[PATCH] testsuite/spcache01: Clear allocated coherent cache memory
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Oct 19 15:46:52 UTC 2021
Am 19.10.21 um 16:48 schrieb Sebastian Huber:
> On 18/10/2021 23:08, Chris Johns wrote:
>> On 18/10/21 8:37 pm, Sebastian Huber wrote:
>>> On 18/10/2021 09:53, Chris Johns wrote:
>>>> On 18/10/21 4:50 pm, Sebastian Huber wrote:
>>>>> On 18/10/2021 07:19,chrisj at rtems.org   wrote:
>>>>>> From: Chris Johns<chrisj at rtems.org>
>>>>>> - Coherent cache memory is used in libbsd for things like descriptors
>>>>>>      and it optionally clears the memory on allocation. Test is
>>>>>> works.
>>>>> There is no guarantee that memset() and memcpy() work with cache
>>>>> coherent
>>>>> memory. Such memory areas may disallow misaligned access for example.
>>>> That seems reasonable however this change about testing the implicit
>>>> requirements we have that memset works. LibBSD requires memset works
>>>> https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-kernel-bus-dma.c?h=6-freebsd-12#n260
>>> Using memset() here could be a bug in libbsd.
>> Yes, I also think so.
>> But what is a suitable mechanism to make sure the arch or BSP handle it
>> correctly? Maybe a clear routine in libbsd using the bus space API? That
>> interface has to work or the drivers will not work.
> I think we had similar issues on another BSP. Christian, do you remember
> how we solved this?
I remember mainly problems with copying memory. I think the last time it
resulted in an ugly "copy_from/to_io" function on the atsam:
   https://git.rtems.org/rtems/tree/bsps/arm/atsam/start/iocopy.c
The bus_space_* functions should work. Only problem is that a valid
bus_space_tag is missing in this context. I think x86 uses it. I think
for all other platforms it is unused.
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
