[PATCH v1 06/10] CoverageMapBase.h: Fix formatting
Ryan Long ryan.long at oarcorp.com
Thu Sep 2 19:24:35 UTC 2021
 tester/covoar/CoverageMapBase.h | 66 ++++++++++++++++++++++++++++-------------
 1 file changed, 45 insertions(+), 21 deletions(-)
diff --git a/tester/covoar/CoverageMapBase.h b/tester/covoar/CoverageMapBase.h
index a58c696..0da5f1c 100644
--- a/tester/covoar/CoverageMapBase.h
+++ b/tester/covoar/CoverageMapBase.h
@@ -27,23 +27,28 @@ namespace Coverage {
      *  an instruction.
     bool isStartOfInstruction;
      *  This member indicates how many times the address was executed.
     uint32_t wasExecuted;
      *  This member indicates that the address is a branch instruction.
     bool isBranch;
      *  This member indicates that the address is a NOP instruction.
     bool isNop;
      *  When isBranch is TRUE, this member indicates that the branch
      *  instruction at the address was taken.
     uint32_t wasTaken;
      *  instruction at the address was NOT taken.
@@ -52,7 +57,7 @@ namespace Coverage {
-  typedef std::vector < AddressInfo > AddressInfos;
+  typedef std::vector<AddressInfo> AddressInfos;
    *  This structure identifies the low and high addresses
@@ -61,19 +66,22 @@ namespace Coverage {
   struct AddressRange {
-    AddressRange ();
-    AddressRange (const std::string& name,
-                  uint32_t           lowAddress,
-                  uint32_t           highAddress);
+    AddressRange();
+    AddressRange(
+      const std::string& name,
+      uint32_t           lowAddress,
+      uint32_t           highAddress
+    size_t size() const;
-    size_t size () const;
+    bool inside( uint32_t address ) const;
-    bool inside (uint32_t address) const;
+    AddressInfo& get( uint32_t address );
-    AddressInfo& get (uint32_t address);
-    const AddressInfo& get (uint32_t address) const;
+    const AddressInfo& get( uint32_t address ) const;
-    void dump (std::ostream& out, bool show_slots = false) const;
+    void dump( std::ostream& out, bool show_slots = false ) const;
      *  This is the file from which this originated.
@@ -100,7 +108,7 @@ namespace Coverage {
    *  This type identifies a list of ranges.
-  typedef std::vector< AddressRange >  AddressRanges;
+  typedef std::vector<AddressRange> AddressRanges;
   /*! @class CoverageMapBase
@@ -140,10 +148,14 @@ namespace Coverage {
      *  This method prints the contents of the coverage map to stdout.
-    void dump( void ) const;
+    void dump() const;
-     *  Address valid?
+    *  This method checks whether an address is valid.
+    *  @param[in] address specifies the address to check
+    *  @return Returns true if @p address is valid and false if not.
     bool validAddress( const uint32_t address ) const;
@@ -156,6 +168,14 @@ namespace Coverage {
     int32_t getFirstLowAddress() const;
+     *  This method gets the low address of the range at @p index.
+     * @param[in] index the index of the range to get the size of
+     *  @return Returns the low address of the range at @p index in the
+     *  RangeList.
     uint32_t getLowAddressOfRange( size_t index ) const;
@@ -179,6 +199,13 @@ namespace Coverage {
     uint32_t getSize() const;
+     *  This method gets the size of the address range at @p index.
+     *  @return Returns the size of the address range.
     uint32_t getSizeOfRange( size_t index ) const;
@@ -201,14 +228,14 @@ namespace Coverage {
      *  This method returns the high address of the coverage map.
      *  @return Returns the high address of the coverage map.
-    uint32_t getHighAddress( void ) const;
+    uint32_t getHighAddress() const;
      *  This method returns the low address of the coverage map.
      *  @return Returns the low address of the coverage map.
-    uint32_t getLowAddress( void ) const;
+    uint32_t getLowAddress() const;
@@ -217,9 +244,7 @@ namespace Coverage {
      *  @param[in] address specifies the address of the start of an instruction
-    void setIsStartOfInstruction(
-      uint32_t address
+    void setIsStartOfInstruction( uint32_t address );
      *  This method returns a boolean which indicates if this
@@ -368,7 +393,6 @@ namespace Coverage {
     uint32_t getWasNotTaken( uint32_t address ) const;
      *  This method returns a boolean which indicates if the branch
      *  instruction at the specified address is ALWAYS taken.
@@ -429,12 +453,12 @@ namespace Coverage {
      * Range checked access to the info.
-    AddressInfo& getInfo(uint32_t offset);
+    AddressInfo& getInfo( uint32_t offset );
      * Constant range checked access to the info.
-    const AddressInfo& getInfo(uint32_t offset) const;
+    const AddressInfo& getInfo( uint32_t offset ) const;
1.8.3.1
