[PATCH v1 4/8] aarch64: Break out MMU definitions
Kinsey Moore kinsey.moore at oarcorp.com
Fri Oct 29 21:17:17 UTC 2021
This moves the AArch64 MMU memory type definitions into cpukit for use
by libdebugger since remapping of memory is required to insert software
breakpoints.
 bsps/aarch64/include/bsp/aarch64-mmu.h        | 40 +-------
 bsps/aarch64/shared/mmu/vmsav8-64-nommu.c     | 49 ++++++++++
 bsps/aarch64/shared/mmu/vmsav8-64.c           | 69 +++++++++++++
 .../aarch64/xilinx-versal/start/bspstartmmu.c |  1 +
 .../aarch64/xilinx-zynqmp/start/bspstartmmu.c |  1 +
 .../aarch64/include/libcpu/mmu-vmsav8-64.h    | 97 +++++++++++++++++++
 spec/build/bsps/aarch64/a53/obj.yml           |  1 +
 spec/build/bsps/aarch64/a72/obj.yml           |  1 +
 spec/build/bsps/aarch64/xilinx-versal/obj.yml |  1 +
 spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml |  1 +
 spec/build/cpukit/cpuaarch64.yml              |  1 +
 11 files changed, 223 insertions(+), 39 deletions(-)
 create mode 100644 bsps/aarch64/shared/mmu/vmsav8-64-nommu.c
 create mode 100644 bsps/aarch64/shared/mmu/vmsav8-64.c
 create mode 100644 cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
diff --git a/bsps/aarch64/include/bsp/aarch64-mmu.h b/bsps/aarch64/include/bsp/aarch64-mmu.h
index a5f6e846f3..4f42d5b187 100644
--- a/bsps/aarch64/include/bsp/aarch64-mmu.h
+++ b/bsps/aarch64/include/bsp/aarch64-mmu.h
@@ -42,50 +42,12 @@
 #include <rtems/score/aarch64-system-registers.h>
 #include <bspopts.h>
 #include <bsp/utility.h>
+#include <libcpu/mmu-vmsav8-64.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
-/* VMSAv8 Long-descriptor fields */
-#define MMU_DESC_AF                        BSP_BIT64( 10 )
-#define MMU_DESC_SH_INNER                  ( BSP_BIT64( 9 ) | BSP_BIT64( 8 ) )
-#define MMU_DESC_WRITE_DISABLE             BSP_BIT64( 7 )
-/* PAGE and TABLE flags are the same bit, but only apply on certain levels */
-#define MMU_DESC_TYPE_TABLE                BSP_BIT64( 1 )
-#define MMU_DESC_TYPE_PAGE                 BSP_BIT64( 1 )
-#define MMU_DESC_VALID                     BSP_BIT64( 0 )
-#define MMU_DESC_MAIR_ATTR( val )          BSP_FLD64( val, 2, 3 )
-#define MMU_DESC_MAIR_ATTR_GET( reg )      BSP_FLD64GET( reg, 2, 3 )
-#define MMU_DESC_MAIR_ATTR_SET( reg, val ) BSP_FLD64SET( reg, val, 2, 3 )
-#define MMU_DESC_PAGE_TABLE_MASK           0xFFFFFFFFF000LL
-/* Page table configuration */
-#define MMU_PAGE_BITS           12
-#define MMU_PAGE_SIZE           ( 1 << MMU_PAGE_BITS )
-#define MMU_BITS_PER_LEVEL      9
-#define MMU_TOP_LEVEL_PAGE_BITS ( 2 * MMU_BITS_PER_LEVEL + MMU_PAGE_BITS )
-#define AARCH64_MMU_FLAGS_BASE \
-  ( MMU_DESC_VALID | MMU_DESC_SH_INNER | MMU_DESC_AF )
-#define AARCH64_MMU_DATA_RO_CACHED \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) | MMU_DESC_WRITE_DISABLE )
