[PATCH 1/3] aarch64: add internal API for secure monitor call (smc)
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Oct 18 14:18:24 UTC 2021
Comments inline below.
On 10/16/2021 15:12, Gedare Bloom wrote:
> cpukit/score/cpu/aarch64/aarch64-smc.c | 72 ++++++++++++++++
> .../aarch64/include/rtems/score/aarch64-smc.h | 84 +++++++++++++++++++
> spec/build/cpukit/cpuaarch64.yml | 2 +
> 3 files changed, 158 insertions(+)
> create mode 100644 cpukit/score/cpu/aarch64/aarch64-smc.c
> create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> diff --git a/cpukit/score/cpu/aarch64/aarch64-smc.c b/cpukit/score/cpu/aarch64/aarch64-smc.c
> new file mode 100644
> index 0000000000..4cfee91a0b
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/aarch64-smc.c
> @@ -0,0 +1,72 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief Secure Monitor Call
> + * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/aarch64-smc.h>
> +int _AArch64_SMC_Invoke(
> + int function_id,
Nit: The function ID should be uint32_t.
> + uintptr_t arg0,
> + uintptr_t arg1,
> + uintptr_t arg2,
> + uintptr_t arg3,
> + uintptr_t arg4,
> + uintptr_t arg5,
> + uintptr_t arg6,
> + uintptr_t arg7,
Only arguments 0-7 are passed in registers according to the AAPCS64.
arg7 here would be the 9th argument and thus passed on the stack which
is incompatible with the SMC calling convention which exclusively uses
registers for passing arguments. It should be fine to drop this argument
since we're not yet using any PSCI functionality that requires that many
arguments.
> + AArch64_SMC_Return *result
> + int rv;
> + /* This only works for SMC that return 4 or fewer results. It may be extended
> + * up to the full 18 return results specified for SMC64, but then we would
> + * need to allocate a callee-saved register for *result */
> + __asm__ volatile(
> + "smc #0\n"
> + "mov %0, x0\n"
> + "ldr x15, [sp]\n"
> + "cbz x15, 0f\n"
> + "stp x0, x1, [x15]\n"
> + "stp x2, x3, [x15, #16]\n"
> + "0:\n"
> + : "=r" ( rv )
> + : "x0", "x1", "x2", "x3", "x15"
> + return rv;
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> index 0000000000..04f99f8bf3
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> @@ -0,0 +1,84 @@
> + * @file
> + * @ingroup RTEMSScoreCPUAArch64
> + * @brief This header file provides API to wrap secure monitor calls (smc).
> + * are met:
> +#ifndef _RTEMS_SCORE_AARCH64_SMC_H
> +#define _RTEMS_SCORE_AARCH64_SMC_H
> +#include <rtems/score/basedefs.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @defgroup RTEMSScoreCPUAArch64SMC Secure Monitor Call Support
> + * @brief This group provides functions to invoke secure monitor mode.
> + * @brief The return result from smc invocation.
> +typedef struct {
> + uintptr_t x0;
> + uintptr_t x1;
> + uintptr_t x2;
> + uintptr_t x3;
> +} AArch64_SMC_Return;
> + int function_id,
> + uintptr_t arg0,
> + uintptr_t arg1,
> + uintptr_t arg2,
> + uintptr_t arg3,
> + uintptr_t arg4,
> + uintptr_t arg5,
> + uintptr_t arg6,
> + uintptr_t arg7,
> +#ifdef __cplusplus
> +#endif
> +#endif /* _RTEMS_SCORE_AARCH64_SMC_H */
> diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
> index 7b1bf5705d..c3befca418 100644
> --- a/spec/build/cpukit/cpuaarch64.yml
> +++ b/spec/build/cpukit/cpuaarch64.yml
> @@ -18,6 +18,7 @@ install:
> - destination: ${BSP_INCLUDEDIR}/rtems/score
> source:
> - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
> + - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> @@ -31,6 +32,7 @@ source:
> - cpukit/score/cpu/aarch64/aarch64-exception-default.c
> - cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> - cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> +- cpukit/score/cpu/aarch64/aarch64-smc.c
> - cpukit/score/cpu/aarch64/aarch64-thread-idle.c
> - cpukit/score/cpu/aarch64/cpu.c
> - cpukit/score/cpu/aarch64/cpu_asm.S
