[PATCH RSB] rtems-tools-6.cfg: Bump hash to include MicroBlaze
Alex White
alex.white at oarcorp.com
Mon Oct 18 15:09:46 UTC 2021
Hash: 323007a6b520140a20b2e268c90b78ff67afaf45
rtems/config/tools/rtems-tools-6.cfg | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index cfb3333..4158753 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
%define rtems_tools_source rtems-tools-%{rtems_tools_version}
%define rtems_tools_ext xz
%else
- %define rtems_tools_version 40a7058bd4d7681ca6be7a14f09a1275ea4fbde4
+ %define rtems_tools_version 323007a6b520140a20b2e268c90b78ff67afaf45
%define rtems_tools_ext bz2
%endif
%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
- nlwNKLP2UXRMRfK0SU0Bpd+9sOvRoRaXRRTj0lzx9jkqGMwwU4lB19uLhTnH88u1jGOrhVSkNunIHvbi9SayAg==
+ yo5i1HEaYyOOX8JJGr+kok0vIEZGpXjeZmA44gqTow101PhtlwhebvgTS0SeMe8L68wTDqdjZe5QVnsjKgYOhw==
# Optionally enable/disable building the RTEMS Tools via the command line.
2.32.0
