[PATCH] spec/libdebugger: Only enable for supported architectures
chrisj at rtems.org chrisj at rtems.org
Thu Oct 21 02:09:43 UTC 2021
 spec/build/cpukit/libdebugger.yml             | 5 ++++-
 spec/build/testsuites/libtests/debugger01.yml | 4 +---
 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/spec/build/cpukit/libdebugger.yml b/spec/build/cpukit/libdebugger.yml
index f316cc18e8..4e689044e7 100644
--- a/spec/build/cpukit/libdebugger.yml
+++ b/spec/build/cpukit/libdebugger.yml
@@ -5,7 +5,9 @@ copyrights:
 - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
+- arm
+- i386
 includes: []
 install: []
 install-path: ${BSP_LIBDIR}
@@ -24,4 +26,5 @@ source:
 - cpukit/libdebugger/rtems-debugger-target.c
 - cpukit/libdebugger/rtems-debugger-threads.c
 target: debugger
+name: BUILD_LIBDEBUGGER
 type: build
diff --git a/spec/build/testsuites/libtests/debugger01.yml b/spec/build/testsuites/libtests/debugger01.yml
index 720b643925..20c538bbb8 100644
--- a/spec/build/testsuites/libtests/debugger01.yml
+++ b/spec/build/testsuites/libtests/debugger01.yml
@@ -5,9 +5,7 @@ copyrights:
 cppflags: []
 cxxflags: []
-enabled-by:
-- arm
-- i386
+enabled-by: BUILD_LIBDEBUGGER
 features: c cprogram
 includes: []
 ldflags: []
2.19.1
