[PATCH v2] rtems-kernel: Implement kernel recipe using waf
Thu Oct 21 03:35:27 UTC 2021
On 14/10/21 9:08 am, Ryan Long wrote:
> Closes #4145
>  rtems/config/tools/rtems-kernel-6.cfg      |   6 +-
>  rtems/config/tools/rtems-kernel-common.cfg |  91 +++++++++----------
>  source-builder/sb/options.py               | 136 +++++++++++++++--------------
>  3 files changed, 119 insertions(+), 114 deletions(-)
> diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
> index f1d0990..9120862 100644
> --- a/rtems/config/tools/rtems-kernel-6.cfg
> +++ b/rtems/config/tools/rtems-kernel-6.cfg
> @@ -2,10 +2,10 @@
>  # RTEMS 5
> -%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
> -%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
> -              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
> +%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
> +%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
> +              m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEwlVk3SRjjRFkFalDGQ==
>  # The RTEMS build instructions.
> diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
> index 157c7a4..2986580 100644
> --- a/rtems/config/tools/rtems-kernel-common.cfg
> +++ b/rtems/config/tools/rtems-kernel-common.cfg
> @@ -38,6 +38,15 @@
>  %define rtems_bsp %{with_rtems_bsp}
> +# Configuration file used with waf
> +%ifn %{defined _bspconfig}
> +%define config_file config-%{_target}-%{rtems_bsp}.ini
> +%else
> +%define config_file %{_bspconfig}
> +%endif
This is not right given the way --with-* is handled.
>  # If no tools are provided use the prefix.
>  %ifn %{defined with_tools}
> @@ -98,14 +107,6 @@ URL: 	 https://www.rtems.org/
>   %define rtems_posix 0
>  %endif
> -%if %{defined with_rtems_legacy_network}
> - %define rtems_networking 1
> -%endif
> -%if %{defined with_rtems_cxx}
> - %define rtems_cxx 1
> -%endif
>  %if %{defined with_rtems_bspopts}
>   %define bspopts %{with_rtems_bspopts}
>  %endif
> @@ -151,24 +152,28 @@ URL: 	 https://www.rtems.org/
>  %if %{defined without_rtemsbsp}
>   %error Option --without-rtemsbsp is not supported.
>  %endif
>  %if %{defined without_rtems_tests}
> - %define with_rtems_tests no
> + %define rtems_tests False
> + %define rtems_sample_tests False
>  %endif
>  %if %{defined with_rtems_tests}
>   %if %{with_rtems_tests} == 1
> -  %define with_rtems_tests yes
> +   %define rtems_tests True
> +   %define rtems_sample_tests True
>   %endif
> - %if %{with_rtems_tests} == yes || \
> -     %{with_rtems_tests} == no || \
> -     %{with_rtems_tests} == samples
> -  %define rtems_tests %{with_rtems_tests}
> +  %if %{with_rtems_tests} == samples
>   %endif
>  %endif
>  %if %{defined with_rtems_smp}
>   %define rtems_smp 1
>  %endif
> + echo "RTEMS legacy network has been removed."
> + echo "Please review and update your configuration."
> + exit 1
>  %endif
>   %define rtems_bspopts %{with_rtems_bspopts}
> @@ -178,7 +183,9 @@ URL: 	 https://www.rtems.org/
>  # If C++ defined for the tool set use it to control RTEMS's setting..
>  %if %{defined enable_cxx}
> - %define rtems_cxx %{enable_cxx}
> + echo CXX has been removed."
> + exit 1
>  %endif
> @@ -188,14 +195,9 @@ URL: 	 https://www.rtems.org/
>  %ifn %{defined rtems_posix}
>   %define rtems_posix 1
>  %endif
> -%ifn %{defined rtems_networking}
> - %define rtems_networking 0
> -%endif
> -%ifn %{defined rtems_cxx}
> -%endif
>  %ifn %{defined rtems_tests}
> - %define rtems_tests samples
>  %endif
>  %ifn %{defined rtems_bspopts}
>   %define rtems_bspopts %{nil}
> @@ -213,8 +215,7 @@ URL: 	 https://www.rtems.org/
>      %if %{defined _internal_autotools_path}
>        export PATH="%{_internal_autotools_path}/bin:${PATH}"
>      %endif
> -    ./bootstrap -c
> -    ./rtems-bootstrap
> +    ./waf distclean
The sources need to be fresh on every build if building in the source tree. Is
this needed?
