually must be implemented as a subroutine.
-uint32_t   _CPU_ISR_Get_level( void );
-/* end of ISR handler macros */
- * @brief Initializes the CPU context.
- * The following steps are performed:
- *  - setting a starting address
- *  - preparing the stack
- *  - preparing the stack and frame pointers
- *  - setting the proper interrupt level in the context
- * @param[in] context points to the context area
- * @param[in] stack_area_begin is the low address of the allocated stack area
- * @param[in] stack_area_size is the size of the stack area in bytes
- * @param[in] new_level is the interrupt level for the task
- * @param[in] entry_point is the task's entry point
- * @param[in] is_fp is set to @c true if the task is a floating point task
- * @param[in] tls_area is the thread-local storage (TLS) area
-void _CPU_Context_Initialize(
-  Context_Control *context,
-  void *stack_area_begin,
-  size_t stack_area_size,
-  uint32_t new_level,
-  void (*entry_point)( void ),
-  bool is_fp,
-  void *tls_area
- *  This routine is responsible for somehow restarting the currently
- *  executing task.  If you are lucky, then all that is necessary
- *  is restoring the context.  Otherwise, there will need to be
- *  a special assembly routine which does something special in this
- *  case.  For many ports, simply adding a label to the restore path
- *  of @ref _CPU_Context_switch will work.  On other ports, it may be
- *  possibly to load a few arguments and jump to the restore path. It will
- *  not work if restarting self conflicts with the stack frame
- *  assumptions of restoring a context.
-#define _CPU_Context_Restart_self( _the_context ) \
-   _CPU_Context_restore( (_the_context) );
- *  The purpose of this macro is to allow the initial pointer into
- *  a floating point context area (used to save the floating point
- *  context) to be at an arbitrary place in the floating point
- *  context area.
- *  This is necessary because some FP units are designed to have
- *  their context saved as a stack which grows into lower addresses.
- *  Other FP units can be saved by simply moving registers into offsets
- *  from the base of the context area.  Finally some FP units provide
- *  a "dump context" instruction which could fill in from high to low
- *  or low to high based on the whim of the CPU designers.
- *  @param[in] _base is the lowest physical address of the floating point
- *         context area
- *  @param[in] _offset is the offset into the floating point area
-#define _CPU_Context_Fp_start( _base, _offset ) \
-   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
- *  This routine initializes the FP context area passed to it to.
- *  There are a few standard ways in which to initialize the
- *  floating point context.  The code included for this macro assumes
- *  that this is a CPU in which a "initial" FP context was saved into
- *  @a _CPU_Null_fp_context and it simply copies it to the destination
- *  context passed to it.
- *  Other floating point context save/restore models include:
- *    -# not doing anything, and
- *    -# putting a "null FP status word" in the correct place in the FP context.
- *  @param[in] _destination is the floating point context area
-#define _CPU_Context_Initialize_fp( _destination ) \
-   *(*(_destination)) = _CPU_Null_fp_context; \
-/* end of Context handler macros */
-/* Fatal Error manager macros */
- *  This routine copies _error into a known place -- typically a stack
- *  location or a register, optionally disables interrupts, and
- *  halts/stops the CPU.
-#define _CPU_Fatal_halt(_source, _error ) \
-        printk("Fatal Error %d.%d Halted\n",_source, _error); \
-        for(;;)
-/* end of Fatal Error manager macros */
-/* Bitfield handler macros */
- *  @defgroup CPUBitfield Processor Dependent Bitfield Manipulation
- *  This set of routines are used to implement fast searches for
- *  the most important ready task.
- *  @ingroup CPUBitfield
- *  This definition is set to TRUE if the port uses the generic bitfield
- *  manipulation implementation.
-#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
- *  This definition is set to TRUE if the port uses the data tables provided
- *  by the generic bitfield manipulation implementation.
- *  This can occur when actually using the generic bitfield manipulation
- *  implementation or when implementing the same algorithm in assembly
- *  language for improved performance.  It is unlikely that a port will use
- *  the data if it has a bitfield scan instruction.
-#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
- *  This routine sets @a _output to the bit number of the first bit
- *  set in @a _value.  @a _value is of CPU dependent type
- *  @a Priority_bit_map_Control.  This type may be either 16 or 32 bits
- *  wide although only the 16 least significant bits will be used.
