[PATCH rtems] bsps/imxrt: Improve SPI driver
    Gedare Bloom
    gedare at rtems.org
    Wed Sep  1 16:50:25 UTC 2021
looks ok, touching imxrt driver only
On Wed, Sep 1, 2021 at 7:55 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> It wasn't possible to keep the CS line low between multiple message
> descriptors in one transfer. This patch reworks the driver so that it is
> possible.
> Update #4180
>  bsps/arm/imxrt/spi/imxrt-lpspi.c | 197 +++++++++++++++++++------------
>  1 file changed, 124 insertions(+), 73 deletions(-)
> diff --git a/bsps/arm/imxrt/spi/imxrt-lpspi.c b/bsps/arm/imxrt/spi/imxrt-lpspi.c
> index 06d8f715d9..80b47f9663 100644
> --- a/bsps/arm/imxrt/spi/imxrt-lpspi.c
> +++ b/bsps/arm/imxrt/spi/imxrt-lpspi.c
> @@ -43,16 +43,19 @@ struct imxrt_lpspi_bus {
>    uint32_t src_clock_hz;
>    clock_ip_name_t clock_ip;
> -  uint32_t msg_todo;
> -  const spi_ioc_transfer *msg;
>    rtems_binary_semaphore sem;
> -  uint32_t tcr;
> +  bool cs_change_on_last_msg;
> +  uint32_t rx_msg_todo;
> +  const spi_ioc_transfer *rx_msg;
>    size_t remaining_rx_size;
>    uint8_t *rx_buf;
> +  uint32_t tx_msg_todo;
> +  const spi_ioc_transfer *tx_msg;
>    size_t remaining_tx_size;
>    const uint8_t *tx_buf;
>    uint32_t fifo_size;
> @@ -146,11 +149,7 @@ static void imxrt_lpspi_config(
>    tcr |= LPSPI_TCR_PCS(msg->cs);
> -  if (!msg->cs_change) {
> -    tcr |= LPSPI_TCR_CONT_MASK;
> +  tcr |= LPSPI_TCR_CONT_MASK;
>    tcr |= LPSPI_TCR_FRAMESZ(word_size-1);
>    if (ccr_orig != ccr) {
> @@ -159,9 +158,13 @@ static void imxrt_lpspi_config(
>      regs->CR |= LPSPI_CR_MEN_MASK;
> -  /* No CONTC on first write. Otherwise upper 8 bits are not written. */
> -  regs->TCR = tcr;
> -  regs->TCR = tcr | LPSPI_TCR_CONTC_MASK | LPSPI_TCR_CONT_MASK;
> +  if (bus->cs_change_on_last_msg) {
> +    /* No CONTC on first write. Otherwise upper 8 bits are not written. */
> +    regs->TCR = tcr;
> +  regs->TCR = tcr | LPSPI_TCR_CONTC_MASK;
> +  bus->cs_change_on_last_msg = msg->cs_change;
>  static inline bool imxrt_lpspi_rx_fifo_not_empty(
> @@ -184,48 +187,72 @@ static inline bool imxrt_lpspi_tx_fifo_not_full(
>        bus->fifo_size - 2;
> +static void imxrt_lpspi_next_tx_msg(
> +  struct imxrt_lpspi_bus *bus,
> +  volatile LPSPI_Type *regs
> +  if (bus->tx_msg_todo > 0) {
> +    const spi_ioc_transfer *msg;
> +    msg = bus->tx_msg;
> +    imxrt_lpspi_config(bus, regs, msg);
> +    bus->remaining_tx_size = msg->len;
> +    bus->tx_buf = msg->tx_buf;
>  static void imxrt_lpspi_fill_tx_fifo(
>    while(imxrt_lpspi_tx_fifo_not_full(bus, regs)
> -      && bus->remaining_tx_size > 0) {
> -    if (bus->remaining_tx_size == 1) {
> -      regs->TCR &= ~(LPSPI_TCR_CONT_MASK);
> +      && (bus->tx_msg_todo > 0 || bus->remaining_tx_size > 0)) {
> +    if (bus->remaining_tx_size > 0) {
> +      if (bus->remaining_tx_size == 1 && bus->tx_msg->cs_change) {
> +         * Necessary for getting the last data out of the Rx FIFO. See "i.MX
> +         * RT1050 Processor Reference Manual Rev. 4" Chapter 47.3.2.2 "Receive
> +         * FIFO and Data Match":
> +         * "During a continuous transfer, if the transmit FIFO is empty, then
> +         * the receive data is only written to the receive FIFO after the
> +         * transmit FIFO is written or after the Transmit Command Register (TCR)
> +         * is written to end the frame."
