[PATCH v1 07/10] CoverageReaderQEMU.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Thu Sep 2 19:24:36 UTC 2021
tester/covoar/CoverageReaderQEMU.cc | 22 +++++++++++-----------
1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/tester/covoar/CoverageReaderQEMU.cc b/tester/covoar/CoverageReaderQEMU.cc
index cef09b3..53d8041 100644
--- a/tester/covoar/CoverageReaderQEMU.cc
+++ b/tester/covoar/CoverageReaderQEMU.cc
@@ -68,10 +68,10 @@ namespace Coverage {
// Read ENTRIES number of trace entries.
#define ENTRIES 1024
- while (true) {
- CoverageMapBase *aCoverageMap = NULL;
+ while ( true ) {
+ CoverageMapBase* aCoverageMap = NULL;
struct trace_entry entries[ENTRIES];
- struct trace_entry *entry;
+ struct trace_entry* entry;
// Read and process each line of the coverage file.
traceFile.read( (char *) entries, sizeof( struct trace_entry ) );
@@ -90,31 +90,31 @@ namespace Coverage {
aCoverageMap = executableInformation->getCoverageMap( entry->pc );
// Ensure that coverage map exists.
- if (!aCoverageMap)
+ if ( !aCoverageMap )
continue;
// Set was executed for each TRACE_OP_BLOCK
- if (entry->op & TRACE_OP_BLOCK) {
- for (i=0; i<entry->size; i++) {
+ if ( entry->op & TRACE_OP_BLOCK ) {
+ for ( i = 0; i < entry->size; i++ ) {
aCoverageMap->setWasExecuted( entry->pc + i );
// Determine if additional branch information is available.
- if ( (entry->op & branchInfo) != 0 ) {
+ if ( ( entry->op & branchInfo ) != 0 ) {
uint32_t a = entry->pc + entry->size - 1;
- while (a > entry->pc && !aCoverageMap->isStartOfInstruction(a))
+ while ( a > entry->pc && !aCoverageMap->isStartOfInstruction( a ) )
a--;
- if (a == entry->pc && !aCoverageMap->isStartOfInstruction(a)) {
+ if ( a == entry->pc && !aCoverageMap->isStartOfInstruction( a ) ) {
// Something went wrong parsing the objdump.
std::ostringstream what;
what << "Reached beginning of range in " << file
<< " at " << entry->pc << " with no start of instruction.";
throw rld::error( what, "CoverageReaderQEMU::processFile" );
- if (entry->op & taken) {
+ if ( entry->op & taken ) {
aCoverageMap->setWasTaken( a );
- } else if (entry->op & notTaken) {
+ } else if ( entry->op & notTaken ) {
aCoverageMap->setWasNotTaken( a );
1.8.3.1
