[PATCH] spec/libdebugger: Only enable for supported architectures
Sebastian Huber
Thu Oct 21 05:59:38 UTC 2021
On 21/10/2021 07:45, Chris Johns wrote:
> On 21/10/21 4:30 pm, Sebastian Huber wrote:
>> On 21/10/2021 04:09, chrisj at rtems.org wrote:
>>> From: Chris Johns<chrisj at rtems.org>
>>> spec/build/cpukit/libdebugger.yml | 5 ++++-
>>> spec/build/testsuites/libtests/debugger01.yml | 4 +---
>>> 2 files changed, 5 insertions(+), 4 deletions(-)
>>> diff --git a/spec/build/cpukit/libdebugger.yml
>>> b/spec/build/cpukit/libdebugger.yml
>>> index f316cc18e8..4e689044e7 100644
>>> --- a/spec/build/cpukit/libdebugger.yml
>>> +++ b/spec/build/cpukit/libdebugger.yml
>>> @@ -5,7 +5,9 @@ copyrights:
>>> - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>> cppflags: []
>>> cxxflags: []
>>> -enabled-by: true
>>> +enabled-by:
>>> +- arm
>>> +- i386
>>> includes: []
>>> install: []
>>> install-path: ${BSP_LIBDIR}
>>> @@ -24,4 +26,5 @@ source:
>>> - cpukit/libdebugger/rtems-debugger-target.c
>>> - cpukit/libdebugger/rtems-debugger-threads.c
>>> target: debugger
>>> +name: BUILD_LIBDEBUGGER
>>> type: build
>> Library items cannot have a name. You need an option item for this.
> An option implies it is user configurable and it is not. How would you pass the
> enable-it state to the tests?
Yes, all options can be set by the user.
> If there is another approach could be please explain how this is to handled?
One only option is to use an option.
> The waf build for libdebugger is broken. The library should only be built for
> the archs that have a backend. As it currently is the library is created and
> installed and this is hidden by the fact the test is conditional on the archs
> and not the library being built. This is now exposed by Kinsey's patch to
> libbsd. LibBSD does not build.
> I based adding the name on libdl. It seems libdl is done differently and I have
> no idea why and how it works.
libdl uses an option:
spec/build/cpukit/optlibdl.yml
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