> +        regs->TCR &= ~(LPSPI_TCR_CONT_MASK);
> -    if (bus->tx_buf != NULL) {
> -      regs->TDR = bus->tx_buf[0];
> -      ++bus->tx_buf;
> -    } else {
> -      regs->TDR = 0;
> +      if (bus->tx_buf != NULL) {
> +        regs->TDR = bus->tx_buf[0];
> +        ++bus->tx_buf;
> +      } else {
> +        regs->TDR = 0;
> +      --bus->remaining_tx_size;
> +    if (bus->remaining_tx_size == 0) {
> +      --bus->tx_msg_todo;
> +      ++bus->tx_msg;
> +      imxrt_lpspi_next_tx_msg(bus, regs);
> -    --bus->remaining_tx_size;
> -static void imxrt_lpspi_next_msg(
> +static void imxrt_lpspi_next_rx_msg(
> -  if (bus->msg_todo > 0) {
> +  if (bus->rx_msg_todo > 0) {
> -    msg = bus->msg;
> +    msg = bus->rx_msg;
> -    imxrt_lpspi_config(bus, regs, msg);
> -    bus->remaining_tx_size = msg->len;
>      bus->remaining_rx_size = msg->len;
>      bus->rx_buf = msg->rx_buf;
> -    bus->tx_buf = msg->tx_buf;
> -    imxrt_lpspi_fill_tx_fifo(bus, regs);
> -    regs->IER = LPSPI_IER_TDIE_MASK;
> -  } else {
> -    regs->IER = 0;
> -    rtems_binary_semaphore_post(&bus->sem);
> @@ -234,15 +261,22 @@ static void imxrt_lpspi_pull_data_from_rx_fifo(
> -  while (imxrt_lpspi_rx_fifo_not_empty(regs) && bus->remaining_rx_size > 0) {
> -    uint32_t data;
> -    data = regs->RDR;
> -    if (bus->rx_buf != NULL) {
> -      *bus->rx_buf = data;
> -      ++bus->rx_buf;
> +  uint32_t data;
> +  while (imxrt_lpspi_rx_fifo_not_empty(regs)
> +      && (bus->rx_msg_todo > 0 || bus->remaining_rx_size > 0)) {
> +    if (bus->remaining_rx_size > 0) {
> +      data = regs->RDR;
> +      if (bus->rx_buf != NULL) {
> +        *bus->rx_buf = data;
> +        ++bus->rx_buf;
> +      --bus->remaining_rx_size;
> +    if (bus->remaining_rx_size == 0) {
> +      --bus->rx_msg_todo;
> +      ++bus->rx_msg;
> +      imxrt_lpspi_next_rx_msg(bus, regs);
> -    --bus->remaining_rx_size;
> @@ -257,39 +291,22 @@ static void imxrt_lpspi_interrupt(void *arg)
>    imxrt_lpspi_pull_data_from_rx_fifo(bus, regs);
> -  if (bus->remaining_tx_size == 0) {
> -    if (bus->remaining_rx_size > 0) {
> -      regs->IER = LPSPI_IER_RDIE_MASK;
> -    } else {
> -      --bus->msg_todo;
> -      ++bus->msg;
> -      imxrt_lpspi_next_msg(bus, regs);
> +  if (bus->tx_msg_todo > 0 || bus->remaining_tx_size > 0) {
> +    regs->IER = LPSPI_IER_TDIE_MASK;
> +  } else if (bus->rx_msg_todo > 0 || bus->remaining_rx_size > 0) {
> +    regs->IER = LPSPI_IER_RDIE_MASK;
> +  } else {
> +    regs->IER = 0;
> +    rtems_binary_semaphore_post(&bus->sem);
>  static inline int imxrt_lpspi_settings_ok(
> +  const spi_ioc_transfer *msg,
> +  const spi_ioc_transfer *prev_msg
> -  if (msg->cs_change == 0) {
> -     * This one most likely would need a bigger workaround if it is necessary.
