[PATCH v2] rtems-kernel: Implement kernel recipe using waf
Ryan Long ryan.long at oarcorp.com
Tue Oct 19 13:52:31 UTC 2021
ping
-----Original Message-----
Sent: Wednesday, October 13, 2021 5:08 PM
To: devel at rtems.org
Cc: Ryan Long <ryan.long at oarcorp.com>
Subject: [PATCH v2] rtems-kernel: Implement kernel recipe using waf
Closes #4145
 rtems/config/tools/rtems-kernel-6.cfg      |   6 +-
 rtems/config/tools/rtems-kernel-common.cfg |  91 +++++++++----------
 source-builder/sb/options.py               | 136 +++++++++++++++--------------
 3 files changed, 119 insertions(+), 114 deletions(-)
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index f1d0990..9120862 100644
--- a/rtems/config/tools/rtems-kernel-6.cfg
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -2,10 +2,10 @@
 # RTEMS 5
-%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
-%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
-              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
+%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
+%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
+m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEwlV
+k3SRjjRFkFalDGQ==
 # The RTEMS build instructions.
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 157c7a4..2986580 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -38,6 +38,15 @@
 %define rtems_bsp %{with_rtems_bsp}
+# Configuration file used with waf
+%ifn %{defined _bspconfig}
+%define config_file config-%{_target}-%{rtems_bsp}.ini
+%else
+%define config_file %{_bspconfig}
+%endif
 # If no tools are provided use the prefix.
 %ifn %{defined with_tools}
@@ -98,14 +107,6 @@ URL: 	 https://www.rtems.org/
  %define rtems_posix 0
 %endif
-%if %{defined with_rtems_legacy_network}
- %define rtems_networking 1
-%endif
-%if %{defined with_rtems_cxx}
- %define rtems_cxx 1
-%endif
 %if %{defined with_rtems_bspopts}
  %define bspopts %{with_rtems_bspopts}
 %endif
@@ -151,24 +152,28 @@ URL: 	 https://www.rtems.org/
 %if %{defined without_rtemsbsp}
  %error Option --without-rtemsbsp is not supported.
 %endif
 %if %{defined without_rtems_tests}
- %define with_rtems_tests no
+ %define rtems_tests False
+ %define rtems_sample_tests False
 %endif
 %if %{defined with_rtems_tests}
  %if %{with_rtems_tests} == 1
-  %define with_rtems_tests yes
+   %define rtems_tests True
+   %define rtems_sample_tests True
  %endif
- %if %{with_rtems_tests} == yes || \
-     %{with_rtems_tests} == no || \
-     %{with_rtems_tests} == samples
-  %define rtems_tests %{with_rtems_tests}
+  %if %{with_rtems_tests} == samples
  %endif
 %endif
 %if %{defined with_rtems_smp}
  %define rtems_smp 1
 %endif
+ echo "RTEMS legacy network has been removed."
+ echo "Please review and update your configuration."
+ exit 1
 %endif
  %define rtems_bspopts %{with_rtems_bspopts}
@@ -178,7 +183,9 @@ URL: 	 https://www.rtems.org/
 # If C++ defined for the tool set use it to control RTEMS's setting..
 %if %{defined enable_cxx}
- %define rtems_cxx %{enable_cxx}
+ echo CXX has been removed."
+ exit 1
 %endif
@@ -188,14 +195,9 @@ URL: 	 https://www.rtems.org/
 %ifn %{defined rtems_posix}
  %define rtems_posix 1
 %endif
-%ifn %{defined rtems_networking}
- %define rtems_networking 0
-%endif
-%ifn %{defined rtems_cxx}
-%endif
 %ifn %{defined rtems_tests}
- %define rtems_tests samples
 %endif
 %ifn %{defined rtems_bspopts}
  %define rtems_bspopts %{nil}
@@ -213,8 +215,7 @@ URL: 	 https://www.rtems.org/
     %if %{defined _internal_autotools_path}
       export PATH="%{_internal_autotools_path}/bin:${PATH}"
     %endif
-    ./bootstrap -c
-    ./rtems-bootstrap
+    ./waf distclean
   %endif
   cd ..
