[rtems-tools] tester: Update jobs configuration
Ryan Long
ryan.long at oarcorp.com
Wed Oct 20 20:05:57 UTC 2021
Allow for default_jobs and max_jobs to be specified in the BSP's
configuration file.
rtemstoolkit/options.py | 45 +++++++++++++---------
tester/rtems/testing/bsps/beagleboardxm.ini | 2 +-
tester/rtems/testing/bsps/beagleboneblack.ini | 2 +-
tester/rtems/testing/bsps/imx7.ini | 2 +-
tester/rtems/testing/bsps/mcf5235.ini | 2 +-
tester/rtems/testing/bsps/mvme2307.ini | 2 +-
tester/rtems/testing/bsps/pc.ini | 2 +-
tester/rtems/testing/bsps/qoriq_e500.ini | 2 +-
tester/rtems/testing/bsps/qoriq_e6500_32.ini | 2 +-
tester/rtems/testing/bsps/qoriq_e6500_64.ini | 2 +-
tester/rtems/testing/bsps/raspberrypi2.ini | 2 +-
tester/rtems/testing/bsps/xilinx_versal_vck190.ini | 2 +-
.../rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini | 2 +-
tester/rtems/testing/bsps/xilinx_zynq_zc706.ini | 2 +-
tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini | 2 +-
.../testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini | 2 +-
.../testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 2 +-
tester/rtems/testing/defaults.mc | 2 +
18 files changed, 45 insertions(+), 34 deletions(-)
diff --git a/rtemstoolkit/options.py b/rtemstoolkit/options.py
index 5ebe3bc..4b7a93a 100644
--- a/rtemstoolkit/options.py
+++ b/rtemstoolkit/options.py
@@ -102,7 +102,7 @@ class command_line(object):
'--no-clean': 'Do not clean up the build tree',
'--always-clean': 'Always clean the build tree, even with an error',
'--keep-going': 'Do not stop on an error.',
- '--jobs=[0..n,none,half,full]': 'Run with specified number of jobs, default: num CPUs.',
+ '--jobs=[0..n,none,half,full]': 'Run with specified number of jobs (default: defined in configuration file)',
'--macros file[,file]': 'Macro format files to load after the defaults',
'--log file': 'Log file where all build output is written to',
@@ -327,6 +327,11 @@ class command_line(object):
# Handle the jobs for make
if '_ncpus' not in self.defaults:
raise error.general('host number of CPUs not set')
+ if self.defaults['default_jobs'] != '0':
+ print(
+ 'default_jobs is %d and the default is %d' %
+ (self.defaults['default_jobs'], 0)
ncpus = self.jobs(self.defaults['_ncpus'])
if ncpus > 1:
self.defaults['_smp_mflags'] = '-j %d' % (ncpus)
@@ -427,28 +432,25 @@ class command_line(object):
um += [m]
return um if len(um) else None
- def jobs(self, cpus):
+ def jobs(self, num_cpus):
try:
- cpus = int(cpus)
+ cpus = int(num_cpus)
except:
raise error.general('invalid host cpu value')
opt_jobs = self.opts['jobs']
if opt_jobs == 'default':
- _jobs = self.defaults.get_value('jobs')
- if _jobs is not None:
- if _jobs == 'none':
- cpus = 0
- elif _jobs == 'max':
- pass
- elif _jobs == 'half':
- cpus = cpus / 2
- else:
- try:
- cpus = int(_jobs)
- except:
- raise error.general('invalid %%{jobs} value: %s' % (_jobs))
+ _jobs = self.defaults.get_value('default_jobs')
+ if _jobs == 'none':
+ cpus = 0
+ elif _jobs == 'max':
+ pass
+ elif _jobs == 'half':
+ cpus = cpus / 2
else:
- opt_jobs = 'max'
+ try:
+ cpus = int(_jobs)
+ except:
+ raise error.general('invalid %%{jobs} value: %s' % (_jobs))
if opt_jobs != 'default':
if opt_jobs == 'none':
cpus = 0
@@ -474,7 +476,14 @@ class command_line(object):
if not ok:
raise error.internal('bad jobs option: %s' % (opt_jobs))