- *  There are a number of variables in using a "find first bit" type
- *  instruction.
- *    -# What happens when run on a value of zero?
- *    -# Bits may be numbered from MSB to LSB or vice-versa.
- *    -# The numbering may be zero or one based.
- *    -# The "find first bit" instruction may search from MSB or LSB.
- *  RTEMS guarantees that (1) will never happen so it is not a concern.
- *  (2),(3), (4) are handled by the macros @ref _CPU_Priority_Mask and
- *  @ref _CPU_Priority_bits_index.  These three form a set of routines
- *  which must logically operate together.  Bits in the _value are
- *  set and cleared based on masks built by @ref _CPU_Priority_Mask.
- *  The basic major and minor values calculated by @ref _Priority_Major
- *  and @ref _Priority_Minor are "massaged" by @ref _CPU_Priority_bits_index
- *  to properly range between the values returned by the "find first bit"
- *  instruction.  This makes it possible for @ref _Priority_Get_highest to
- *  calculate the major and directly index into the minor table.
- *  This mapping is necessary to ensure that 0 (a high priority major/minor)
- *  is the first bit found.
- *  This entire "find first bit" and mapping process depends heavily
- *  on the manner in which a priority is broken into a major and minor
- *  components with the major being the 4 MSB of a priority and minor
- *  the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
- *  priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
- *  to the lowest priority.
- *  If your CPU does not have a "find first bit" instruction, then
- *  there are ways to make do without it.  Here are a handful of ways
- *  to implement this in software:
- at verbatim
-      - a series of 16 bit test instructions
-      - a "binary search using if's"
-      - _number = 0
-        if _value > 0x00ff
-          _value >>=8
-          _number = 8;
-        if _value > 0x0000f
-          _value >=8
-          _number += 4
-        _number += bit_set_table[ _value ]
- at endverbatim
- *    where bit_set_table[ 16 ] has values which indicate the first
- *      bit set
- *  @param[in] _value is the value to be scanned
- *  @param[in] _output is the first bit set
-#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
-#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
-    (_output) = 0;   /* do something to prevent warnings */ \
-#endif
-/* end of Bitfield handler macros */
- *  This routine builds the mask which corresponds to the bit fields
- *  as searched by @ref _CPU_Bitfield_Find_first_bit.  See the discussion
- *  for that routine.
-#define _CPU_Priority_Mask( _bit_number ) \
-  ( 1 << (_bit_number) )
-#endif
- *  This routine translates the bit numbers returned by
- *  @ref _CPU_Bitfield_Find_first_bit into something suitable for use as
- *  a major or minor component of a priority.  See the discussion
- *  @param[in] _priority is the major or minor number to translate
-#define _CPU_Priority_bits_index( _priority ) \
-  (_priority)
-#endif
-#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
-#define CPU_TIMESTAMP_USE_INT64 TRUE
-#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
-typedef struct {
-/* There is no CPU specific per-CPU state */
-} CPU_Per_CPU_control;
-#define CPU_SIZEOF_POINTER 4
-#define CPU_PER_CPU_CONTROL_SIZE 0
-typedef struct {
-  uint32_t r[32];
-} CPU_Exception_frame;
-/* end of Priority handler macros */
-/* functions */
- *  This routine performs CPU dependent initialization.
-void _CPU_Initialize(void);
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
- *  @param[in] vector is the vector number
- *  @param[in] new_handler is the raw ISR handler to install
- *  @param[in] old_handler is the previously installed ISR Handler
-  uint32_t    vector,
- *  This routine installs an interrupt vector.
- *  @param[in] new_handler is the RTEMS ISR handler to install
-  uint32_t    vector,
- *  This routine installs the hardware interrupt stack pointer.
- *  @note  It need only be provided if @ref CPU_HAS_HARDWARE_INTERRUPT_STACK
- *         is TRUE.
-void _CPU_Install_interrupt_stack( void );
- *  This routine is the CPU dependent IDLE thread body.
- *  @note  It need only be provided if @ref CPU_PROVIDES_IDLE_THREAD_BODY
- *         is TRUE.
-void *_CPU_Thread_Idle_body( uintptr_t ignored );
- *  This routine switches from the run context to the heir context.
