[PATCH] spec/libdebugger: Only enable for supported architectures
Thu Oct 21 05:45:49 UTC 2021
On 21/10/21 4:30 pm, Sebastian Huber wrote:
> On 21/10/2021 04:09, chrisj at rtems.org wrote:
>> From: Chris Johns<chrisj at rtems.org>
>>   spec/build/cpukit/libdebugger.yml             | 5 ++++-
>>   spec/build/testsuites/libtests/debugger01.yml | 4 +---
>>   2 files changed, 5 insertions(+), 4 deletions(-)
>> diff --git a/spec/build/cpukit/libdebugger.yml
>> b/spec/build/cpukit/libdebugger.yml
>> index f316cc18e8..4e689044e7 100644
>> --- a/spec/build/cpukit/libdebugger.yml
>> +++ b/spec/build/cpukit/libdebugger.yml
>> @@ -5,7 +5,9 @@ copyrights:
>>   - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>   cppflags: []
>>   cxxflags: []
>> -enabled-by: true
>> +enabled-by:
>> +- arm
>> +- i386
>>   includes: []
>>   install: []
>>   install-path: ${BSP_LIBDIR}
>> @@ -24,4 +26,5 @@ source:
>>   - cpukit/libdebugger/rtems-debugger-target.c
>>   - cpukit/libdebugger/rtems-debugger-threads.c
>>   target: debugger
>> +name: BUILD_LIBDEBUGGER
>>   type: build
> Library items cannot have a name. You need an option item for this.
An option implies it is user configurable and it is not. How would you pass the
enable-it state to the tests?
If there is another approach could be please explain how this is to handled?
The waf build for libdebugger is broken. The library should only be built for
the archs that have a backend. As it currently is the library is created and
installed and this is hidden by the fact the test is conditional on the archs
and not the library being built. This is now exposed by Kinsey's patch to
libbsd. LibBSD does not build.
I based adding the name on libdl. It seems libdl is done differently and I have
no idea why and how it works.
