[PATCH] testsuite/spcache01: Clear allocated coherent cache memory
Sebastian Huber
Tue Oct 19 14:48:49 UTC 2021
On 18/10/2021 23:08, Chris Johns wrote:
> On 18/10/21 8:37 pm, Sebastian Huber wrote:
>> On 18/10/2021 09:53, Chris Johns wrote:
>>> On 18/10/21 4:50 pm, Sebastian Huber wrote:
>>>> On 18/10/2021 07:19,chrisj at rtems.org wrote:
>>>>> From: Chris Johns<chrisj at rtems.org>
>>>>> - Coherent cache memory is used in libbsd for things like descriptors
>>>>> and it optionally clears the memory on allocation. Test is works.
>>>> There is no guarantee that memset() and memcpy() work with cache coherent
>>>> memory. Such memory areas may disallow misaligned access for example.
>>> That seems reasonable however this change about testing the implicit
>>> requirements we have that memset works. LibBSD requires memset works ...
>>> https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-kernel-bus-dma.c?h=6-freebsd-12#n260
>> Using memset() here could be a bug in libbsd.
> Yes, I also think so.
> But what is a suitable mechanism to make sure the arch or BSP handle it
> correctly? Maybe a clear routine in libbsd using the bus space API? That
> interface has to work or the drivers will not work.
I think we had similar issues on another BSP. Christian, do you remember
how we solved this?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