- *  @param[in] run points to the context of the currently executing task
- *  @param[in] heir points to the context of the heir task
-void _CPU_Context_switch(
-  Context_Control  *run,
-  Context_Control  *heir
- *  This routine is generally used only to restart self in an
- *  efficient manner.  It may simply be a label in @ref _CPU_Context_switch.
- *  @param[in] new_context points to the context to be restored.
- *  @note May be unnecessary to reload some registers.
-void _CPU_Context_restore(
-  Context_Control *new_context
-) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
- *  This routine saves the floating point context passed to it.
- *  @param[in] fp_context_ptr is a pointer to a pointer to a floating
- *  point context area
- *  @return on output @a *fp_context_ptr will contain the address that
- *  should be used with @ref _CPU_Context_restore_fp to restore this context.
-void _CPU_Context_save_fp(
-  Context_Control_fp **fp_context_ptr
- *  This routine restores the floating point context passed to it.
- *  point context area to restore
- *  should be used with @ref _CPU_Context_save_fp to save this context.
-void _CPU_Context_restore_fp(
- *  The following routine swaps the endian format of an unsigned int.
- *  It must be static because it is referenced indirectly.
- *  This version will work on any processor, but if there is a better
- *  way for your CPU PLEASE use it.  The most common way to do this is to:
- *     swap least significant two bytes with 16-bit rotate
- *     swap upper and lower 16-bits
- *     swap most significant two bytes with 16-bit rotate
- *  Some CPUs have special instructions which swap a 32-bit quantity in
- *  a single instruction (e.g. i486).  It is probably best to avoid
- *  an "endian swapping control bit" in the CPU.  One good reason is
- *  that interrupts would probably have to be disabled to ensure that
- *  an interrupt does not try to access the same "chunk" with the wrong
- *  endian.  Another good reason is that on some CPUs, the endian bit
- *  endianness for ALL fetches -- both code and data -- so the code
- *  will be fetched incorrectly.
- *  @param[in] value is the value to be swapped
- *  @return the value after being endian swapped
-static inline uint32_t CPU_swap_u32(
-  uint32_t value
-  uint32_t byte1, byte2, byte3, byte4, swapped;
-  byte4 = (value >> 24) & 0xff;
-  byte3 = (value >> 16) & 0xff;
-  byte2 = (value >> 8)  & 0xff;
-  byte1 =  value        & 0xff;
-  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
-  return swapped;
- *  This routine swaps a 16 bir quantity.
-#define CPU_swap_u16( value ) \
-  (((value&0xff) << 8) | ((value >> 8)&0xff))
-typedef uint32_t CPU_Counter_ticks;
-CPU_Counter_ticks _CPU_Counter_read( void );
-CPU_Counter_ticks _CPU_Counter_difference(
-  CPU_Counter_ticks second,
-  CPU_Counter_ticks first
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/spec/build/bsps/microblaze/grp.yml b/spec/build/bsps/microblaze/grp.yml
index 0000000000..3a238f5d6e
--- /dev/null
+++ b/spec/build/bsps/microblaze/grp.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: group
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/microblaze/include/bsp/linker-symbols.h
+ldflags: []
+links: []
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/abi.yml b/spec/build/bsps/microblaze/microblaze_fpga/abi.yml
index 0000000000..4665f5d42e
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/abi.yml
@@ -0,0 +1,20 @@
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+default:
+- -mlittle-endian
+- -mno-xl-soft-div
+- -mno-xl-soft-mul
+- -Wl,-EL
+default-by-variant: []
+description: |
+  ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105.yml b/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105.yml
index 0000000000..0a29e9c200
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105.yml
@@ -0,0 +1,24 @@
+arch: microblaze
+bsp: kcu105
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: microblaze_fpga
+includes: []
+install: []
+links:
+- role: build-dependency
+  uid: grp
+  uid: linkcmds
+  uid: tstkcu105_qemu
+  uid: ../../opto0
+source:
+- bsps/shared/start/bspreset-loop.c
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105_qemu.yml b/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105_qemu.yml
index 0000000000..9f5d742885
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/bspkcu105_qemu.yml
@@ -0,0 +1,24 @@
+arch: microblaze
+bsp: kcu105_qemu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+  uid: grp
+  uid: linkcmds
+  uid: ../../opto0
+source:
+- bsps/microblaze/microblaze_fpga/start/bspreset.c
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index 0000000000..7d11228d92
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -0,0 +1,36 @@
+build-type: group
+copyrights:
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+  uid: ../grp
+  uid: abi
+  uid: obj
+  uid: start
+  uid: optconsoleinterrupts
+  uid: optintcbaseaddress
+  uid: opttimerbaseaddress
+  uid: opttimerfrequency
+  uid: optuartlitebaseaddress
+  uid: ../../obj
+  uid: ../../objirq
+  uid: ../../bspopts
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml b/spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml
index 0000000000..1584fd694e
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml
@@ -0,0 +1,242 @@
+build-type: config-file
+content: |
+  /* SPDX-License-Identifier: BSD-2-Clause */
+   * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+   * Redistribution and use in source and binary forms, with or without
+   * modification, are permitted provided that the following conditions
+   * are met:
+   * 1. Redistributions of source code must retain the above copyright
+   *    notice, this list of conditions and the following disclaimer.
