[PATCH rtems] bsps/imxrt: Improve SPI driver
Christian MAUDERER christian.mauderer at embedded-brains.de
Thu Sep 2 06:40:19 UTC 2021
Thanks.
Am 01.09.21 um 18:50 schrieb Gedare Bloom:
> looks ok, touching imxrt driver only
> On Wed, Sep 1, 2021 at 7:55 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> It wasn't possible to keep the CS line low between multiple message
>> descriptors in one transfer. This patch reworks the driver so that it is
>> possible.
>> Update #4180
>>   bsps/arm/imxrt/spi/imxrt-lpspi.c | 197 +++++++++++++++++++------------
>>   1 file changed, 124 insertions(+), 73 deletions(-)
>> diff --git a/bsps/arm/imxrt/spi/imxrt-lpspi.c b/bsps/arm/imxrt/spi/imxrt-lpspi.c
>> index 06d8f715d9..80b47f9663 100644
>> --- a/bsps/arm/imxrt/spi/imxrt-lpspi.c
>> +++ b/bsps/arm/imxrt/spi/imxrt-lpspi.c
>> @@ -43,16 +43,19 @@ struct imxrt_lpspi_bus {
>>     uint32_t src_clock_hz;
>>     clock_ip_name_t clock_ip;
>> -  uint32_t msg_todo;
>> -  const spi_ioc_transfer *msg;
>>     rtems_binary_semaphore sem;
>> -  uint32_t tcr;
>> +  bool cs_change_on_last_msg;
>> +  uint32_t rx_msg_todo;
>> +  const spi_ioc_transfer *rx_msg;
>>     size_t remaining_rx_size;
>>     uint8_t *rx_buf;
>> +  uint32_t tx_msg_todo;
>> +  const spi_ioc_transfer *tx_msg;
>>     size_t remaining_tx_size;
>>     const uint8_t *tx_buf;
>>     uint32_t fifo_size;
>> @@ -146,11 +149,7 @@ static void imxrt_lpspi_config(
>>     tcr |= LPSPI_TCR_PCS(msg->cs);
>> -  if (!msg->cs_change) {
>> -    tcr |= LPSPI_TCR_CONT_MASK;
>> +  tcr |= LPSPI_TCR_CONT_MASK;
>>     tcr |= LPSPI_TCR_FRAMESZ(word_size-1);
>>     if (ccr_orig != ccr) {
>> @@ -159,9 +158,13 @@ static void imxrt_lpspi_config(
>>       regs->CR |= LPSPI_CR_MEN_MASK;
>> -  /* No CONTC on first write. Otherwise upper 8 bits are not written. */
>> -  regs->TCR = tcr;
>> -  regs->TCR = tcr | LPSPI_TCR_CONTC_MASK | LPSPI_TCR_CONT_MASK;
>> +  if (bus->cs_change_on_last_msg) {
>> +    /* No CONTC on first write. Otherwise upper 8 bits are not written. */
>> +    regs->TCR = tcr;
>> +  regs->TCR = tcr | LPSPI_TCR_CONTC_MASK;
>> +  bus->cs_change_on_last_msg = msg->cs_change;
>>   static inline bool imxrt_lpspi_rx_fifo_not_empty(
>> @@ -184,48 +187,72 @@ static inline bool imxrt_lpspi_tx_fifo_not_full(
>>         bus->fifo_size - 2;
>> +static void imxrt_lpspi_next_tx_msg(
>> +  struct imxrt_lpspi_bus *bus,
>> +  volatile LPSPI_Type *regs
>> +  if (bus->tx_msg_todo > 0) {
>> +    const spi_ioc_transfer *msg;
>> +    msg = bus->tx_msg;
>> +    imxrt_lpspi_config(bus, regs, msg);
>> +    bus->remaining_tx_size = msg->len;
>> +    bus->tx_buf = msg->tx_buf;
>>   static void imxrt_lpspi_fill_tx_fifo(
>>     while(imxrt_lpspi_tx_fifo_not_full(bus, regs)
>> -      && bus->remaining_tx_size > 0) {
>> -    if (bus->remaining_tx_size == 1) {
>> -      regs->TCR &= ~(LPSPI_TCR_CONT_MASK);
>> +      && (bus->tx_msg_todo > 0 || bus->remaining_tx_size > 0)) {
>> +    if (bus->remaining_tx_size > 0) {
>> +      if (bus->remaining_tx_size == 1 && bus->tx_msg->cs_change) {
>> +         * Necessary for getting the last data out of the Rx FIFO. See "i.MX
>> +         * RT1050 Processor Reference Manual Rev. 4" Chapter 47.3.2.2 "Receive
>> +         * FIFO and Data Match":
>> +         * "During a continuous transfer, if the transmit FIFO is empty, then
>> +         * the receive data is only written to the receive FIFO after the
>> +         * transmit FIFO is written or after the Transmit Command Register (TCR)
>> +         * is written to end the frame."
