[PATCH] eng: Remove bogus coding rule
Sebastian Huber
Thu Sep 2 09:21:23 UTC 2021
Declaring functions used only through function pointers as inline makes
absolutely no sense at all.
eng/coding-conventions.rst | 2 --
1 file changed, 2 deletions(-)
diff --git a/eng/coding-conventions.rst b/eng/coding-conventions.rst
index 668a917..575dd44 100644
--- a/eng/coding-conventions.rst
+++ b/eng/coding-conventions.rst
@@ -219,8 +219,6 @@ Performance
* Understand the constraints of `real-time programming <https://devel.rtems.org/wiki/TBR/Review/Real-Time_Resources>`_..
Limit execution times in interrupt contexts and critical sections,
such as Interrupt and Timer Service Routines (TSRs).
-* Functions used only through function pointers should be declared
- 'static inline' (RTEMS_INLINE_ROUTINE)
* Prefer to ++preincrement instead of postincrement++.
* Avoid using floating point except where absolutely necessary.
2.31.1