+   * 2. Redistributions in binary form must reproduce the above copyright
+   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+   * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+   * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+   * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+   * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+   * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+   * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+   * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+   * POSSIBILITY OF SUCH DAMAGE.
+  ENTRY (_start)
+  STARTUP (start.o)
+  _TEXT_START_ADDR = DEFINED(_TEXT_START_ADDR) ? _TEXT_START_ADDR : 0x80000000;
+  MEMORY
+        BRAM     (AIW) : ORIGIN = 0x00000000, LENGTH = 0x10000
+        RAM   : ORIGIN = _TEXT_START_ADDR, LENGTH = 0x1000000
+  REGION_ALIAS ("REGION_START", BRAM);
+  REGION_ALIAS ("REGION_VECTOR", BRAM);
+  REGION_ALIAS ("REGION_TEXT", RAM);
+  REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+  REGION_ALIAS ("REGION_RODATA", RAM);
+  REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_DATA", RAM);
+  REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_FAST_DATA", RAM);
+  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_BSS", RAM);
+  REGION_ALIAS ("REGION_WORK", RAM);
+  REGION_ALIAS ("REGION_STACK", RAM);
+  SECTIONS
+    .vectors.reset 0x0 : { KEEP (*(.vectors.reset)) } = 0
+    .vectors.sw_exception 0x8 : { KEEP (*(.vectors.sw_exception)) } = 0
+    .vectors.interrupt 0x10 : { KEEP (*(.vectors.interrupt)) } = 0
+    .vectors.debug_sw_break 0x18 : { KEEP (*(.vectors.debug_sw_break)) } = 0
+    .vectors.hw_exception 0x20 : { KEEP (*(.vectors.hw_exception)) } = 0
+    . = _TEXT_START_ADDR;
+    .text : ALIGN_WITH_INPUT {
+      bsp_section_text_begin = .;
+      *(.text.unlikely .text.*_unlikely)
+      *(.text .stub .text.* .gnu.linkonce.t.*)
+      /* .gnu.warning sections are handled specially by elf32.em.  */
+      *(.gnu.warning)
+      *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
+    } > REGION_TEXT AT > REGION_TEXT_LOAD
+    .init : ALIGN_WITH_INPUT {
+      KEEP (*(.init))
+    .fini : ALIGN_WITH_INPUT {
+      KEEP (*(.fini))
+      * If requested, align the size of the combined start and text
+      * section to the next power of two to meet MPU region
+      * alignment requirements.
+      . = DEFINED (bsp_align_text_and_rodata_end_to_power_of_2) ?