>    %endif
>    cd ..
> @@ -225,32 +226,34 @@ URL: 	 https://www.rtems.org/
>    else
>      build_dir="build"
>    fi
> +  cd ${source_dir_rtems}
> +  cpu=`echo %{_target} | cut -d- -f1`
> +  echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
> +  echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}" >> %{config_file}
> +  echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >> %{config_file}
> +  echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
> +  echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file}
> +%endif
>    mkdir -p ${build_dir}
> -  cd ${build_dir}
> -  ../${source_dir_rtems}/configure \
> -    --build=%{_build} --host=%{_host} \
> -    --target=%{_target} \
> -    --enable-rtemsbsp="%{rtems_bsp}" \
> -    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
> -    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
> -    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
> -    %{?rtems_tests:--enable-tests=%{rtems_tests}} \
> -    %{?rtems_smp:--enable-smp} \
> +  ./waf configure \
> +    --rtems-bsps=%{_target}/%{rtems_bsp} \
>      --prefix=%{_prefix} --bindir=%{_bindir} \
> -    --exec-prefix=%{_exec_prefix} \
> -    --includedir=%{_includedir} --libdir=%{_libdir} \
> -    --mandir=%{_mandir} --infodir=%{_infodir} \
> -    %{rtems_bspopts}
> +    --rtems-config=%{config_file}
> +  ./waf %{?_smp_mflags}
> -  %{__make} %{?_smp_mflags} all
>    cd ..
>  %install
>    %{__rmdir} $SB_BUILD_ROOT
> -  cd ${build_dir}
> -  %{__make} DESTDIR=$SB_BUILD_ROOT install
> +  ./waf --destdir=$SB_BUILD_ROOT install
>    %if %{rtems_tests} != no
How does this get handled if the user supplies the config file?
>     %define rtems_test_install %{_target}/%{rtems_bsp}/tests
> @@ -259,4 +262,4 @@ URL: 	 https://www.rtems.org/
>        -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
>    %endif
> -  cd ..
> +  cd -
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index a0f196b..7d823ba 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -55,39 +55,40 @@ class command_line:
>      def __init__(self, argv, optargs, _defaults, command_path):
>          self._long_opts = {
>              # key                       macro                handler            param  defs   init
> -            '--prefix'               : ('_prefix',           self._lo_path,     True,  None,  False),
> -            '--topdir'               : ('_topdir',           self._lo_path,     True,  None,  False),
> -            '--configdir'            : ('_configdir',        self._lo_path,     True,  None,  False),
> -            '--builddir'             : ('_builddir',         self._lo_path,     True,  None,  False),
> -            '--sourcedir'            : ('_sourcedir',        self._lo_path,     True,  None,  False),
> -            '--patchdir'             : ('_patchdir',         self._lo_path,     True,  None,  False),
> -            '--tmppath'              : ('_tmppath',          self._lo_path,     True,  None,  False),
> -            '--jobs'                 : ('_jobs',             self._lo_jobs,     True,  'max', True),
> -            '--log'                  : ('_logfile',          self._lo_string,   True,  None,  False),
> -            '--url'                  : ('_url_base',         self._lo_string,   True,  None,  False),
> -            '--no-download'          : ('_disable_download', self._lo_bool,     False, '0',   True),
> -            '--macros'               : ('_macros',           self._lo_string,   True,  None,  False),
> -            '--source-only-download' : ('_source_download',  self._lo_bool,     False, '0',   True),
> -            '--targetcflags'         : ('_targetcflags',     self._lo_string,   True,  None,  False),
> -            '--targetcxxflags'       : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
> -            '--libstdcxxflags'       : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
> -            '--force'                : ('_force',            self._lo_bool,     False, '0',   True),
> -            '--quiet'                : ('_quiet',            self._lo_bool,     False, '0',   True),
> -            '--trace'                : ('_trace',            self._lo_bool,     False, '0',   True),
> -            '--dry-run'              : ('_dry_run',          self._lo_bool,     False, '0',   True),
> -            '--warn-all'             : ('_warn_all',         self._lo_bool,     False, '0',   True),
> -            '--no-clean'             : ('_no_clean',         self._lo_bool,     False, '0',   True),
> -            '--keep-going'           : ('_keep_going',       self._lo_bool,     False, '0',   True),
> -            '--always-clean'         : ('_always_clean',     self._lo_bool,     False, '0',   True),
> -            '--no-install'           : ('_no_install',       self._lo_bool,     False, '0',   True),
> -            '--regression'           : ('_regression',       self._lo_bool,     False, '0',   True),
> -            '--host'                 : ('_host',             self._lo_triplets, True,  None,  False),