> -     * See "i.MX RT1050 Processor Reference Manual Rev. 4" Chapter 47.3.2.2
> -     * "Receive FIFO and Data Match":
> -     * "During a continuous transfer, if the transmit FIFO is empty, then the
> -     * receive data is only written to the receive FIFO after the transmit FIFO
> -     * is written or after the Transmit Command Register (TCR) is written to end
> -     * the frame."
> -     * It might is possible to extend the driver so that it can work with an
> -     * empty read buffer.
> -    return -EINVAL;
>    /* most of this is currently just not implemented */
>    if (msg->cs > 3 ||
>        msg->speed_hz > bus->base.max_speed_hz ||
> @@ -299,6 +316,18 @@ static inline int imxrt_lpspi_settings_ok(
>      return -EINVAL;
> +  if (prev_msg != NULL && !prev_msg->cs_change) {
> +     * A lot of settings have to be the same in this case because the upper 8
> +     * bit of TCR can't be changed if it is a continuous transfer.
> +    if (prev_msg->cs != msg->cs ||
> +        prev_msg->speed_hz != msg->speed_hz ||
> +        prev_msg->mode != msg->mode) {
> +      return -EINVAL;
>    return 0;
> @@ -308,17 +337,29 @@ static int imxrt_lpspi_check_messages(
>    uint32_t size
> +  const spi_ioc_transfer *prev_msg = NULL;
>    while(size > 0) {
>      int rv;
> -    rv = imxrt_lpspi_settings_ok(bus, msg);
> +    rv = imxrt_lpspi_settings_ok(bus, msg, prev_msg);
>      if (rv != 0) {
>        return rv;
> +    prev_msg = msg;
>      ++msg;
>      --size;
> +   * Check whether cs_change is set on last message. Can't work without it
> +   * because the last received data is only put into the FIFO if it is the end
> +   * of a transfer or if another TX byte is put into the FIFO.
> +  if (!prev_msg->cs_change) {
> +    return -EINVAL;
>    return 0;
> @@ -336,10 +377,20 @@ static int imxrt_lpspi_transfer(
>    rv = imxrt_lpspi_check_messages(bus, msgs, n);
>    if (rv == 0) {
> -    bus->msg_todo = n;
> -    bus->msg = &msgs[0];
> -    imxrt_lpspi_next_msg(bus, bus->regs);
> +    bus->tx_msg_todo = n;
> +    bus->tx_msg = &msgs[0];
> +    bus->rx_msg_todo = n;
> +    bus->rx_msg = &msgs[0];
> +    bus->cs_change_on_last_msg = true;
> +    imxrt_lpspi_next_rx_msg(bus, bus->regs);
> +    imxrt_lpspi_next_tx_msg(bus, bus->regs);
> +     * Enable the transmit FIFO empty interrupt which will cause an interrupt
> +     * instantly because there is no data in the transmit FIFO. The interrupt
> +     * will then fill the FIFO. So nothing else to do here.
> +    bus->regs->IER = LPSPI_IER_TDIE_MASK;
>      rtems_binary_semaphore_wait(&bus->sem);
> @@ -416,7 +467,7 @@ static int imxrt_lpspi_setup(spi_bus *base)
>    bus = (struct imxrt_lpspi_bus *) base;
> -  rv = imxrt_lpspi_settings_ok(bus, &msg);
> +  rv = imxrt_lpspi_settings_ok(bus, &msg, NULL);
>     * Nothing to do besides checking.
> 2.31.1
> devel mailing list
> devel at rtems.org
