[PATCH v3 5/5] testsuite: Add machine exception signal map test
Kinsey Moore kinsey.moore at oarcorp.com
Wed Oct 27 21:44:07 UTC 2021
Add a test to verify that mapping of machine exceptions to POSIX signals
operates properly when the application requests it.
 spec/build/testsuites/psxtests/grp.yml        |  2 +
 .../build/testsuites/psxtests/psxsignal09.yml | 22 ++++++
 testsuites/psxtests/psxsignal09/init.c        | 73 +++++++++++++++++++
 .../psxtests/psxsignal09/psxsignal09.doc      |  7 ++
 .../psxtests/psxsignal09/psxsignal09.scn      |  3 +
 testsuites/psxtests/psxsignal09/system.h      | 55 ++++++++++++++
 6 files changed, 162 insertions(+)
 create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
 create mode 100644 testsuites/psxtests/psxsignal09/init.c
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
 create mode 100644 testsuites/psxtests/psxsignal09/system.h
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index 9a0cb189fb..3ebd6a3373 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -208,6 +208,8 @@ links:
   uid: psxsignal07
 - role: build-dependency
   uid: psxsignal08
+- role: build-dependency
+  uid: psxsignal09
   uid: psxspin01
diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
new file mode 100644
index 0000000000..6f7b85d3cf
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxsignal09.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- and:
+  - RTEMS_EXCEPTION_EXTENSIONS
+  - RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxsignal09/init.c
+stlib: []
+target: testsuites/psxtests/psxsignal09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 0000000000..12883cc28c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -0,0 +1,73 @@
+ * @file
+ * @ingroup psxtests
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include <signal.h>
+#include <errno.h>
+#include <reent.h>
+const char rtems_test_name[] = "PSXSIGNAL 9";
+static void Handler_1( int signo )
+  TEST_END();
+  rtems_test_exit(0);
+void *POSIX_Init( void *argument )
+  int              status;
+  struct sigaction act;
+  TEST_BEGIN();
+  /* Hook signals that can be generated from machine exceptions */
+  act.sa_handler = Handler_1;
+  act.sa_flags   = 0;
+  status = sigaction( SIGFPE, &act, NULL );
+  rtems_test_assert( !status );
+  status = sigaction( SIGILL, &act, NULL );
+  status = sigaction( SIGSEGV, &act, NULL );
+  /* Generate machine exception */
+  _CPU_Instruction_illegal();
+  return NULL;
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
index 0000000000..5375ee6c20
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
@@ -0,0 +1,7 @@
+#  COPYRIGHT (c) 2021.
+#  On-Line Applications Research Corporation (OAR).
+#  SPDX-License-Identifier: BSD-2-Clause
+This test ensures that machine exceptions are mapped to POSIX signals when
+required by the application.
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
index 0000000000..b0d092a60c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXSIGNAL 9 ***
+*** END OF TEST PSXSIGNAL 9 ***
diff --git a/testsuites/psxtests/psxsignal09/system.h b/testsuites/psxtests/psxsignal09/system.h
index 0000000000..9f83634b6d
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/system.h
@@ -0,0 +1,55 @@
+ * @file
+ * are met:
+#include <pmacros.h>
+void *POSIX_Init( void *argument );
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS        1
+#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+        (RTEMS_MINIMUM_STACK_SIZE * 4)
+#include <rtems/confdefs.h>
+/* end of include file */
2.30.2