> -            '--build'                : ('_build',            self._lo_triplets, True,  None,  False),
> -            '--target'               : ('_target',           self._lo_triplets, True,  None,  False),
> -            '--rtems-tools'          : ('_rtems_tools',      self._lo_string,   True,  None,  False),
> -            '--rtems-bsp'            : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
> -            '--rtems-version'        : ('_rtems_version',    self._lo_string,   True,  None,  False),
> -            '--help'                 : (None,                self._lo_help,     False, None,  False)
> +            '--prefix'                : ('_prefix',           self._lo_path,     True,  None,  False),
> +            '--topdir'                : ('_topdir',           self._lo_path,     True,  None,  False),
> +            '--configdir'             : ('_configdir',        self._lo_path,     True,  None,  False),
> +            '--builddir'              : ('_builddir',         self._lo_path,     True,  None,  False),
> +            '--sourcedir'             : ('_sourcedir',        self._lo_path,     True,  None,  False),
> +            '--patchdir'              : ('_patchdir',         self._lo_path,     True,  None,  False),
> +            '--tmppath'               : ('_tmppath',          self._lo_path,     True,  None,  False),
> +            '--jobs'                  : ('_jobs',             self._lo_jobs,     True,  'max', True),
> +            '--log'                   : ('_logfile',          self._lo_string,   True,  None,  False),
> +            '--with-rtems-bsp-config' : ('_bspconfig',        self._lo_path,     True,  None,  False),
--with-* and --without- has special handling. This is not needed.
> +            '--url'                   : ('_url_base',         self._lo_string,   True,  None,  False),
> +            '--no-download'           : ('_disable_download', self._lo_bool,     False, '0',   True),
> +            '--macros'                : ('_macros',           self._lo_string,   True,  None,  False),
> +            '--source-only-download'  : ('_source_download',  self._lo_bool,     False, '0',   True),
> +            '--targetcflags'          : ('_targetcflags',     self._lo_string,   True,  None,  False),
> +            '--targetcxxflags'        : ('_targetcxxflags',   self._lo_string,   True,  None,  False),
> +            '--libstdcxxflags'        : ('_libstdcxxflags',   self._lo_string,   True,  None,  False),
> +            '--force'                 : ('_force',            self._lo_bool,     False, '0',   True),
> +            '--quiet'                 : ('_quiet',            self._lo_bool,     False, '0',   True),
> +            '--trace'                 : ('_trace',            self._lo_bool,     False, '0',   True),
> +            '--dry-run'               : ('_dry_run',          self._lo_bool,     False, '0',   True),
> +            '--warn-all'              : ('_warn_all',         self._lo_bool,     False, '0',   True),
> +            '--no-clean'              : ('_no_clean',         self._lo_bool,     False, '0',   True),
> +            '--keep-going'            : ('_keep_going',       self._lo_bool,     False, '0',   True),
> +            '--always-clean'          : ('_always_clean',     self._lo_bool,     False, '0',   True),
> +            '--no-install'            : ('_no_install',       self._lo_bool,     False, '0',   True),
> +            '--regression'            : ('_regression',       self._lo_bool,     False, '0',   True),
> +            '--host'                  : ('_host',             self._lo_triplets, True,  None,  False),
> +            '--build'                 : ('_build',            self._lo_triplets, True,  None,  False),
> +            '--target'                : ('_target',           self._lo_triplets, True,  None,  False),
> +            '--rtems-tools'           : ('_rtems_tools',      self._lo_string,   True,  None,  False),
> +            '--rtems-bsp'             : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
> +            '--rtems-version'         : ('_rtems_version',    self._lo_string,   True,  None,  False),
> +            '--help'                  : (None,                self._lo_help,     False, None,  False)
>          self.command_path = command_path
> @@ -203,40 +204,41 @@ class command_line:
>          print('%s: [options] [args]' % (self.command_name))
>          print('RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2019 Chris Johns')
>          print('Options and arguments:')
> -        print('--force                : Force the build to proceed')
> -        print('--quiet                : Quiet output (not used)')
> -        print('--trace                : Trace the execution')
> -        print('--dry-run              : Do everything but actually run the build')
> -        print('--warn-all             : Generate warnings')
> -        print('--no-clean             : Do not clean up the build tree')
> -        print('--always-clean         : Always clean the build tree, even with an error')
> -        print('--keep-going           : Do not stop on an error.')