@@ -225,32 +226,34 @@ URL: 	 https://www.rtems.org/
   else
     build_dir="build"
   fi
+  cd ${source_dir_rtems}
+  cpu=`echo %{_target} | cut -d- -f1`
+  echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
+  echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}"
+>> %{config_file}
+  echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >>
+%{config_file}
+  echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
+  echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file} %endif
   mkdir -p ${build_dir}
-  cd ${build_dir}
-  ../${source_dir_rtems}/configure \
-    --build=%{_build} --host=%{_host} \
-    --target=%{_target} \
-    --enable-rtemsbsp="%{rtems_bsp}" \
-    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
-    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
-    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
-    %{?rtems_tests:--enable-tests=%{rtems_tests}} \
-    %{?rtems_smp:--enable-smp} \
+  ./waf configure \
+    --rtems-bsps=%{_target}/%{rtems_bsp} \
     --prefix=%{_prefix} --bindir=%{_bindir} \
-    --exec-prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} --libdir=%{_libdir} \
-    --mandir=%{_mandir} --infodir=%{_infodir} \
-    %{rtems_bspopts}
+    --rtems-config=%{config_file}
+  ./waf %{?_smp_mflags}
-  %{__make} %{?_smp_mflags} all
   cd ..
 %install
   %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  ./waf --destdir=$SB_BUILD_ROOT install
   %if %{rtems_tests} != no
    %define rtems_test_install %{_target}/%{rtems_bsp}/tests
@@ -259,4 +262,4 @@ URL: 	 https://www.rtems.org/
       -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
   %endif
-  cd ..
+  cd -
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py index a0f196b..7d823ba 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -55,39 +55,40 @@ class command_line:
     def __init__(self, argv, optargs, _defaults, command_path):
         self._long_opts = {
             # key                       macro                handler            param  defs   init
-            '--prefix'               : ('_prefix',           self._lo_path,     True,  None,  False),
-            '--topdir'               : ('_topdir',           self._lo_path,     True,  None,  False),
-            '--configdir'            : ('_configdir',        self._lo_path,     True,  None,  False),
-            '--builddir'             : ('_builddir',         self._lo_path,     True,  None,  False),
-            '--sourcedir'            : ('_sourcedir',        self._lo_path,     True,  None,  False),
-            '--patchdir'             : ('_patchdir',         self._lo_path,     True,  None,  False),
-            '--tmppath'              : ('_tmppath',          self._lo_path,     True,  None,  False),
-            '--jobs'                 : ('_jobs',             self._lo_jobs,     True,  'max', True),
-            '--log'                  : ('_logfile',          self._lo_string,   True,  None,  False),
-            '--url'                  : ('_url_base',         self._lo_string,   True,  None,  False),
-            '--no-download'          : ('_disable_download', self._lo_bool,     False, '0',   True),
-            '--macros'               : ('_macros',           self._lo_string,   True,  None,  False),
-            '--source-only-download' : ('_source_download',  self._lo_bool,     False, '0',   True),
-            '--targetcflags'         : ('_targetcflags',     self._lo_string,   True,  None,  False),
-            '--targetcxxflags'       : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
-            '--libstdcxxflags'       : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
-            '--force'                : ('_force',            self._lo_bool,     False, '0',   True),
-            '--quiet'                : ('_quiet',            self._lo_bool,     False, '0',   True),
-            '--trace'                : ('_trace',            self._lo_bool,     False, '0',   True),
-            '--dry-run'              : ('_dry_run',          self._lo_bool,     False, '0',   True),
-            '--warn-all'             : ('_warn_all',         self._lo_bool,     False, '0',   True),
-            '--no-clean'             : ('_no_clean',         self._lo_bool,     False, '0',   True),
-            '--keep-going'           : ('_keep_going',       self._lo_bool,     False, '0',   True),
-            '--always-clean'         : ('_always_clean',     self._lo_bool,     False, '0',   True),
-            '--no-install'           : ('_no_install',       self._lo_bool,     False, '0',   True),
-            '--regression'           : ('_regression',       self._lo_bool,     False, '0',   True),
-            '--host'                 : ('_host',             self._lo_triplets, True,  None,  False),
-            '--build'                : ('_build',            self._lo_triplets, True,  None,  False),
