[PATCH 4/4] Add support for Xilinx Versal APAC
chrisj at rtems.org chrisj at rtems.org
Wed Oct 20 03:16:35 UTC 2021
 libbsd.py                                     |   1 +
 rtemsbsd/include/bsp/nexus-devices.h          |   9 +
 .../include/machine/rtems-bsd-nexus-bus.h     |  28 +++
 rtemsbsd/sys/arm64/xilinx/versal_slcr.c       | 223 ++++++++++++++++++
 rtemsbsd/sys/arm64/xilinx/versal_slcr.h       |  86 +++++++
 5 files changed, 347 insertions(+)
 create mode 100644 rtemsbsd/sys/arm64/xilinx/versal_slcr.c
 create mode 100644 rtemsbsd/sys/arm64/xilinx/versal_slcr.h
diff --git a/libbsd.py b/libbsd.py
index b27b95d8..7593e9ba 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -1478,6 +1478,7 @@ class dev_net(builder.Module):
         self.addRTEMSKernelSourceFiles(
                 'sys/dev/mii/ksz8091rnb_50MHz.c',
+                'sys/arm64/xilinx/versal_slcr.c',
                 'sys/arm64/xilinx/zynqmp_slcr.c',
             mm.generator['source']()
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 4c13e868..46df17b4 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -126,6 +126,15 @@ RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0;
 RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1;
 RTEMS_BSD_DRIVER_MMC;
+#elif defined(LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
+#include <bsp/irq.h>
+RTEMS_BSD_DRIVER_XILINX_VERSAL_SLCR;
+RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM0(VERSAL_IRQ_ETHERNET_0);
+RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM1(VERSAL_IRQ_ETHERNET_1);
+RTEMS_BSD_DRIVER_UKPHY;
 #elif defined(LIBBSP_ARM_ATSAM_BSP_H)
 RTEMS_BSD_DRIVER_USB;
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index f0987513..9e1e725a 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -139,6 +139,26 @@ extern "C" {
                                   &zynqmp_slcr_res[0])
 #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR */
+ * Xilinx Versal System Level Control Registers (SLCR).
+#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_SLCR)
+   * Hard IP part of the Versal so a fixed address.
+  #define RTEMS_BSD_DRIVER_XILINX_VERSAL_SLCR                           \
+    static const rtems_bsd_device_resource versal_slcr_res[] = {        \
+        .type = RTEMS_BSD_RES_MEMORY,                                   \
+        .start_request = 0,                                             \
+        .start_actual = 0xf0000000                                      \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(versal_slcr, 0,                       \
+                                  RTEMS_ARRAY_SIZE(versal_slcr_res),   \
+                                  &versal_slcr_res[0])
+#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_SLCR */
  * Xilinx ZynqMP Arasan SDIO Driver.
@@ -489,6 +509,14 @@ extern "C" {
   #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(_irq)       \
     RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(3, 0xff0e0000, _irq)
 #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3 */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM0)
+  #define RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM0(_irq)       \
+    RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(0, 0xff0c0000, _irq)
+#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM0 */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM1)
+  #define RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM1(_irq)                \
+    RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(1, 0xff0d0000, _irq)
+#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_CGEM1 */
  * Designware/Synopsys Ethernet MAC Controller.
diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.c b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
new file mode 100644
index 00000000..74ebde91
--- /dev/null
+++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
@@ -0,0 +1,223 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2021 Chris Johns <chrisj at rtems.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * Versal ACAP SLCR driver.  Provides hook for CGEM clocks.
+ * Reference:
+ *   https://www.xilinx.com/html_docs/registers/am012/mod___crl.html
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <bsp.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/sysctl.h>
+#include <sys/rman.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#include <machine/stdarg.h>
+#include <arm64/xilinx/versal_slcr.h>
+struct versal_slcr_softc {
+	device_t	dev;
+	struct mtx	sc_mtx;
+	struct resource	*mem_res;
+static struct versal_slcr_softc *versal_slcr_softc_p;
+#define RD4(sc, off) 		(bus_read_4((sc)->mem_res, (off)))
+#define WR4(sc, off, val) 	(bus_write_4((sc)->mem_res, (off), (val)))
+SYSCTL_NODE(_hw, OID_AUTO, versal, CTLFLAG_RD, 0, "Xilinx Versal ACAP SLCR");
+#if defined(LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
+/* Override cgem_set_refclk() in gigabit ethernet driver
+ * (sys/dev/cadence/if_cgem.c).  This function is called to
+ * request a change in the gem's reference clock speed.