> -        print('--regression           : Set --no-install, --keep-going and --always-clean')
> -        print('--jobs                 : Run with specified number of jobs, default: num CPUs.')
> -        print('--host                 : Set the host triplet')
> -        print('--build                : Set the build triplet')
> -        print('--target               : Set the target triplet')
> -        print('--prefix path          : Tools build prefix, ie where they are installed')
> -        print('--topdir path          : Top of the build tree, default is $PWD')
> -        print('--configdir path       : Path to the configuration directory, default: ./config')
> -        print('--builddir path        : Path to the build directory, default: ./build')
> -        print('--sourcedir path       : Path to the source directory, default: ./source')
> -        print('--patchdir path        : Path to the patches directory, default: ./patches')
> -        print('--tmppath path         : Path to the temp directory, default: ./tmp')
> -        print('--macros file[,[file]  : Macro format files to load after the defaults')
> -        print('--log file             : Log file where all build out is written too')
> -        print('--url url[,url]        : URL to look for source')
> -        print('--no-download          : Disable the source downloader')
> -        print('--no-install           : Do not install the packages to the prefix')
> -        print('--targetcflags flags   : List of C flags for the target code')
> -        print('--targetcxxflags flags : List of C++ flags for the target code')
> -        print('--libstdcxxflags flags : List of C++ flags to build the target libstdc++ code')
> -        print('--source-only-download : Only download the source')
> -        print('--with-<label>         : Add the --with-<label> to the build')
> -        print('--without-<label>      : Add the --without-<label> to the build')
> -        print('--rtems-tools path     : Path to an install RTEMS tool set')
> -        print('--rtems-bsp arc/bsp    : Standard RTEMS architecure and BSP specifier')
> -        print('--rtems-version ver    : The RTEMS major/minor version string')
> +        print('--force                 : Force the build to proceed')
> +        print('--quiet                 : Quiet output (not used)')
> +        print('--trace                 : Trace the execution')
> +        print('--dry-run               : Do everything but actually run the build')
> +        print('--warn-all              : Generate warnings')
> +        print('--no-clean              : Do not clean up the build tree')
> +        print('--always-clean          : Always clean the build tree, even with an error')
> +        print('--keep-going            : Do not stop on an error.')
> +        print('--regression            : Set --no-install, --keep-going and --always-clean')
> +        print('--jobs                  : Run with specified number of jobs, default: num CPUs.')
> +        print('--host                  : Set the host triplet')
> +        print('--build                 : Set the build triplet')
> +        print('--target                : Set the target triplet')
> +        print('--prefix path           : Tools build prefix, ie where they are installed')
> +        print('--topdir path           : Top of the build tree, default is $PWD')
> +        print('--configdir path        : Path to the configuration directory, default: ./config')
> +        print('--builddir path         : Path to the build directory, default: ./build')
> +        print('--sourcedir path        : Path to the source directory, default: ./source')
> +        print('--patchdir path         : Path to the patches directory, default: ./patches')
> +        print('--tmppath path          : Path to the temp directory, default: ./tmp')
> +        print('--macros file[,[file]   : Macro format files to load after the defaults')
> +        print('--log file              : Log file where all build out is written too')
> +        print('--with-rtems-bsp-config : Configuration file to use')
> +        print('--url url[,url]         : URL to look for source')
> +        print('--no-download           : Disable the source downloader')
> +        print('--no-install            : Do not install the packages to the prefix')
> +        print('--targetcflags flags    : List of C flags for the target code')
> +        print('--targetcxxflags flags  : List of C++ flags for the target code')
> +        print('--libstdcxxflags flags  : List of C++ flags to build the target libstdc++ code')
> +        print('--source-only-download  : Only download the source')
> +        print('--with-<label>          : Add the --with-<label> to the build')
> +        print('--without-<label>       : Add the --without-<label> to the build')
> +        print('--rtems-tools path      : Path to an install RTEMS tool set')
> +        print('--rtems-bsp arc/bsp     : Standard RTEMS architecure and BSP specifier')
> +        print('--rtems-version ver     : The RTEMS major/minor version string')
>          if self.optargs:
>              for a in self.optargs:
>                  print('%-22s : %s' % (a, self.optargs[a]))