+          bsp_section_start_begin
+          + ALIGN (. - bsp_section_start_begin,
+          1 << LOG2CEIL (. - bsp_section_start_begin)) : .;
+      bsp_section_text_end = .;
+    bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
+    bsp_section_text_load_begin = LOADADDR (.text);
+    bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
+    . = ALIGN(4);
+    /* Added to handle pic code */
+    .got : {
+      *(.got)
+    } > REGION_RODATA AT > REGION_RODATA_LOAD
+    .got1 : {
+      *(.got1)
+    .got2 : {
+      *(.got2)
+    _frodata = . ;
+    .rodata : {
+      *(.rodata)
+      *(.rodata.*)
+      *(.gnu.linkonce.r.*)
+      CONSTRUCTORS; /* Is this needed? */
+    _erodata = .;
+    .eh_frame : {
+      *(.eh_frame)
+    .jcr : {
+      *(.jcr)
+    .gcc_except_table : {
+      *(.gcc_except_table)
+    .tdata : ALIGN_WITH_INPUT {
+      _TLS_Data_begin = .;
+      *(.tdata .tdata.* .gnu.linkonce.td.*)
+      _TLS_Data_end = .;
+    .tbss : ALIGN_WITH_INPUT {
+      _TLS_BSS_begin = .;
+      *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+      _TLS_BSS_end = .;
+    _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
+    _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
+    _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
+    _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
+    _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
+    _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
+    .ctors : {
+      _dummy_symbol__ = .;
+      __CTOR_LIST__ = .;
+      ___CTORS_LIST___ = .;
+      KEEP (*crtbegin.o(.ctors))
+      KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors))
+      KEEP (*(SORT(.ctors.*)))
+      KEEP (*(.ctors*))
+      __CTOR_END__ = .;
+      ___CTORS_END___ = .;
+    .dtors : {
+      __DTOR_LIST__ = .;
+      ___DTORS_LIST___ = .;
+      KEEP (*crtbegin.o(.dtors))
+      KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors))
+      KEEP (*(SORT(.dtors.*)))
+      KEEP (*(.dtors))
+      PROVIDE(__DTOR_END__ = .);
+      PROVIDE(___DTORS_END___ = .);
+    .rtemsroset : {
+      /* Special FreeBSD linker set sections */
+      __start_set_sysctl_set = .;
+      *(set_sysctl_*);
+      __stop_set_sysctl_set = .;
+      *(set_domain_*);
+      *(set_pseudo_*);
+      KEEP (*(SORT(.rtemsroset.*)))
+      bsp_section_rodata_end = .;
+    .data : ALIGN_WITH_INPUT {
+      bsp_section_data_begin = .;
+      *(.data .data.* .gnu.linkonce.d.*)
+      SORT(CONSTRUCTORS)
+    } > REGION_DATA AT > REGION_DATA_LOAD
+    .data1 : ALIGN_WITH_INPUT {
+      *(.data1)
+    .rtemsrwset : ALIGN_WITH_INPUT {
+      KEEP (*(SORT(.rtemsrwset.*)))
+      bsp_section_data_end = .;
+    bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
+    bsp_section_data_load_begin = LOADADDR (.data);
+    bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
+    .bss : ALIGN_WITH_INPUT {
+      bsp_section_bss_begin = .;
+      *(.dynbss)
+      *(.bss .bss.* .gnu.linkonce.b.*)
+      *(COMMON)
+      bsp_section_bss_end = .;
+    } > REGION_BSS AT > REGION_BSS
+    bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
+    . = ALIGN(8);
+    .rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
+      bsp_section_rtemsstack_begin = .;
+      *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
+      bsp_section_rtemsstack_end = .;
+    } > REGION_WORK AT > REGION_WORK
+    bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
+    .work : ALIGN_WITH_INPUT {
+      * The work section will occupy the remaining REGION_WORK region and
+      * contains the RTEMS work space and heap.
+      bsp_section_work_begin = .;
+      . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
+      bsp_section_work_end = .;
+    bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
+    .stack : ALIGN_WITH_INPUT {
+      * The stack section will occupy the remaining REGION_STACK region and may
+      * contain the task stacks.  Depending on the region distribution this
+      * section may be of zero size.
