[PATCH 4/7] score: Limit the CLOCK_REALTIME setting
Fri Sep 3 13:33:21 UTC 2021
Limit the CLOCK_REALTIME setting to ensure that the CLOCK_REALTIME is defined
for a system uptime of at least 114 years.
 cpukit/include/rtems/score/todimpl.h |  9 +++++++++
 cpukit/score/src/coretodcheck.c      |  2 +-
 testsuites/psxtests/psxclock/init.c  | 15 +++++++++++++++
 3 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/score/todimpl.h b/cpukit/include/rtems/score/todimpl.h
index ceeef2e21b..f85689fd9c 100644
--- a/cpukit/include/rtems/score/todimpl.h
+++ b/cpukit/include/rtems/score/todimpl.h
@@ -115,6 +115,15 @@ extern "C" {
   (((1987 - 1970 + 1)  * TOD_SECONDS_PER_NON_LEAP_YEAR) + \
   (4 * TOD_SECONDS_PER_DAY))
+ * @brief Seconds from 1970-01-01T00:00:00Z to 2400-01-01T00:00:00Z.
+ * This is the latest time of day which should be set by _TOD_Set().  The year
+ * 2400 was chosen to guarantee a defined CLOCK_REALTIME within the range of a
+ * system uptime of about 114 years.
+#define TOD_SECONDS_1970_THROUGH_2400 13569465600
  *  @brief Earliest year to which an time of day can be initialized.
diff --git a/cpukit/score/src/coretodcheck.c b/cpukit/score/src/coretodcheck.c
index b42435aa43..8c012c5070 100644
--- a/cpukit/score/src/coretodcheck.c
+++ b/cpukit/score/src/coretodcheck.c
@@ -51,7 +51,7 @@ Status_Control _TOD_Is_valid_new_time_of_day( const struct timespec *tod )
     return STATUS_INVALID_NUMBER;
-  if ( _Watchdog_Is_far_future_timespec( tod ) ) {
+  if ( tod->tv_sec > TOD_SECONDS_1970_THROUGH_2400 ) {
diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
index 778637b4fd..3f88f1d401 100644
--- a/testsuites/psxtests/psxclock/init.c
+++ b/testsuites/psxtests/psxclock/init.c
@@ -131,6 +131,21 @@ static rtems_task Init(
   rtems_test_assert( sc == -1 );
   rtems_test_assert( errno == EINVAL );
+  puts( "Init: clock_settime - 2400-01-01T00:00:00Z SUCCESSFUL" );
+  tv.tv_sec = 13569465600;
+  tv.tv_nsec = 0;
+  errno = 0;
+  sc = clock_settime( CLOCK_REALTIME, &tv );
+  rtems_test_assert( sc == 0 );
+  puts( "Init: clock_settime - 2400-01-01T00:00:01Z EINVAL" );
+  tv.tv_sec = 13569465601;
+  tv.tv_nsec = 0;
+  errno = 0;
+  rtems_test_assert( sc == -1 );
+  rtems_test_assert( errno == EINVAL );
   puts( "Init: clock_settime - far future EINVAL" );
   tv.tv_sec = 17179869184;
   tv.tv_nsec = 0;
2.26.2
