[PATCH RSB] Update to dtc 1.6.1
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Thu Oct 28 17:19:43 UTC 2021
Does RISC-V need that too?
On Thu, 28 Oct 2021 at 16:41, Alex White <alex.white at oarcorp.com> wrote:
> This bumps the dtc version from 1.6.0 to 1.6.1. Building 1.6.0 on
> FreeBSD 13 was unsuccessful, but 1.6.1 appears to build fine.
>  bare/config/devel/dtc-1.6.1-1.cfg      | 18 ++++++++++++++++++
>  bare/config/devel/dtc.bset             |  2 +-
>  bare/config/devel/qemu-couverture.bset |  2 +-
>  rtems/config/6/rtems-microblaze.bset   |  2 +-
>  rtems/config/6/rtems-moxie.bset        |  2 +-
>  rtems/config/7/rtems-moxie.bset        |  2 +-
>  6 files changed, 23 insertions(+), 5 deletions(-)
>  create mode 100644 bare/config/devel/dtc-1.6.1-1.cfg
> diff --git a/bare/config/devel/dtc-1.6.1-1.cfg
> b/bare/config/devel/dtc-1.6.1-1.cfg
> new file mode 100644
> index 0000000..54aed09
> --- /dev/null
> +++ b/bare/config/devel/dtc-1.6.1-1.cfg
> @@ -0,0 +1,18 @@
> +# DTC (Device Tree Compiler) 1.6.1
> +%if %{release} == %{nil}
> +%define release 1
> +%endif
> +%include %{_configdir}/base.cfg
> +%define dtc_version 1.6.1
> +%hash sha256 dtc-%{dtc_version}.tar.gz
> 38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
> +# The DTC build instructions. We use 1.x.x Release 1.
> +%include %{_configdir}/dtc-1-1.cfg
> diff --git a/bare/config/devel/dtc.bset b/bare/config/devel/dtc.bset
> index 54521f6..56fb61e 100644
> --- a/bare/config/devel/dtc.bset
> +++ b/bare/config/devel/dtc.bset
> @@ -4,4 +4,4 @@
>  %define release 1
> -devel/dtc-1.4.1-1
> +devel/dtc-1.6.1-1
> diff --git a/bare/config/devel/qemu-couverture.bset
> b/bare/config/devel/qemu-couverture.bset
> index fd5547c..60bec8e 100644
> --- a/bare/config/devel/qemu-couverture.bset
> +++ b/bare/config/devel/qemu-couverture.bset
> @@ -22,5 +22,5 @@ devel/gettext-0.18.3.1-1
>  devel/libffi-3.0.13-1
>  devel/pixman-0.32.4-1
>  devel/glib-2.48.2-1
> -devel/dtc-1.6.0-1
> +devel/dtc-1.6.1-1
>  devel/qemu-couverture-git-1
> diff --git a/rtems/config/6/rtems-microblaze.bset
> b/rtems/config/6/rtems-microblaze.bset
> index 3eb7a89..050a217 100644
> --- a/rtems/config/6/rtems-microblaze.bset
> +++ b/rtems/config/6/rtems-microblaze.bset
> @@ -6,7 +6,7 @@
>  %include 6/rtems-base.bset
> -devel/dtc-1.6.0-1
> +devel/dtc-1.6.1-1
>  # Build gdb first to raise the Python install error as early as possible.
> diff --git a/rtems/config/6/rtems-moxie.bset
> b/rtems/config/6/rtems-moxie.bset
> index a191c5d..0771def 100644
> --- a/rtems/config/6/rtems-moxie.bset
> +++ b/rtems/config/6/rtems-moxie.bset
> @@ -2,5 +2,5 @@
>  %define rtems_arch moxie
>  %define win32-gdb-disable-sim
>  %define with_libgomp
> -devel/dtc-1.6.0-1
> +devel/dtc-1.6.1-1
>  %include 6/rtems-default.bset
> diff --git a/rtems/config/7/rtems-moxie.bset
> b/rtems/config/7/rtems-moxie.bset
> index 60fe7f4..5aecffa 100644
> --- a/rtems/config/7/rtems-moxie.bset
> +++ b/rtems/config/7/rtems-moxie.bset
> @@ -2,5 +2,5 @@
> -devel/dtc-1.6.0-1
> +devel/dtc-1.6.1-1
>  %include 7/rtems-default.bset
> 2.27.0
> devel mailing list
> devel at rtems.org
