ZynqMP and Versal crash clearing coherent cache memory with memset
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 18 16:53:29 UTC 2021
On 10/18/2021 00:44, Chris Johns wrote:
> Hi,
> I cannot run libbsd on real hardware because the cadence rx descriptor cache
> coherent allocation crashes in `memset`. It is used to clear the memory.
> The rtemsbsd allocator call optionally clears the memory and it seems the newlib
> aarch64 memset code crashes when doing this. A basic loop with 8bit or 32bit
> writes does not crash. The memset call happily clears an array in cached memory
> with different offsets.
> I have posted a patch to spcache01 that generates the crash on Versal and ZynqMP
> hardware. The crash dump is:
> test cache coherent allocation
> clear cache coherent with memset: 0x1fe00050
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> X0   = 0x000000001fe00050 X17  = 0x000000000000000c
> X1   = 0x0000000000000000 X18  = 0x00000000100007b0
> X2   = 0x0000000000000110 X19  = 0x000000001fe00050
> X3   = 0x000000001fe000c0 X20  = 0x000000001fdfff80
> X4   = 0x000000001fe00250 X21  = 0x0000000010013ab0
> X5   = 0x0000000000000004 X22  = 0x0000000000000000
> X6   = 0x0000000000000001 X23  = 0x00000000ffffffff
> X7   = 0x0000000000000000 X24  = 0x0000000010103140
> X8   = 0x0000000000000000 X25  = 0x0000000000000000
> X9   = 0xffffff80ffffffc8 X26  = 0x0000000000000000
> X10  = 0x0000000000000000 X27  = 0x0000000000000000
> X11  = 0x000000001010ca78 X28  = 0x0000000000000000
> X12  = 0x0000000000000001 FP   = 0x000000001010cc30
> X13  = 0x000000001fe00050 LR   = 0x0000000010001f94
> X14  = 0x0000000000000000 SP   = 0x000000001010cc30
> X15  = 0x0000000000000004 PC   = 0x00000000100125c0
> X16  = 0x000000001000f700 DAIF = 0x00000000000003c0
> VEC  = 0x0000000000000004 CPSR = 0x0000000060000005
> ESR  = EC: 0b100101 IL: 0b1 ISS: 0b0000000000000000001100001
>         Data Abort taken without a change in Exception level
> FAR  = 0x000000001fe000c0
> FPCR = 0x0000000000000000 FPSR = 0x0000000000000010
> The Versal (A72) fails in exactly the same way. The allocated address is
> 0x1fe00050 and the FAR is 0x1fe000c0 so I am not sure if the "0xc0 - 0x50"
> section is aligning the pointer to a larger word size for better performance and
> that first part is OK but the different word size breaks.
I'm running with a toolchain that was built with
--targetcflags="-DPREFER_SIZE_OVER_SPEED" which affects the content of
the memset function, so my memset is just loops of writes and seems to
work fine. Just out of curiousity, what instruction was at that PC
address? If it was "dc zva", then I had seen this a while back during
initial AArch64 bringup and had assumed it was fixed since the addition
of the MMU code since that instruction doesn't work on device memory.
It looks like bsp_section_nocacheheap sits inside
bsp_section_nocachenoload which is mapped as device memory which
wouldn't play nicely with the "dc zva" instruction.
Kinsey