-            '--target'               : ('_target',           self._lo_triplets, True,  None,  False),
-            '--rtems-tools'          : ('_rtems_tools',      self._lo_string,   True,  None,  False),
-            '--rtems-bsp'            : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
-            '--rtems-version'        : ('_rtems_version',    self._lo_string,   True,  None,  False),
-            '--help'                 : (None,                self._lo_help,     False, None,  False)
+            '--prefix'                : ('_prefix',           self._lo_path,     True,  None,  False),
+            '--topdir'                : ('_topdir',           self._lo_path,     True,  None,  False),
+            '--configdir'             : ('_configdir',        self._lo_path,     True,  None,  False),
+            '--builddir'              : ('_builddir',         self._lo_path,     True,  None,  False),
+            '--sourcedir'             : ('_sourcedir',        self._lo_path,     True,  None,  False),
+            '--patchdir'              : ('_patchdir',         self._lo_path,     True,  None,  False),
+            '--tmppath'               : ('_tmppath',          self._lo_path,     True,  None,  False),
+            '--jobs'                  : ('_jobs',             self._lo_jobs,     True,  'max', True),
+            '--log'                   : ('_logfile',          self._lo_string,   True,  None,  False),
+            '--with-rtems-bsp-config' : ('_bspconfig',        self._lo_path,     True,  None,  False),
+            '--url'                   : ('_url_base',         self._lo_string,   True,  None,  False),
+            '--no-download'           : ('_disable_download', self._lo_bool,     False, '0',   True),
+            '--macros'                : ('_macros',           self._lo_string,   True,  None,  False),
+            '--source-only-download'  : ('_source_download',  self._lo_bool,     False, '0',   True),
+            '--targetcflags'          : ('_targetcflags',     self._lo_string,   True,  None,  False),
+            '--targetcxxflags'        : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
+            '--libstdcxxflags'        : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
+            '--force'                 : ('_force',            self._lo_bool,     False, '0',   True),
+            '--quiet'                 : ('_quiet',            self._lo_bool,     False, '0',   True),
+            '--trace'                 : ('_trace',            self._lo_bool,     False, '0',   True),
+            '--dry-run'               : ('_dry_run',          self._lo_bool,     False, '0',   True),
+            '--warn-all'              : ('_warn_all',         self._lo_bool,     False, '0',   True),
+            '--no-clean'              : ('_no_clean',         self._lo_bool,     False, '0',   True),
+            '--keep-going'            : ('_keep_going',       self._lo_bool,     False, '0',   True),
+            '--always-clean'          : ('_always_clean',     self._lo_bool,     False, '0',   True),
+            '--no-install'            : ('_no_install',       self._lo_bool,     False, '0',   True),
+            '--regression'            : ('_regression',       self._lo_bool,     False, '0',   True),
+            '--host'                  : ('_host',             self._lo_triplets, True,  None,  False),
+            '--build'                 : ('_build',            self._lo_triplets, True,  None,  False),
+            '--target'                : ('_target',           self._lo_triplets, True,  None,  False),
+            '--rtems-tools'           : ('_rtems_tools',      self._lo_string,   True,  None,  False),
+            '--rtems-bsp'             : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
+            '--rtems-version'         : ('_rtems_version',    self._lo_string,   True,  None,  False),
+            '--help'                  : (None,                self._lo_help,     False, None,  False)
         self.command_path = command_path @@ -203,40 +204,41 @@ class command_line:
         print('%s: [options] [args]' % (self.command_name))
         print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2019 Chris Johns')
         print('Options and arguments:')
-        print('--force                : Force the build to proceed')
-        print('--quiet                : Quiet output (not used)')
-        print('--trace                : Trace the execution')
-        print('--dry-run              : Do everything but actually run the build')
-        print('--warn-all             : Generate warnings')
-        print('--no-clean             : Do not clean up the build tree')
-        print('--always-clean         : Always clean the build tree, even with an error')
-        print('--keep-going           : Do not stop on an error.')