if cpus <= 0:
- cpu = 1
+ cpus = 1
+ max_jobs = int(self.defaults.get_value('max_jobs'))
+ if max_jobs == 0:
+ max_jobs = cpus
+ if cpus > max_jobs:
+ raise error.internal(
+ 'exceeded maximum number of jobs: %d > %d' % (cpus, max_jobs)
return cpus
def params(self):
diff --git a/tester/rtems/testing/bsps/beagleboardxm.ini b/tester/rtems/testing/bsps/beagleboardxm.ini
index e8a79a6..72e6e8f 100644
--- a/tester/rtems/testing/bsps/beagleboardxm.ini
+++ b/tester/rtems/testing/bsps/beagleboardxm.ini
@@ -36,7 +36,7 @@
[beagleboardxm]
bsp = beagleboardxm
arch = arm
-jobs = 1
+max_jobs = 1
tester = %{_rtscripts}/gdb.cfg
gdb_script = bsp_gdb_script
requires = bsp_tty_dev, bsp_gdb_script
diff --git a/tester/rtems/testing/bsps/beagleboneblack.ini b/tester/rtems/testing/bsps/beagleboneblack.ini
index 4bf850f..346d859 100644
--- a/tester/rtems/testing/bsps/beagleboneblack.ini
+++ b/tester/rtems/testing/bsps/beagleboneblack.ini
@@ -35,7 +35,7 @@
[beagleboneblack]
bsp = beagleboneblack
arch = arm
-jobs = 1
+max_jobs = 1
tester = %{_rtscripts}/tftp.cfg
test_restarts = 3
target_reset_regex = ^No ethernet found.*|BOOTP broadcast 6.*|^ERROR: can.t get kernel image
diff --git a/tester/rtems/testing/bsps/imx7.ini b/tester/rtems/testing/bsps/imx7.ini
index 0a56ba8..28dd77f 100644
--- a/tester/rtems/testing/bsps/imx7.ini
+++ b/tester/rtems/testing/bsps/imx7.ini
@@ -35,7 +35,7 @@
[imx7]
bsp = imx7
arch = arm
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_start_regex = Hit any key to stop autoboot:
diff --git a/tester/rtems/testing/bsps/mcf5235.ini b/tester/rtems/testing/bsps/mcf5235.ini
index 00f6a26..5023275 100644
--- a/tester/rtems/testing/bsps/mcf5235.ini
+++ b/tester/rtems/testing/bsps/mcf5235.ini
@@ -34,6 +34,6 @@
[mcf5235]
bsp = mcf5235
arch = m68k
-jobs = 1
+max_jobs = 1
requires = bsp_tty_dev, gdb_script
diff --git a/tester/rtems/testing/bsps/mvme2307.ini b/tester/rtems/testing/bsps/mvme2307.ini
index b142aa9..bb7e15f 100644
--- a/tester/rtems/testing/bsps/mvme2307.ini
+++ b/tester/rtems/testing/bsps/mvme2307.ini
@@ -52,7 +52,7 @@
[mvme2307]
bsp = mvme2307
arch = powerpc
-jobs = 1
+max_jobs = 1
test_restarts = 3
tester = %{_rtscripts}/wait.cfg
target_start_regex = ^Copyright Motorola Inc.*, All Rights Reserved
diff --git a/tester/rtems/testing/bsps/pc.ini b/tester/rtems/testing/bsps/pc.ini
index 93a5dae..5f81336 100644
--- a/tester/rtems/testing/bsps/pc.ini
+++ b/tester/rtems/testing/bsps/pc.ini
@@ -31,7 +31,7 @@
[pc]
bsp = pc686
arch = i386
-jobs = 1
+max_jobs = 1
test_restarts = 3
requires = bsp_tty_dev, target_on_command, target_off_command, target_reset_command
diff --git a/tester/rtems/testing/bsps/qoriq_e500.ini b/tester/rtems/testing/bsps/qoriq_e500.ini
index 322069b..1756bcd 100644
--- a/tester/rtems/testing/bsps/qoriq_e500.ini
+++ b/tester/rtems/testing/bsps/qoriq_e500.ini
@@ -35,7 +35,7 @@
[qoriq_e500]
bsp = qoriq_e500
arch = powerpc
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_start_regex = U-Boot
diff --git a/tester/rtems/testing/bsps/qoriq_e6500_32.ini b/tester/rtems/testing/bsps/qoriq_e6500_32.ini
index 26ee3ae..daf564e 100644
--- a/tester/rtems/testing/bsps/qoriq_e6500_32.ini
+++ b/tester/rtems/testing/bsps/qoriq_e6500_32.ini
@@ -36,7 +36,7 @@
[qoriq_e6500_32]
bsp = qoriq_e6500_32
arch = powerpc
-jobs = 1
+max_jobs = 1
test_restarts = 3