+      bsp_section_stack_begin = .;
+      . += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
+      bsp_section_stack_end = .;
+    } > REGION_STACK AT > REGION_STACK
+    bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_begin;
+    RamBase = ORIGIN (REGION_WORK);
+    RamSize = LENGTH (REGION_WORK);
+    RamEnd = RamBase + RamSize;
+    WorkAreaBase = bsp_section_work_begin;
+    HeapSize = 0;
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 0000000000..8f2bba665a
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -0,0 +1,51 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+  source:
+  - bsps/microblaze/microblaze_fpga/include/bsp.h
+  - bsps/microblaze/microblaze_fpga/include/tm27.h
+  source:
+  - bsps/microblaze/microblaze_fpga/include/bsp/irq.h
+  - bsps/microblaze/include/common/xil_io.h
+  - bsps/microblaze/include/common/xil_types.h
+  - bsps/microblaze/include/dev/serial/uartlite.h
+  - bsps/microblaze/include/dev/serial/uartlite_l.h
+- destination: ${BSP_LIBDIR}
+  source:
+  - bsps/microblaze/microblaze_fpga/start/linkcmds
+links: []
+source:
+- bsps/microblaze/microblaze_fpga/clock/clock.c
+- bsps/microblaze/microblaze_fpga/console/console-io.c
+- bsps/microblaze/microblaze_fpga/console/debug-io.c
+- bsps/microblaze/microblaze_fpga/irq/irq.c
+- bsps/microblaze/microblaze_fpga/start/_exception_handler.S
+- bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S
+- bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
+- bsps/microblaze/microblaze_fpga/start/bspstart.c
+- bsps/microblaze/microblaze_fpga/start/crtinit.S
+- bsps/microblaze/shared/dev/serial/uartlite.c
+- bsps/microblaze/shared/dev/serial/uartlite_l.c
+- bsps/shared/cache/nocache.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/cpucounter/cpucounterfrequency.c
+- bsps/shared/dev/cpucounter/cpucounterread.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optconsoleinterrupts.yml b/spec/build/bsps/microblaze/microblaze_fpga/optconsoleinterrupts.yml
index 0000000000..c75a4450e1
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optconsoleinterrupts.yml
@@ -0,0 +1,15 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+default: true
+description: |
+  use interrupt driven mode for console
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optintcbaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optintcbaseaddress.yml
index 0000000000..5ed9294ff6
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optintcbaseaddress.yml
@@ -0,0 +1,18 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+default: 0x41200000
+description: |
+  base address of the AXI Interrupt Controller
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_INTC_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/opttimerbaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/opttimerbaseaddress.yml
index 0000000000..93bea74ea3
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/opttimerbaseaddress.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x41C00000
+description: |
+  base address of the AXI Timer
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_TIMER_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/opttimerfrequency.yml b/spec/build/bsps/microblaze/microblaze_fpga/opttimerfrequency.yml
index 0000000000..4734f81bc1
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/opttimerfrequency.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 100000000
+description: |
+  frequency of the AXI Timer
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_TIMER_FREQUENCY
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optuartlitebaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optuartlitebaseaddress.yml
index 0000000000..7dd3123b64
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optuartlitebaseaddress.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x40600000
+description: |
+  base address of the AXI UART Lite
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_UART_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/start.yml b/spec/build/bsps/microblaze/microblaze_fpga/start.yml
index 0000000000..38de263733
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/start.yml
@@ -0,0 +1,14 @@
+asflags: []
+build-type: start-file
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+links: []
+source:
+- bsps/microblaze/shared/start/start.S
+target: start.o
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/tstkcu105_qemu.yml b/spec/build/bsps/microblaze/microblaze_fpga/tstkcu105_qemu.yml
index 0000000000..fb9f2bdb00
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/tstkcu105_qemu.yml
@@ -0,0 +1,14 @@
+actions:
+- set-test-state:
+    # expected to fail, don't compile these
+    minimum: exclude
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+type: build
diff --git a/spec/build/cpukit/cpumicroblaze.yml b/spec/build/cpukit/cpumicroblaze.yml
index 0000000000..36c328216d
--- /dev/null
+++ b/spec/build/cpukit/cpumicroblaze.yml
@@ -0,0 +1,29 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- microblaze
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/rtems
+  source:
+  - cpukit/score/cpu/microblaze/include/rtems/asm.h
+- destination: ${BSP_INCLUDEDIR}/rtems/score
+  source:
+  - cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
+  - cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
+  - cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
+  - cpukit/score/cpu/microblaze/include/rtems/score/microblaze.h
+links: []
+source:
+- cpukit/score/cpu/microblaze/__tls_get_addr.c
+- cpukit/score/cpu/microblaze/microblaze-context-switch.S
+- cpukit/score/cpu/microblaze/microblaze-context-validate.S
+- cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S
+- cpukit/score/cpu/microblaze/cpu.c
+- cpukit/score/cpu/microblaze/cpu_asm.S
+type: build
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index c0f8f6d670..38f4f2776b 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -471,6 +471,8 @@ links:
   uid: cpum68k
   uid: cpumips
+  uid: cpumicroblaze
   uid: cpumoxie
2.27.0