-#define AARCH64_MMU_CODE_CACHED AARCH64_MMU_DATA_RO_CACHED
-#define AARCH64_MMU_CODE_RW_CACHED AARCH64_MMU_DATA_RW_CACHED
-#define AARCH64_MMU_DATA_RO \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) | MMU_DESC_WRITE_DISABLE )
-#define AARCH64_MMU_CODE AARCH64_MMU_DATA_RO
-#define AARCH64_MMU_CODE_RW AARCH64_MMU_DATA_RW
-/* RW implied by not ORing in RO */
-#define AARCH64_MMU_DATA_RW_CACHED \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) )
-#define AARCH64_MMU_DATA_RW \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) )
-#define AARCH64_MMU_DEVICE ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 0 ) )
 typedef struct {
   uintptr_t begin;
   uintptr_t end;
diff --git a/bsps/aarch64/shared/mmu/vmsav8-64-nommu.c b/bsps/aarch64/shared/mmu/vmsav8-64-nommu.c
new file mode 100644
index 0000000000..2c793fa239
--- /dev/null
+++ b/bsps/aarch64/shared/mmu/vmsav8-64-nommu.c
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Shared
+ * @brief AArch64 MMU dummy implementation.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * This must have a non-header implementation because it is used by libdebugger.
+rtems_status_code aarch64_mmu_map(
+  uintptr_t addr,
+  uint64_t size,
+  uint64_t flags
+  return RTEMS_SUCCESSFUL;
diff --git a/bsps/aarch64/shared/mmu/vmsav8-64.c b/bsps/aarch64/shared/mmu/vmsav8-64.c
index 0000000000..9caa91c414
--- /dev/null
+++ b/bsps/aarch64/shared/mmu/vmsav8-64.c
@@ -0,0 +1,69 @@
+ * @file
+ * @brief AArch64 MMU implementation.
+ * are met:
+#include <bsp/aarch64-mmu.h>
+#include <rtems/score/cpu.h>
+  uintptr_t addr,
+  uint64_t size,
+  uint64_t flags
+  rtems_status_code sc;
+  aarch64_mmu_disable();
+  sc = aarch64_mmu_map_block(
+    (uint64_t *) bsp_translation_table_base,
+    0x0,
+    addr,
+    size,
+    0,
+    flags
+  _AARCH64_Data_synchronization_barrier();
+  __asm__ volatile(
+    "tlbi vmalle1\n"
+  _AARCH64_Instruction_synchronization_barrier();
+  aarch64_mmu_enable();
+  return sc;
diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
index 8b622aec7d..5949111d0d 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
@@ -36,6 +36,7 @@
 #include <bsp.h>
 #include <bsp/start.h>
 BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
 versal_mmu_config_table[] = {
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
index 09012c9db5..33ca1eafab 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
@@ -37,6 +37,7 @@
 #include <bsp.h>
 zynqmp_mmu_config_table[] = {
diff --git a/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h b/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
index 0000000000..6b6296bb7a
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
@@ -0,0 +1,97 @@
+ * @file
+ * @ingroup RTEMSScoreCPUAArch64
+ * @brief Definitions used in MMU setup.