+int
+cgem_set_ref_clk(int unit, int frequency)
+	struct versal_slcr_softc *sc = versal_slcr_softc_p;
+	int div, last_error = 0;
+	uint64_t clk_ctrl, pll_ctrl;
+	uint32_t clk_ctrl_val, pll_ctrl_val, pll_freq, pll_reset, pll_bypass;
+	if (!sc)
+		return (-1);
+	switch (unit) {
+		case 0:
+			clk_ctrl = VERSAL_SLCR_GEM0_CLK_CTRL;
+			break;
+		case 1:
+			clk_ctrl = VERSAL_SLCR_GEM1_CLK_CTRL;
+			break;
+		default:
+			return (-1);
+	clk_ctrl_val = RD4(sc, clk_ctrl);
+	switch (clk_ctrl_val & VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_MASK) {
+		case VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_P_PLL:
+			pll_ctrl = VERSAL_SLCR_P_PLL_CTRL;
+			break;
+		case VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_R_PLL:
+			pll_ctrl = VERSAL_SLCR_R_PLL_CTRL;
+			break;
+		case VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL:
+			pll_ctrl = VERSAL_SLCR_N_PLL_CTRL;
+			break;
+		default:
+			return (-1);
+	/* Get PLL frequency */
+	pll_ctrl_val = RD4(sc, pll_ctrl);
+	pll_reset = (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_RESET) != 0;
+	pll_bypass = (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_BYPASS) != 0;
+	if (pll_reset && !pll_bypass) {
+		return 0;
+	pll_freq = VERSAL_DEFAULT_PS_CLK_FREQUENCY;
+	if (!pll_bypass) {
+		pll_freq *= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_FBDIV_MASK) >> VERSAL_SLCR_PLL_CTRL_FBDIV_SHIFT;
+	/* Apply divider */
+  pll_freq >>= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_DIV_MASK) >> VERSAL_SLCR_PLL_CTRL_DIV_SHIFT;
+	/* Find suitable divisor. Linear search, not the fastest method but hey.
+	for (div = 1; div <= VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX; div++) {
+    int div_freq = pll_freq / div;
+		int error = abs(frequency - div_freq);
+		if (error >= last_error && last_error != 0) {
+      div--;
+			break;
+		last_error = error;
+	if (div > VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX)
+		return (-1);
+	/* Modify GEM reference clock. */
+	clk_ctrl_val &= ~VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MASK;
+	clk_ctrl_val |= div << VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_SHIFT;
+	WR4(sc, clk_ctrl, clk_ctrl_val);
+	return (0);
+#endif
+static int
+versal_slcr_probe(device_t dev)
+	device_set_desc(dev, "Versal ACAP SLCR block");
+	return (0);
+static int
+versal_slcr_attach(device_t dev)
+	struct versal_slcr_softc *sc = device_get_softc(dev);
+	int rid;
+	/* Allow only one attach. */
+	if (versal_slcr_softc_p != NULL)
+		return (ENXIO);
+	sc->dev = dev;
+	/* Get memory resource. */
+	rid = 0;
+	sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+					     RF_ACTIVE);
+	if (sc->mem_res == NULL) {
+		device_printf(dev, "could not allocate memory resources.\n");
+		return (ENOMEM);
+	/* For use with CGEM clock setting */
+	versal_slcr_softc_p = sc;
+	return (0);
+static int
+versal_slcr_detach(device_t dev)
+	bus_generic_detach(dev);
+	/* Release memory resource. */
+	if (sc->mem_res != NULL)
+		bus_release_resource(dev, SYS_RES_MEMORY,
+			     rman_get_rid(sc->mem_res), sc->mem_res);
+	versal_slcr_softc_p = NULL;
+	return (0);
+static device_method_t versal_slcr_methods[] = {
+	/* device_if */
+	DEVMETHOD(device_probe, 	versal_slcr_probe),
+	DEVMETHOD(device_attach, 	versal_slcr_attach),
+	DEVMETHOD(device_detach, 	versal_slcr_detach),
+	DEVMETHOD_END
+static driver_t versal_slcr_driver = {
+	"versal_slcr",
+	versal_slcr_methods,
+	sizeof(struct versal_slcr_softc),
+static devclass_t versal_slcr_devclass;
+DRIVER_MODULE(versal_slcr, nexus, versal_slcr_driver, versal_slcr_devclass, 0, 0);
+MODULE_VERSION(versal_slcr, 1);
diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.h b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
index 00000000..e1c967ac
--- /dev/null
+++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
@@ -0,0 +1,86 @@
+ * are met:
+ * SUCH DAMAGE.
