ZynqMP and Versal crash clearing coherent cache memory with memset
Mon Oct 18 21:59:19 UTC 2021
On Mon, Oct 18, 2021 at 4:28 PM Chris Johns <chrisj at rtems.org> wrote:
> On 19/10/21 3:53 am, Kinsey Moore wrote:
> > On 10/18/2021 00:44, Chris Johns wrote:
> >> Hi,
> >> I cannot run libbsd on real hardware because the cadence rx descriptor cache
> >> coherent allocation crashes in `memset`. It is used to clear the memory.
> >> The rtemsbsd allocator call optionally clears the memory and it seems the newlib
> >> aarch64 memset code crashes when doing this. A basic loop with 8bit or 32bit
> >> writes does not crash. The memset call happily clears an array in cached memory
> >> with different offsets.
> >> I have posted a patch to spcache01 that generates the crash on Versal and ZynqMP
> >> hardware. The crash dump is:
> >> test cache coherent allocation
> >> clear cache coherent with memset: 0x1fe00050
> >> *** FATAL ***
> >> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> >> X0   = 0x000000001fe00050 X17  = 0x000000000000000c
> >> X1   = 0x0000000000000000 X18  = 0x00000000100007b0
> >> X2   = 0x0000000000000110 X19  = 0x000000001fe00050
> >> X3   = 0x000000001fe000c0 X20  = 0x000000001fdfff80
> >> X4   = 0x000000001fe00250 X21  = 0x0000000010013ab0
> >> X5   = 0x0000000000000004 X22  = 0x0000000000000000
> >> X6   = 0x0000000000000001 X23  = 0x00000000ffffffff
> >> X7   = 0x0000000000000000 X24  = 0x0000000010103140
> >> X8   = 0x0000000000000000 X25  = 0x0000000000000000
> >> X9   = 0xffffff80ffffffc8 X26  = 0x0000000000000000
> >> X10  = 0x0000000000000000 X27  = 0x0000000000000000
> >> X11  = 0x000000001010ca78 X28  = 0x0000000000000000
> >> X12  = 0x0000000000000001 FP   = 0x000000001010cc30
> >> X13  = 0x000000001fe00050 LR   = 0x0000000010001f94
> >> X14  = 0x0000000000000000 SP   = 0x000000001010cc30
> >> X15  = 0x0000000000000004 PC   = 0x00000000100125c0
> >> X16  = 0x000000001000f700 DAIF = 0x00000000000003c0
> >> VEC  = 0x0000000000000004 CPSR = 0x0000000060000005
> >> ESR  = EC: 0b100101 IL: 0b1 ISS: 0b0000000000000000001100001
> >>         Data Abort taken without a change in Exception level
> >> FAR  = 0x000000001fe000c0
> >> FPCR = 0x0000000000000000 FPSR = 0x0000000000000010
> >> The Versal (A72) fails in exactly the same way. The allocated address is
> >> 0x1fe00050 and the FAR is 0x1fe000c0 so I am not sure if the "0xc0 - 0x50"
> >> section is aligning the pointer to a larger word size for better performance and
> >> that first part is OK but the different word size breaks.
> > I'm running with a toolchain that was built with
> > --targetcflags="-DPREFER_SIZE_OVER_SPEED" which affects the content of the
> > memset function, so my memset is just loops of writes and seems to work fine.
> Oh. Maybe the eng manual needs a piece on this. Using flags on tool chains like
> this is fine for a user because it is use at your own peril however I believe
> patches need to be tested with the defaults for all tools. It is way to hard to
> baseline a BSP if tweaks are needed here and there.
We did try to merge this to the RSB as a temporary workaround for ilp32 issues.
Kinsey may have realized it had this impact also but I don't recall
being aware of
it.
We didn't want it to be a local hack. :)
> > Just out of curiousity, what instruction was at that PC address? If it was "dc
> > zva", then I had seen this a while back during initial AArch64 bringup and had
> > assumed it was fixed since the addition of the MMU code since that instruction
> > doesn't work on device memory.
> It this that instruction ...
>     100125c0:   d50b7423        dc      zva, x3
> Looks like it is not fixed.
I think your suggestion that FreeBSD should not use memset for device memory
is the right path though. But that could be in a lot of places. :(
> > It looks like bsp_section_nocacheheap sits inside bsp_section_nocachenoload
> > which is mapped as device memory which wouldn't play nicely with the "dc zva"
> > instruction.
> Cache coherent memory is mapped as device memory. The descriptors are mapped
> into it so checks of bits and updates are effected by caches.
> Chris
> devel mailing list
> devel at rtems.org
