[PATCH 7/7] score: Change TOD_LATEST_YEAR to 2099
Sebastian Huber
Fri Sep 3 13:33:24 UTC 2021
This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in
<rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and
_TOD_Days_since_last_leap_year[] static.
Update #4338.
bsps/bfin/shared/dev/rtc.c | 9 ++----
cpukit/include/rtems/score/todimpl.h | 31 ++++++++++++++++--
cpukit/rtems/src/clockgettod.c | 6 ++--
cpukit/rtems/src/clocktodtoseconds.c | 33 +++++--------------
cpukit/rtems/src/clocktodvalidate.c | 18 +++++------
testsuites/sptests/sp2038/init.c | 43 +++----------------------
testsuites/sptests/spclock_err02/init.c | 8 ++---
7 files changed, 58 insertions(+), 90 deletions(-)
diff --git a/bsps/bfin/shared/dev/rtc.c b/bsps/bfin/shared/dev/rtc.c
index cb15ca0607..e3fb48b4bf 100644
--- a/bsps/bfin/shared/dev/rtc.c
+++ b/bsps/bfin/shared/dev/rtc.c
@@ -22,11 +22,6 @@
#include <rtems/rtems/clockimpl.h>
-/* The following are inside RTEMS -- we are violating visibility!!!
- * Perhaps an API could be defined to get days since 1 Jan.
-extern const uint16_t _TOD_Days_to_date[2][13];
* Prototypes and routines used below
@@ -75,7 +70,7 @@ int setRealTime(
tod_temp = *tod;
days = (tod_temp.year - TOD_BASE_YEAR) * 365 + \
- _TOD_Days_to_date[0][tod_temp.month] + tod_temp.day - 1;
+ _TOD_Days_to_date[1][tod_temp.month] + tod_temp.day - 1;
if (tod_temp.month < 3)
days += Leap_years_until_now (tod_temp.year - 1);
else
@@ -115,7 +110,7 @@ void getRealTime(
/* finding month and day */
Leap_year = (((!(tod_temp.year%4)) && (tod_temp.year%100)) ||
- (!(tod_temp.year%400)))?1:0;
+ (!(tod_temp.year%400)))?0:1;
for (n=1; n<=12; n++) {
if (days <= _TOD_Days_to_date[Leap_year][n+1]) {
tod_temp.month = n;
diff --git a/cpukit/include/rtems/score/todimpl.h b/cpukit/include/rtems/score/todimpl.h
index f85689fd9c..acfec00186 100644
--- a/cpukit/include/rtems/score/todimpl.h
+++ b/cpukit/include/rtems/score/todimpl.h
@@ -142,12 +142,16 @@ extern "C" {
* 32 bits can accept as latest point in time 2106-Feb-7 6:28:15
* but to simplify the implementation, is was decided to only
* check that the year is not greater than the year of this constant.
+ * The year 2099 was chosen because all years evenly divisible by 4 from 1988
+ * to 2099 are leap years. In this time frame, years evenly divisible by 100
+ * are no leap years unless they are evenly divisible by 400. Thus the year
+ * 2000 is a leap year.
- * The internal realtime clock can run centuries longer but in
+ * The internal CLOCK_REALTIME can run centuries longer but in
* contrast to the POSIX API, the RTEMS Classic API does not
* support this for efficiency reasons.
-#define TOD_LATEST_YEAR 2105
+#define TOD_LATEST_YEAR 2099
* @addtogroup RTEMSScoreTOD
@@ -175,6 +179,14 @@ typedef struct {
extern TOD_Control _TOD;
+ * @brief This array contains the number of days in all months up to the month
+ * indicated by the index of the second dimension.
+ * The first dimension should be 0 for leap years, and 1 otherwise.
+extern const uint16_t _TOD_Days_to_date[ 2 ][ 13 ];
* @brief Locks the time of day mutex.
@@ -215,6 +227,21 @@ static inline void _TOD_Release( ISR_lock_Context *lock_context )
_Timecounter_Release( lock_context );
+ * @brief Maps the year to the leap year index.
+ * @param year is the year to map.
+ * @retval 0 The year is a leap year.
+ * @retval 1 The year is not a leap year.
