[PATCH RSB] microblaze: Fix FreeBSD 13 build
Wed Oct 27 22:35:45 UTC 2021
Can you fix the same thing on the other architectures that include dtc? I
think the MIPS and moxie need it at least.
Also make sure to the RTEMS 7 configurations get the same change.
And.. there is a base/ bset for dtc which needs bumping.
Bet you didn't expect this much fun feedback. :)
--joel
On Wed, Oct 27, 2021, 5:27 PM Alex White <alex.white at oarcorp.com> wrote:
> This bumps the dtc version included in the MicroBlaze toolchain from
> 1.6.0 to 1.6.1. Building 1.6.0 on FreeBSD 13 was unsuccessful, but 1.6.1
> appears to build fine.
>  bare/config/devel/dtc-1.6.1-1.cfg    | 18 ++++++++++++++++++
>  rtems/config/6/rtems-microblaze.bset |  2 +-
>  2 files changed, 19 insertions(+), 1 deletion(-)
>  create mode 100644 bare/config/devel/dtc-1.6.1-1.cfg
> diff --git a/bare/config/devel/dtc-1.6.1-1.cfg
> b/bare/config/devel/dtc-1.6.1-1.cfg
> new file mode 100644
> index 0000000..54aed09
> --- /dev/null
> +++ b/bare/config/devel/dtc-1.6.1-1.cfg
> @@ -0,0 +1,18 @@
> +# DTC (Device Tree Compiler) 1.6.1
> +%if %{release} == %{nil}
> +%define release 1
> +%endif
> +%include %{_configdir}/base.cfg
> +%define dtc_version 1.6.1
> +%hash sha256 dtc-%{dtc_version}.tar.gz
> 38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
> +# The DTC build instructions. We use 1.x.x Release 1.
> +%include %{_configdir}/dtc-1-1.cfg
> diff --git a/rtems/config/6/rtems-microblaze.bset
> b/rtems/config/6/rtems-microblaze.bset
> index 3eb7a89..050a217 100644
> --- a/rtems/config/6/rtems-microblaze.bset
> +++ b/rtems/config/6/rtems-microblaze.bset
> @@ -6,7 +6,7 @@
>  %include 6/rtems-base.bset
> -devel/dtc-1.6.0-1
> +devel/dtc-1.6.1-1
>  # Build gdb first to raise the Python install error as early as possible.
> 2.27.0
> devel mailing list
> devel at rtems.org
