[PATCH RSB] rtems-tools-6.cfg: Bump hash to include MicroBlaze
Chris Johns
chrisj at rtems.org
Mon Oct 18 21:29:10 UTC 2021
OK and thanks
On 19/10/21 2:09 am, Alex White wrote:
> Hash: 323007a6b520140a20b2e268c90b78ff67afaf45
> rtems/config/tools/rtems-tools-6.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
> index cfb3333..4158753 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
> %define rtems_tools_source rtems-tools-%{rtems_tools_version}
> %define rtems_tools_ext xz
> %else
> - %define rtems_tools_version 40a7058bd4d7681ca6be7a14f09a1275ea4fbde4
> + %define rtems_tools_version 323007a6b520140a20b2e268c90b78ff67afaf45
> %define rtems_tools_ext bz2
> %endif
> %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> - nlwNKLP2UXRMRfK0SU0Bpd+9sOvRoRaXRRTj0lzx9jkqGMwwU4lB19uLhTnH88u1jGOrhVSkNunIHvbi9SayAg==
> + yo5i1HEaYyOOX8JJGr+kok0vIEZGpXjeZmA44gqTow101PhtlwhebvgTS0SeMe8L68wTDqdjZe5QVnsjKgYOhw==
> # Optionally enable/disable building the RTEMS Tools via the command line.