+static inline size_t _TOD_Get_leap_year_index( uint32_t year )
+ _Assert( year % 4 != 0 || year % 100 != 0 || year % 400 == 0 );
+ return ( ( year % 4 ) + 3 ) / 4;
* @brief Checks the time point is a valid new time of day for _TOD_Set().
diff --git a/cpukit/rtems/src/clockgettod.c b/cpukit/rtems/src/clockgettod.c
index dea136d477..5058b42375 100644
--- a/cpukit/rtems/src/clockgettod.c
+++ b/cpukit/rtems/src/clockgettod.c
@@ -32,8 +32,6 @@
#define RTEMS_DAYS_PER_YEAR (365UL)
#define RTEMS_YEAR_BASE (1970UL)
static bool _Leap_year(
uint32_t year
@@ -64,9 +62,9 @@ static uint32_t _Year_day_as_month(
uint32_t month = 0;
if ( _Leap_year( year ) )
- days_to_date = _TOD_Days_to_date[1];
- else
days_to_date = _TOD_Days_to_date[0];
+ else
+ days_to_date = _TOD_Days_to_date[1];
days_to_date += 2;
diff --git a/cpukit/rtems/src/clocktodtoseconds.c b/cpukit/rtems/src/clocktodtoseconds.c
index 86e89f86eb..43bf6c59c5 100644
--- a/cpukit/rtems/src/clocktodtoseconds.c
+++ b/cpukit/rtems/src/clocktodtoseconds.c
@@ -23,16 +23,9 @@
-#define TOD_SECONDS_AT_2100_03_01_00_00 4107542400UL
- * The following array contains the number of days in all months
- * up to the month indicated by the index of the second dimension.
- * The first dimension should be 1 for leap years, and 0 otherwise.
-const uint16_t _TOD_Days_to_date[2][13] = {
- { 0, 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334 },
- { 0, 0, 31, 60, 91, 121, 152, 182, 213, 244, 274, 305, 335 }
+const uint16_t _TOD_Days_to_date[ 2 ][ 13 ] = {
+ { 0, 0, 31, 60, 91, 121, 152, 182, 213, 244, 274, 305, 335 },
+ { 0, 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334 }
@@ -48,21 +41,18 @@ Watchdog_Interval _TOD_To_seconds(
const rtems_time_of_day *the_tod
- uint32_t time;
- uint32_t year_mod_4;
+ uint32_t time;
+ size_t leap_year_index;
time = the_tod->day - 1;
- year_mod_4 = the_tod->year & 3;
- if ( year_mod_4 == 0 )
- time += _TOD_Days_to_date[ 1 ][ the_tod->month ];
- else
- time += _TOD_Days_to_date[ 0 ][ the_tod->month ];
+ leap_year_index = _TOD_Get_leap_year_index( the_tod->year );
+ time += _TOD_Days_to_date[ leap_year_index ][ the_tod->month ];
time += ( (the_tod->year - TOD_BASE_YEAR) / 4 ) *
( (TOD_DAYS_PER_YEAR * 4) + 1);
- time += _TOD_Days_since_last_leap_year[ year_mod_4 ];
+ time += _TOD_Days_since_last_leap_year[ the_tod->year % 4 ];
time *= TOD_SECONDS_PER_DAY;
@@ -70,13 +60,6 @@ Watchdog_Interval _TOD_To_seconds(
* TOD_SECONDS_PER_MINUTE;
time += the_tod->second;
- /* The year 2100 is not a leap year */
- if ( time
- >= (TOD_SECONDS_AT_2100_03_01_00_00 - TOD_SECONDS_1970_THROUGH_1988)) {
- time -= TOD_SECONDS_PER_DAY;
time += TOD_SECONDS_1970_THROUGH_1988;
return( time );
diff --git a/cpukit/rtems/src/clocktodvalidate.c b/cpukit/rtems/src/clocktodvalidate.c
index ddf310c3c0..9c94c16931 100644
--- a/cpukit/rtems/src/clocktodvalidate.c
+++ b/cpukit/rtems/src/clocktodvalidate.c
@@ -26,17 +26,18 @@
* The following array contains the number of days in all months.
* The second dimension should range from 1 to 12 for January to
- * February, respectively.
+ * December, respectively.
