[PATCH RSB] Update to dtc 1.6.1
Alex White
alex.white at oarcorp.com
Thu Oct 28 15:40:52 UTC 2021
This bumps the dtc version from 1.6.0 to 1.6.1. Building 1.6.0 on
FreeBSD 13 was unsuccessful, but 1.6.1 appears to build fine.
bare/config/devel/dtc-1.6.1-1.cfg | 18 ++++++++++++++++++
bare/config/devel/dtc.bset | 2 +-
bare/config/devel/qemu-couverture.bset | 2 +-
rtems/config/6/rtems-microblaze.bset | 2 +-
rtems/config/6/rtems-moxie.bset | 2 +-
rtems/config/7/rtems-moxie.bset | 2 +-
6 files changed, 23 insertions(+), 5 deletions(-)
create mode 100644 bare/config/devel/dtc-1.6.1-1.cfg
diff --git a/bare/config/devel/dtc-1.6.1-1.cfg b/bare/config/devel/dtc-1.6.1-1.cfg
new file mode 100644
index 0000000..54aed09
--- /dev/null
+++ b/bare/config/devel/dtc-1.6.1-1.cfg
@@ -0,0 +1,18 @@
+# DTC (Device Tree Compiler) 1.6.1
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define dtc_version 1.6.1
+%hash sha256 dtc-%{dtc_version}.tar.gz 38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
+# The DTC build instructions. We use 1.x.x Release 1.
+%include %{_configdir}/dtc-1-1.cfg
diff --git a/bare/config/devel/dtc.bset b/bare/config/devel/dtc.bset
index 54521f6..56fb61e 100644
--- a/bare/config/devel/dtc.bset
+++ b/bare/config/devel/dtc.bset
@@ -4,4 +4,4 @@
%define release 1
-devel/dtc-1.4.1-1
+devel/dtc-1.6.1-1
diff --git a/bare/config/devel/qemu-couverture.bset b/bare/config/devel/qemu-couverture.bset
index fd5547c..60bec8e 100644
--- a/bare/config/devel/qemu-couverture.bset
+++ b/bare/config/devel/qemu-couverture.bset
@@ -22,5 +22,5 @@ devel/gettext-0.18.3.1-1
devel/libffi-3.0.13-1
devel/pixman-0.32.4-1
devel/glib-2.48.2-1
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
devel/qemu-couverture-git-1
diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
index 3eb7a89..050a217 100644
--- a/rtems/config/6/rtems-microblaze.bset
+++ b/rtems/config/6/rtems-microblaze.bset
@@ -6,7 +6,7 @@
%include 6/rtems-base.bset
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
# Build gdb first to raise the Python install error as early as possible.
diff --git a/rtems/config/6/rtems-moxie.bset b/rtems/config/6/rtems-moxie.bset
index a191c5d..0771def 100644
--- a/rtems/config/6/rtems-moxie.bset
+++ b/rtems/config/6/rtems-moxie.bset
@@ -2,5 +2,5 @@
%define rtems_arch moxie
%define win32-gdb-disable-sim
%define with_libgomp
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
%include 6/rtems-default.bset
diff --git a/rtems/config/7/rtems-moxie.bset b/rtems/config/7/rtems-moxie.bset
index 60fe7f4..5aecffa 100644
--- a/rtems/config/7/rtems-moxie.bset
+++ b/rtems/config/7/rtems-moxie.bset
@@ -2,5 +2,5 @@
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
%include 7/rtems-default.bset
2.27.0