-        print('--regression           : Set --no-install, --keep-going and --always-clean')
-        print('--jobs                 : Run with specified number of jobs, default: num CPUs.')
-        print('--host                 : Set the host triplet')
-        print('--build                : Set the build triplet')
-        print('--target               : Set the target triplet')
-        print('--prefix path          : Tools build prefix, ie where they are installed')
-        print('--topdir path          : Top of the build tree, default is $PWD')
-        print('--configdir path       : Path to the configuration directory, default: ./config')
-        print('--builddir path        : Path to the build directory, default: ./build')
-        print('--sourcedir path       : Path to the source directory, default: ./source')
-        print('--patchdir path        : Path to the patches directory, default: ./patches')
-        print('--tmppath path         : Path to the temp directory, default: ./tmp')
-        print('--macros file[,[file]  : Macro format files to load after the defaults')
-        print('--log file             : Log file where all build out is written too')
-        print('--url url[,url]        : URL to look for source')
-        print('--no-download          : Disable the source downloader')
-        print('--no-install           : Do not install the packages to the prefix')
-        print('--targetcflags flags   : List of C flags for the target code')
-        print('--targetcxxflags flags : List of C++ flags for the target code')
-        print('--libstdcxxflags flags : List of C++ flags to build the target libstdc++ code')
-        print('--source-only-download : Only download the source')
-        print('--with-<label>         : Add the --with-<label> to the build')
-        print('--without-<label>      : Add the --without-<label> to the build')
-        print('--rtems-tools path     : Path to an install RTEMS tool set')
-        print('--rtems-bsp arc/bsp    : Standard RTEMS architecure and BSP specifier')
-        print('--rtems-version ver    : The RTEMS major/minor version string')
+        print('--force                 : Force the build to proceed')
+        print('--quiet                 : Quiet output (not used)')
+        print('--trace                 : Trace the execution')
+        print('--dry-run               : Do everything but actually run the build')
+        print('--warn-all              : Generate warnings')
+        print('--no-clean              : Do not clean up the build tree')
+        print('--always-clean          : Always clean the build tree, even with an error')
+        print('--keep-going            : Do not stop on an error.')
+        print('--regression            : Set --no-install, --keep-going and --always-clean')
+        print('--jobs                  : Run with specified number of jobs, default: num CPUs.')
+        print('--host                  : Set the host triplet')
+        print('--build                 : Set the build triplet')
+        print('--target                : Set the target triplet')
+        print('--prefix path           : Tools build prefix, ie where they are installed')
+        print('--topdir path           : Top of the build tree, default is $PWD')
+        print('--configdir path        : Path to the configuration directory, default: ./config')
+        print('--builddir path         : Path to the build directory, default: ./build')
+        print('--sourcedir path        : Path to the source directory, default: ./source')
+        print('--patchdir path         : Path to the patches directory, default: ./patches')
+        print('--tmppath path          : Path to the temp directory, default: ./tmp')
+        print('--macros file[,[file]   : Macro format files to load after the defaults')
+        print('--log file              : Log file where all build out is written too')
+        print('--with-rtems-bsp-config : Configuration file to use')
+        print('--url url[,url]         : URL to look for source')
+        print('--no-download           : Disable the source downloader')
+        print('--no-install            : Do not install the packages to the prefix')
+        print('--targetcflags flags    : List of C flags for the target code')
+        print('--targetcxxflags flags  : List of C++ flags for the target code')
+        print('--libstdcxxflags flags  : List of C++ flags to build the target libstdc++ code')
+        print('--source-only-download  : Only download the source')
+        print('--with-<label>          : Add the --with-<label> to the build')
+        print('--without-<label>       : Add the --without-<label> to the build')
+        print('--rtems-tools path      : Path to an install RTEMS tool set')
+        print('--rtems-bsp arc/bsp     : Standard RTEMS architecure and BSP specifier')
+        print('--rtems-version ver     : The RTEMS major/minor version string')
         if self.optargs:
             for a in self.optargs:
                 print('%-22s : %s' % (a, self.optargs[a]))
1.8.3.1
