Alex White
alex.white at oarcorp.com
Mon Oct 18 15:06:34 UTC 2021
Hi,
Ignore this. It looks like my ".patch" file was malformed somehow. I will see if I can fix it and resend.
Alex
________________________________
From: devel <devel-bounces at rtems.org> on behalf of Alex White <alex.white at oarcorp.com>
Sent: Monday, October 18, 2021 10:01 AM
To: devel at rtems.org <devel at rtems.org>
Subject:
>From c47d01739f2abf79a1423ea3cdcc7e98c621b222 Mon Sep 17 00:00:00 2001
Date: Thu, 14 Oct 2021 01:44:08 -0500
Subject: [PATCH RSB] rtems-tools-6.cfg: Bump hash to include MicroBlaze
Hash: 323007a6b520140a20b2e268c90b78ff67afaf45
rtems/config/tools/rtems-tools-6.cfg | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index cfb3333..4158753 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
%define rtems_tools_source rtems-tools-%{rtems_tools_version}
%define rtems_tools_ext xz
%else
- %define rtems_tools_version 40a7058bd4d7681ca6be7a14f09a1275ea4fbde4
+ %define rtems_tools_version 323007a6b520140a20b2e268c90b78ff67afaf45
%define rtems_tools_ext bz2
%endif
%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
- nlwNKLP2UXRMRfK0SU0Bpd+9sOvRoRaXRRTj0lzx9jkqGMwwU4lB19uLhTnH88u1jGOrhVSkNunIHvbi9SayAg==
+ yo5i1HEaYyOOX8JJGr+kok0vIEZGpXjeZmA44gqTow101PhtlwhebvgTS0SeMe8L68wTDqdjZe5QVnsjKgYOhw==
# Optionally enable/disable building the RTEMS Tools via the command line.
2.32.0
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