+ * Defines for Xilinx Versal ACAP SLCR registers.
+ * Reference:
+#ifndef _VERSAL_SLCR_H_
+#define _VERSAL_SLCR_H_
+#define VERSAL_SLCR_CRF_OFFSET		0x01260000
+#define VERSAL_SLCR_CRL_OFFSET		0x0f5e0000
+ * PLL controls
+ * P = PPLL = PMCPLL = PMCPLL_CTRL : PMC PLL Clock
+ * N = NPLL = NOCPLL = NOCPLL_CTRL : NOC PLL Clock
+ * R = RPLL = RPLL_CTRL            : Low Power Domain clock
+#define VERSAL_SLCR_P_PLL_CTRL		(VERSAL_SLCR_CRF_OFFSET + 0x40)
+#define VERSAL_SLCR_N_PLL_CTRL		(VERSAL_SLCR_CRF_OFFSET + 0x50)
+#define VERSAL_SLCR_R_PLL_CTRL		(VERSAL_SLCR_CRL_OFFSET + 0x40)
+#define   VERSAL_SLCR_PLL_CTRL_RESET		(1<<0)
+#define   VERSAL_SLCR_PLL_CTRL_BYPASS		(1<<3)
+#define   VERSAL_SLCR_PLL_CTRL_FBDIV_SHIFT	8
+#define   VERSAL_SLCR_PLL_CTRL_FBDIV_MAX	0xff
+#define   VERSAL_SLCR_PLL_CTRL_FBDIV_MASK	(VERSAL_SLCR_PLL_CTRL_FBDIV_MAX<<8)
+#define   VERSAL_SLCR_PLL_CTRL_DIV_SHIFT	(16)
+#define   VERSAL_SLCR_PLL_CTRL_DIV_MASK	(0x3<<16)
+#define   VERSAL_SLCR_PLL_CTRL_PRE_SRC_SHIFT	20
+#define   VERSAL_SLCR_PLL_CTRL_PRE_SRC_MASK	(0x7<<20)
+#define   VERSAL_SLCR_PLL_CTRL_POST_SRC_SHIFT	24
+#define   VERSAL_SLCR_PLL_CTRL_POST_SRC_MASK	(0x7<<24)
+#define     VERSAL_SLCR_PLL_CTRL_SRC_REF_CLK		0x0
+#define     VERSAL_SLCR_PLL_CTRL_SRC_REF_CLK_MASK	0x2
+#define     VERSAL_SLCR_PLL_CTRL_SRC_PL_PMC_ALT_REF_CLK_MASK	0x3
+/* Clock controls. */
+#define VERSAL_SLCR_GEM0_CLK_CTRL		(VERSAL_SLCR_CRL_OFFSET + 0x118)
+#define VERSAL_SLCR_GEM1_CLK_CTRL		(VERSAL_SLCR_CRL_OFFSET + 0x11c)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_CLKACT_RX		(1<<27)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_CLKACT_TX		(1<<26)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_CLKACT		(1<<25)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX		0x3ff
+#define   VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MASK	(VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX<<8)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_SHIFT	8
+#define   VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_MASK		(7<<0)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_P_PLL		(0<<0)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_R_PLL		(1<<0)
+#define   VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL		(3<<0)
+#define VERSAL_DEFAULT_PS_CLK_FREQUENCY 33333333
+#ifdef _KERNEL
+extern int cgem_set_ref_clk(int unit, int frequency);
+#endif
+#endif /* _VERSAL_SLCR_H_ */
2.19.1
