[PATCH v1 2/8] cpukit/libdebugger: Use uintptr_t for pointers
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Oct 29 21:17:15 UTC 2021
Use uintptr_t instead of DB_UINT when the variable in question describes
a pointer.
cpukit/libdebugger/rtems-debugger-i386.c | 12 ++++++------
cpukit/libdebugger/rtems-debugger-target.c | 2 +-
cpukit/libdebugger/rtems-debugger-target.h | 10 +++++-----
cpukit/libdebugger/rtems-debugger-threads.c | 6 +++---
cpukit/libdebugger/rtems-debugger-threads.h | 10 +++++-----
5 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-i386.c b/cpukit/libdebugger/rtems-debugger-i386.c
index a2396e5f30..02e29c25a1 100644
--- a/cpukit/libdebugger/rtems-debugger-i386.c
+++ b/cpukit/libdebugger/rtems-debugger-i386.c
@@ -376,7 +376,7 @@ rtems_debugger_target_write_regs(rtems_debugger_thread* thread)
return 0;
-DB_UINT
+uintptr_t
rtems_debugger_target_reg_pc(rtems_debugger_thread* thread)
int r;
@@ -387,13 +387,13 @@ rtems_debugger_target_reg_pc(rtems_debugger_thread* thread)
return 0;
-DB_UINT
+uintptr_t
rtems_debugger_target_frame_pc(CPU_Exception_frame* frame)
- return (DB_UINT) frame->eip;
+ return (uintptr_t) frame->eip;
-DB_UINT
+uintptr_t
rtems_debugger_target_reg_sp(rtems_debugger_thread* thread)
int r;
@@ -404,7 +404,7 @@ rtems_debugger_target_reg_sp(rtems_debugger_thread* thread)
return 0;
-DB_UINT
+uintptr_t
rtems_debugger_target_tcb_sp(rtems_debugger_thread* thread)
return (DB_UINT) thread->tcb->Registers.esp;
@@ -503,7 +503,7 @@ rtems_debugger_target_hwbreak_remove(void)
int
rtems_debugger_target_hwbreak_control(rtems_debugger_target_watchpoint wp,
bool insert,
- DB_UINT addr,
+ uintptr_t addr,
DB_UINT kind)
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index 34e4e84d2f..04b274909b 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -315,7 +315,7 @@ rtems_debugger_target_exception(CPU_Exception_frame* frame)
Thread_Control* thread = _Thread_Get_executing();
const rtems_id tid = thread->Object.id;
rtems_id* excludes;
- DB_UINT pc;
+ uintptr_t pc;
const rtems_debugger_thread_stepper* stepper;
rtems_debugger_exception target_exception;
size_t i;
diff --git a/cpukit/libdebugger/rtems-debugger-target.h b/cpukit/libdebugger/rtems-debugger-target.h
index db356e1f07..1e132fb28c 100644
--- a/cpukit/libdebugger/rtems-debugger-target.h
+++ b/cpukit/libdebugger/rtems-debugger-target.h
@@ -164,22 +164,22 @@ extern int rtems_debugger_target_write_regs(rtems_debugger_thread* thread);
* Return the thread's program counter (PC).
-extern DB_UINT rtems_debugger_target_reg_pc(rtems_debugger_thread* thread);
+extern uintptr_t rtems_debugger_target_reg_pc(rtems_debugger_thread* thread);
* Return the frame's program counter (PC).
-extern DB_UINT rtems_debugger_target_frame_pc(CPU_Exception_frame* frame);
+extern uintptr_t rtems_debugger_target_frame_pc(CPU_Exception_frame* frame);
* Return the thread's stack pointer (SP).
-extern DB_UINT rtems_debugger_target_reg_sp(rtems_debugger_thread* thread);
+extern uintptr_t rtems_debugger_target_reg_sp(rtems_debugger_thread* thread);
* Return the thread's TCB stack pointer (SP).
-extern DB_UINT rtems_debugger_target_tcb_sp(rtems_debugger_thread* thread);
+extern uintptr_t rtems_debugger_target_tcb_sp(rtems_debugger_thread* thread);
* The thread is stepping. Setup the thread to step an instruction.
@@ -228,7 +228,7 @@ extern int rtems_debugger_target_hwbreak_remove(void);
extern int rtems_debugger_target_hwbreak_control(rtems_debugger_target_watchpoint type,
bool insert,
- DB_UINT addr,
+ uintptr_t addr,
DB_UINT kind);
diff --git a/cpukit/libdebugger/rtems-debugger-threads.c b/cpukit/libdebugger/rtems-debugger-threads.c
index e6ffe4a080..c628c0250e 100644
--- a/cpukit/libdebugger/rtems-debugger-threads.c
+++ b/cpukit/libdebugger/rtems-debugger-threads.c
@@ -469,8 +469,8 @@ rtems_debugger_thread_step(rtems_debugger_thread* thread)
int
rtems_debugger_thread_stepping(rtems_debugger_thread* thread,
- DB_UINT start,
- DB_UINT end)
+ uintptr_t start,
+ uintptr_t end)
/* add lock */
rtems_debugger_threads* threads = rtems_debugger->threads;
@@ -496,7 +496,7 @@ rtems_debugger_thread_stepping(rtems_debugger_thread* thread,
-rtems_debugger_thread_is_stepping(rtems_id id, DB_UINT pc)
+rtems_debugger_thread_is_stepping(rtems_id id, uintptr_t pc)
/* add lock */
diff --git a/cpukit/libdebugger/rtems-debugger-threads.h b/cpukit/libdebugger/rtems-debugger-threads.h
index 200dbbe1c7..60bc87984e 100644
--- a/cpukit/libdebugger/rtems-debugger-threads.h
+++ b/cpukit/libdebugger/rtems-debugger-threads.h
@@ -102,8 +102,8 @@ typedef struct rtems_debugger_thread
typedef struct rtems_debugger_thread_stepper
rtems_debugger_thread* thread;
- DB_UINT start;
- DB_UINT end;
+ uintptr_t start;
+ uintptr_t end;
} rtems_debugger_thread_stepper;
@@ -165,15 +165,15 @@ extern int rtems_debugger_thread_step(rtems_debugger_thread* thread);
* Thread is stepping so record the details.
extern int rtems_debugger_thread_stepping(rtems_debugger_thread* thread,
- DB_UINT start,
- DB_UINT end);
+ uintptr_t start,
+ uintptr_t end);
* Thread's PC in the stepping range? Returns the stepper is in range else
* NULL.
extern const rtems_debugger_thread_stepper*
-rtems_debugger_thread_is_stepping(rtems_id id, DB_UINT pc);
+rtems_debugger_thread_is_stepping(rtems_id id, uintptr_t pc);
* Return the thread's current priority/
2.30.2