>> +        regs->TCR &= ~(LPSPI_TCR_CONT_MASK);
>> -    if (bus->tx_buf != NULL) {
>> -      regs->TDR = bus->tx_buf[0];
>> -      ++bus->tx_buf;
>> -    } else {
>> -      regs->TDR = 0;
>> +      if (bus->tx_buf != NULL) {
>> +        regs->TDR = bus->tx_buf[0];
>> +        ++bus->tx_buf;
>> +      } else {
>> +        regs->TDR = 0;
>> +      --bus->remaining_tx_size;
>> +    if (bus->remaining_tx_size == 0) {
>> +      --bus->tx_msg_todo;
>> +      ++bus->tx_msg;
>> +      imxrt_lpspi_next_tx_msg(bus, regs);
>> -    --bus->remaining_tx_size;
>> -static void imxrt_lpspi_next_msg(
>> +static void imxrt_lpspi_next_rx_msg(
>> -  if (bus->msg_todo > 0) {
>> +  if (bus->rx_msg_todo > 0) {
>> -    msg = bus->msg;
>> +    msg = bus->rx_msg;
>> -    imxrt_lpspi_config(bus, regs, msg);
>> -    bus->remaining_tx_size = msg->len;
>>       bus->remaining_rx_size = msg->len;
>>       bus->rx_buf = msg->rx_buf;
>> -    bus->tx_buf = msg->tx_buf;
>> -    imxrt_lpspi_fill_tx_fifo(bus, regs);
>> -    regs->IER = LPSPI_IER_TDIE_MASK;
>> -  } else {
>> -    regs->IER = 0;
>> -    rtems_binary_semaphore_post(&bus->sem);
>> @@ -234,15 +261,22 @@ static void imxrt_lpspi_pull_data_from_rx_fifo(
>> -  while (imxrt_lpspi_rx_fifo_not_empty(regs) && bus->remaining_rx_size > 0) {
>> -    uint32_t data;
>> -    data = regs->RDR;
>> -    if (bus->rx_buf != NULL) {
>> -      *bus->rx_buf = data;
>> -      ++bus->rx_buf;
>> +  uint32_t data;
>> +  while (imxrt_lpspi_rx_fifo_not_empty(regs)
>> +      && (bus->rx_msg_todo > 0 || bus->remaining_rx_size > 0)) {
>> +    if (bus->remaining_rx_size > 0) {
>> +      data = regs->RDR;
>> +      if (bus->rx_buf != NULL) {
>> +        *bus->rx_buf = data;
>> +        ++bus->rx_buf;
>> +      --bus->remaining_rx_size;
>> +    if (bus->remaining_rx_size == 0) {
>> +      --bus->rx_msg_todo;
>> +      ++bus->rx_msg;
>> +      imxrt_lpspi_next_rx_msg(bus, regs);
>> -    --bus->remaining_rx_size;
>> @@ -257,39 +291,22 @@ static void imxrt_lpspi_interrupt(void *arg)
>>     imxrt_lpspi_pull_data_from_rx_fifo(bus, regs);
>> -  if (bus->remaining_tx_size == 0) {
>> -    if (bus->remaining_rx_size > 0) {
>> -      regs->IER = LPSPI_IER_RDIE_MASK;
>> -    } else {
>> -      --bus->msg_todo;
>> -      ++bus->msg;
>> -      imxrt_lpspi_next_msg(bus, regs);
>> +  if (bus->tx_msg_todo > 0 || bus->remaining_tx_size > 0) {
>> +    regs->IER = LPSPI_IER_TDIE_MASK;
>> +  } else if (bus->rx_msg_todo > 0 || bus->remaining_rx_size > 0) {
>> +    regs->IER = LPSPI_IER_RDIE_MASK;
>> +  } else {
>> +    regs->IER = 0;
>> +    rtems_binary_semaphore_post(&bus->sem);
>>   static inline int imxrt_lpspi_settings_ok(
>> +  const spi_ioc_transfer *msg,
>> +  const spi_ioc_transfer *prev_msg
>> -  if (msg->cs_change == 0) {
>> -     * This one most likely would need a bigger workaround if it is necessary.
