ZynqMP and Versal crash clearing coherent cache memory with memset
Chris Johns
chrisj at rtems.org
Mon Oct 18 21:28:25 UTC 2021
On 19/10/21 3:53 am, Kinsey Moore wrote:
> On 10/18/2021 00:44, Chris Johns wrote:
>> Hi,
>> I cannot run libbsd on real hardware because the cadence rx descriptor cache
>> coherent allocation crashes in `memset`. It is used to clear the memory.
>> The rtemsbsd allocator call optionally clears the memory and it seems the newlib
>> aarch64 memset code crashes when doing this. A basic loop with 8bit or 32bit
>> writes does not crash. The memset call happily clears an array in cached memory
>> with different offsets.
>> I have posted a patch to spcache01 that generates the crash on Versal and ZynqMP
>> hardware. The crash dump is:
>> test cache coherent allocation
>> clear cache coherent with memset: 0x1fe00050
>> *** FATAL ***
>> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
>> X0 = 0x000000001fe00050 X17 = 0x000000000000000c
>> X1 = 0x0000000000000000 X18 = 0x00000000100007b0
>> X2 = 0x0000000000000110 X19 = 0x000000001fe00050
>> X3 = 0x000000001fe000c0 X20 = 0x000000001fdfff80
>> X4 = 0x000000001fe00250 X21 = 0x0000000010013ab0
>> X5 = 0x0000000000000004 X22 = 0x0000000000000000
>> X6 = 0x0000000000000001 X23 = 0x00000000ffffffff
>> X7 = 0x0000000000000000 X24 = 0x0000000010103140
>> X8 = 0x0000000000000000 X25 = 0x0000000000000000
>> X9 = 0xffffff80ffffffc8 X26 = 0x0000000000000000
>> X10 = 0x0000000000000000 X27 = 0x0000000000000000
>> X11 = 0x000000001010ca78 X28 = 0x0000000000000000
>> X12 = 0x0000000000000001 FP = 0x000000001010cc30
>> X13 = 0x000000001fe00050 LR = 0x0000000010001f94
>> X14 = 0x0000000000000000 SP = 0x000000001010cc30
>> X15 = 0x0000000000000004 PC = 0x00000000100125c0
>> X16 = 0x000000001000f700 DAIF = 0x00000000000003c0
>> VEC = 0x0000000000000004 CPSR = 0x0000000060000005
>> ESR = EC: 0b100101 IL: 0b1 ISS: 0b0000000000000000001100001
>> Data Abort taken without a change in Exception level
>> FAR = 0x000000001fe000c0
>> FPCR = 0x0000000000000000 FPSR = 0x0000000000000010
>> The Versal (A72) fails in exactly the same way. The allocated address is
>> 0x1fe00050 and the FAR is 0x1fe000c0 so I am not sure if the "0xc0 - 0x50"
>> section is aligning the pointer to a larger word size for better performance and
>> that first part is OK but the different word size breaks.
> I'm running with a toolchain that was built with
> --targetcflags="-DPREFER_SIZE_OVER_SPEED" which affects the content of the
> memset function, so my memset is just loops of writes and seems to work fine.
Oh. Maybe the eng manual needs a piece on this. Using flags on tool chains like
this is fine for a user because it is use at your own peril however I believe
patches need to be tested with the defaults for all tools. It is way to hard to
baseline a BSP if tweaks are needed here and there.
> Just out of curiousity, what instruction was at that PC address? If it was "dc
> zva", then I had seen this a while back during initial AArch64 bringup and had
> assumed it was fixed since the addition of the MMU code since that instruction
> doesn't work on device memory.
It this that instruction ...
100125c0: d50b7423 dc zva, x3
Looks like it is not fixed.
> It looks like bsp_section_nocacheheap sits inside bsp_section_nocachenoload
> which is mapped as device memory which wouldn't play nicely with the "dc zva"
> instruction.
Cache coherent memory is mapped as device memory. The descriptors are mapped
into it so checks of bits and updates are effected by caches.