diff --git a/tester/rtems/testing/bsps/qoriq_e6500_64.ini b/tester/rtems/testing/bsps/qoriq_e6500_64.ini
index c9b6ab7..e507032 100644
--- a/tester/rtems/testing/bsps/qoriq_e6500_64.ini
+++ b/tester/rtems/testing/bsps/qoriq_e6500_64.ini
@@ -36,7 +36,7 @@
[qoriq_e6500_64]
bsp = qoriq_e6500_64
arch = powerpc
-jobs = 1
+max_jobs = 1
test_restarts = 3
diff --git a/tester/rtems/testing/bsps/raspberrypi2.ini b/tester/rtems/testing/bsps/raspberrypi2.ini
index e8043ac..f7f3c8c 100644
--- a/tester/rtems/testing/bsps/raspberrypi2.ini
+++ b/tester/rtems/testing/bsps/raspberrypi2.ini
@@ -35,7 +35,7 @@
[raspberrypi2]
bsp = raspberrypi2
arch = arm
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_reset_regex = BOOTP broadcast 6.*|^ERROR: can.t get kernel image
diff --git a/tester/rtems/testing/bsps/xilinx_versal_vck190.ini b/tester/rtems/testing/bsps/xilinx_versal_vck190.ini
index 3bdd6be..a7695a7 100644
--- a/tester/rtems/testing/bsps/xilinx_versal_vck190.ini
+++ b/tester/rtems/testing/bsps/xilinx_versal_vck190.ini
@@ -36,7 +36,7 @@
bsp = xilinx_versal_vck190
arch = aarch64
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*
target_start_regex = .* PSCI Power Domain Map:$|^U-Boot .*
diff --git a/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini b/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini
index 4366ffc..b6b39b6 100644
--- a/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini
@@ -34,6 +34,6 @@
[xilinx_zynq_a9_qemu_smp]
bsp = xilinx_zynq_a9_qemu
arch = arm
-jobs = half
+default_jobs = half
tester = %{_rtscripts}/qemu.cfg
bsp_qemu_opts = %{qemu_opts_base} %{qemu_opts_no_net} %{qemu_opts_serial} -M xilinx-zynq-a9 -m 256M -smp cpus=2
diff --git a/tester/rtems/testing/bsps/xilinx_zynq_zc706.ini b/tester/rtems/testing/bsps/xilinx_zynq_zc706.ini
index e543022..844776d 100644
--- a/tester/rtems/testing/bsps/xilinx_zynq_zc706.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynq_zc706.ini
@@ -35,7 +35,7 @@
[xilinx_zynq_zc706]
bsp = xilinx_zynq_zc706
arch = arm
-jobs = 1
+max_jobs = 1
diff --git a/tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini b/tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini
index 14b4d94..5c2451b 100644
--- a/tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini
@@ -36,7 +36,7 @@
bsp = xilinx_zynq_zedboard
arch = arm
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_start_regex = ^U-Boot SPL .*
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
index 8c1c839..eefe173 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
@@ -35,7 +35,7 @@
bsp = xilinx_zynqmp_ilp32_zu3eg
arch = aarch64
-jobs = 1
+max_jobs = 1
test_restarts = 3
target_reset_regex = ^No ethernet found.*|^.*: No link\..*
target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
index 663e5de..1fa35e5 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
@@ -35,7 +35,7 @@
bsp = xilinx_zynqmp_lp64_zu3eg
arch = aarch64
-jobs = 1
+max_jobs = 1
test_restarts = 3
diff --git a/tester/rtems/testing/defaults.mc b/tester/rtems/testing/defaults.mc
index d3e16a9..830b377 100644
--- a/tester/rtems/testing/defaults.mc
+++ b/tester/rtems/testing/defaults.mc
@@ -116,6 +116,8 @@ __xz: exe, required, '/usr/bin/xz'
# Default settings
_target: none, none, '%{nil}'
+max_jobs: none, none, '0'
+default_jobs: none, none, '0'
# Paths
_rtbase: none, none, '%{_rtdir}'
1.8.3.1