>> -     * See "i.MX RT1050 Processor Reference Manual Rev. 4" Chapter 47.3.2.2
>> -     * "Receive FIFO and Data Match":
>> -     * "During a continuous transfer, if the transmit FIFO is empty, then the
>> -     * receive data is only written to the receive FIFO after the transmit FIFO
>> -     * is written or after the Transmit Command Register (TCR) is written to end
>> -     * the frame."
>> -     * It might is possible to extend the driver so that it can work with an
>> -     * empty read buffer.
>> -    return -EINVAL;
>>     /* most of this is currently just not implemented */
>>     if (msg->cs > 3 ||
>>         msg->speed_hz > bus->base.max_speed_hz ||
>> @@ -299,6 +316,18 @@ static inline int imxrt_lpspi_settings_ok(
>>       return -EINVAL;
>> +  if (prev_msg != NULL && !prev_msg->cs_change) {
>> +     * A lot of settings have to be the same in this case because the upper 8
>> +     * bit of TCR can't be changed if it is a continuous transfer.
>> +    if (prev_msg->cs != msg->cs ||
>> +        prev_msg->speed_hz != msg->speed_hz ||
>> +        prev_msg->mode != msg->mode) {
>> +      return -EINVAL;
>>     return 0;
>> @@ -308,17 +337,29 @@ static int imxrt_lpspi_check_messages(
>>     uint32_t size
>> +  const spi_ioc_transfer *prev_msg = NULL;
>>     while(size > 0) {
>>       int rv;
>> -    rv = imxrt_lpspi_settings_ok(bus, msg);
>> +    rv = imxrt_lpspi_settings_ok(bus, msg, prev_msg);
>>       if (rv != 0) {
>>         return rv;
>> +    prev_msg = msg;
>>       ++msg;
>>       --size;
>> +   * Check whether cs_change is set on last message. Can't work without it
>> +   * because the last received data is only put into the FIFO if it is the end
>> +   * of a transfer or if another TX byte is put into the FIFO.
>> +  if (!prev_msg->cs_change) {
>> +    return -EINVAL;
>>     return 0;
>> @@ -336,10 +377,20 @@ static int imxrt_lpspi_transfer(
>>     rv = imxrt_lpspi_check_messages(bus, msgs, n);
>>     if (rv == 0) {
>> -    bus->msg_todo = n;
>> -    bus->msg = &msgs[0];
>> -    imxrt_lpspi_next_msg(bus, bus->regs);
>> +    bus->tx_msg_todo = n;
>> +    bus->tx_msg = &msgs[0];
>> +    bus->rx_msg_todo = n;
>> +    bus->rx_msg = &msgs[0];
>> +    bus->cs_change_on_last_msg = true;
>> +    imxrt_lpspi_next_rx_msg(bus, bus->regs);
>> +    imxrt_lpspi_next_tx_msg(bus, bus->regs);
>> +     * Enable the transmit FIFO empty interrupt which will cause an interrupt
>> +     * instantly because there is no data in the transmit FIFO. The interrupt
>> +     * will then fill the FIFO. So nothing else to do here.
>> +    bus->regs->IER = LPSPI_IER_TDIE_MASK;
>>       rtems_binary_semaphore_wait(&bus->sem);
>> @@ -416,7 +467,7 @@ static int imxrt_lpspi_setup(spi_bus *base)
>>     bus = (struct imxrt_lpspi_bus *) base;
>> -  rv = imxrt_lpspi_settings_ok(bus, &msg);
>> +  rv = imxrt_lpspi_settings_ok(bus, &msg, NULL);
>>      * Nothing to do besides checking.
>> 2.31.1
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