+ * are met:
+#ifndef LIBCPU_AARCH64_MMU_VMSAV8_64_H
+#define LIBCPU_AARCH64_MMU_VMSAV8_64_H
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#include <rtems.h>
+/* VMSAv8 Long-descriptor fields */
+#define MMU_DESC_AF                        ( 1 << 10 )
+#define MMU_DESC_SH_INNER                  ( ( 1 << 9 ) | ( 1 << 8 ) )
+#define MMU_DESC_WRITE_DISABLE             ( 1 << 7 )
+/* PAGE and TABLE flags are the same bit, but only apply on certain levels */
+#define MMU_DESC_TYPE_TABLE                ( 1 << 1 )
+#define MMU_DESC_TYPE_PAGE                 ( 1 << 1 )
+#define MMU_DESC_VALID                     ( 1 << 0 )
+#define MMU_DESC_MAIR_ATTR( val )          ( ( val & 0x3 ) << 2 )
+#define MMU_DESC_PAGE_TABLE_MASK           0xFFFFFFFFF000LL
+/* Page table configuration */
+#define MMU_PAGE_BITS           12
+#define MMU_PAGE_SIZE           ( 1 << MMU_PAGE_BITS )
+#define MMU_BITS_PER_LEVEL      9
+#define MMU_TOP_LEVEL_PAGE_BITS ( 2 * MMU_BITS_PER_LEVEL + MMU_PAGE_BITS )
+#define AARCH64_MMU_FLAGS_BASE \
+  ( MMU_DESC_VALID | MMU_DESC_SH_INNER | MMU_DESC_AF )
+#define AARCH64_MMU_DATA_RO_CACHED \
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) | MMU_DESC_WRITE_DISABLE )
+#define AARCH64_MMU_CODE_CACHED AARCH64_MMU_DATA_RO_CACHED
+#define AARCH64_MMU_CODE_RW_CACHED AARCH64_MMU_DATA_RW_CACHED
+#define AARCH64_MMU_DATA_RO \
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) | MMU_DESC_WRITE_DISABLE )
+#define AARCH64_MMU_CODE AARCH64_MMU_DATA_RO
+#define AARCH64_MMU_CODE_RW AARCH64_MMU_DATA_RW
+/* RW implied by not ORing in RO */
+#define AARCH64_MMU_DATA_RW_CACHED \
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) )
+#define AARCH64_MMU_DATA_RW \
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) )
+#define AARCH64_MMU_DEVICE ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 0 ) )
+  uintptr_t addr,
+  uint64_t  size,
+  uint64_t  flags
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBCPU_AARCH64_MMU_VMSAV8_64_H */
diff --git a/spec/build/bsps/aarch64/a53/obj.yml b/spec/build/bsps/aarch64/a53/obj.yml
index 939079a35a..51d4de8f52 100644
--- a/spec/build/bsps/aarch64/a53/obj.yml
+++ b/spec/build/bsps/aarch64/a53/obj.yml
@@ -22,6 +22,7 @@ source:
 - bsps/aarch64/a53/start/bspstarthooks.c
 - bsps/aarch64/shared/cache/cache.c
 - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+- bsps/aarch64/shared/mmu/vmsav8-64-nommu.c
 - bsps/shared/dev/btimer/btimer-cpucounter.c
 - bsps/shared/dev/clock/arm-generic-timer.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
diff --git a/spec/build/bsps/aarch64/a72/obj.yml b/spec/build/bsps/aarch64/a72/obj.yml
index 812b21be67..ad92559644 100644
--- a/spec/build/bsps/aarch64/a72/obj.yml
+++ b/spec/build/bsps/aarch64/a72/obj.yml
 - bsps/aarch64/a72/start/bspstarthooks.c
diff --git a/spec/build/bsps/aarch64/xilinx-versal/obj.yml b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
index 79e7000b52..b9ad05c0f6 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
@@ -24,6 +24,7 @@ links: []
 source:
+- bsps/aarch64/shared/mmu/vmsav8-64.c
 - bsps/aarch64/xilinx-versal/console/console.c
 - bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
 - bsps/aarch64/xilinx-versal/start/bspstart.c
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
index 4f6b9c44d8..8a15fe73bf 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
@@ -20,6 +20,7 @@ links: []
 source:
 - bsps/aarch64/xilinx-zynqmp/console/console.c
 - bsps/aarch64/xilinx-zynqmp/start/bspstart.c
 - bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
index 7b1bf5705d..70d80f0b6c 100644
--- a/spec/build/cpukit/cpuaarch64.yml
+++ b/spec/build/cpukit/cpuaarch64.yml
@@ -11,6 +11,7 @@ includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/libcpu
   source:
+  - cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
   - cpukit/score/cpu/aarch64/include/libcpu/vectors.h
 - destination: ${BSP_INCLUDEDIR}/rtems
   source:
2.30.2
