[PATCH v3 0/5] Exception Extensions
Sebastian Huber
Thu Oct 28 05:51:26 UTC 2021
On 27/10/2021 23:44, Kinsey Moore wrote:
> This patch set is a rework of the previous Exception Management API
> patch set based on feedback from the community. From the last revision:
> * Everything has been moved out of the RTEMS Classic API namespace
> * The concept of exception classes have been removed in favor of a
> direct CPU_Exception_frame to signal mapping function
> * The added tests have been reworked to accomodate the above changes
Thanks, the patch set looks good overall. I just have some minor comments.
> It was not possible to defer the call to raise() to a post-switch action
> since the post-switch action list is already locked and thus cannot be
> relocked by calls underneath raise() to add the signal handler call to
> the list.
You can release the thread state lock in a post-switch action, see
_Signal_Action_handler() for an example. You can keep the code as is if
you want. I personally would be a bit nervous if someone calls the
highly complex raise() function in exception context.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