-const uint32_t _TOD_Days_per_month[ 2 ][ 13 ] = {
- { 0, 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 },
- { 0, 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }
+static const uint32_t _TOD_Days_per_month[ 2 ][ 13 ] = {
+ { 0, 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 },
+ { 0, 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }
rtems_status_code _TOD_Validate( const rtems_time_of_day *the_tod )
uint32_t days_in_month;
if ( the_tod == NULL ) {
@@ -71,11 +72,8 @@ rtems_status_code _TOD_Validate( const rtems_time_of_day *the_tod )
return RTEMS_INVALID_CLOCK;
- if (((the_tod->year % 4) == 0 && (the_tod->year % 100 != 0)) ||
- (the_tod->year % 400 == 0))
- days_in_month = _TOD_Days_per_month[ 1 ][ the_tod->month ];
- else
- days_in_month = _TOD_Days_per_month[ 0 ][ the_tod->month ];
+ days_in_month = _TOD_Days_per_month[ leap_year_index ][ the_tod->month ];
if ( the_tod->day > days_in_month ) {
diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
index 035b9a9b9b..9dc4306a77 100644
--- a/testsuites/sptests/sp2038/init.c
+++ b/testsuites/sptests/sp2038/init.c
@@ -143,13 +143,7 @@ static const uint32_t sample_seconds [] = {
3979434495UL,
4011056895UL,
4042592895UL,
- 4074128895UL,
- 4105664895UL,
- 4137200895UL,
- 4168736895UL,
- 4200272895UL,
- 4231808895UL,
- 4263431295UL
+ 4074128895UL
static const rtems_time_of_day nearly_problem_2038 = {
@@ -179,24 +173,6 @@ static const rtems_time_of_day tod_to_seconds_base = {
.second = 15
-static const rtems_time_of_day nearly_problem_2106 = {
- .year = 2105,
- .month = 12,
- .day = 31,
- .hour = 23,
- .minute = 59,
- .second = 59
-static const rtems_time_of_day problem_2106 = {
- .year = 2106,
- .month = 1,
- .day = 1,
- .hour = 0,
- .minute = 0,
- .second = 0
static const rtems_time_of_day problem_2100 = {
.year = 2100,
.month = 2,
@@ -242,24 +218,15 @@ static void test_tod_to_seconds(void)
static void test_problem_year(void)
rtems_status_code sc = RTEMS_SUCCESSFUL;
- time_t zero = 0;
- time_t one = 1;
- time_t maybe_negative = zero - one;
bool time_t_is_32_bit = sizeof(time_t) == 4;
- bool time_t_is_signed = maybe_negative < zero;
if (time_t_is_32_bit) {
const rtems_time_of_day *nearly_problem = NULL;
const rtems_time_of_day *problem = NULL;
rtems_time_of_day now;
- if (time_t_is_signed) {
- nearly_problem = &nearly_problem_2038;
- problem = &problem_2038;
- } else {
- nearly_problem = &nearly_problem_2106;
- problem = &problem_2106;
+ nearly_problem = &nearly_problem_2038;
+ problem = &problem_2038;
sc = rtems_clock_set(nearly_problem);
ASSERT_SC(sc);
@@ -282,7 +249,7 @@ static void test_leap_year(void)
const rtems_time_of_day *problem2 = &problem_2100_2;
// 2100 is not a leap year, so it should have 28 days
test_status = _TOD_Validate(problem);
- rtems_test_assert(test_status == RTEMS_SUCCESSFUL);
+ rtems_test_assert(test_status == RTEMS_INVALID_CLOCK);
test_status = _TOD_Validate(problem2);
@@ -309,7 +276,7 @@ static void test_every_day(void)
- for (every_day.year = 1988; every_day.year <= 2100; ++every_day.year) {
+ for (every_day.year = 1988; every_day.year <= 2099; ++every_day.year) {
int leap_year = test_year_is_leap_year(every_day.year) ? 1 : 0;
for (every_day.month = 1; every_day.month <= 12; ++every_day.month) {
int days = days_per_month[leap_year][every_day.month - 1];
diff --git a/testsuites/sptests/spclock_err02/init.c b/testsuites/sptests/spclock_err02/init.c
index c879c4ce1f..2200b24ec6 100644
--- a/testsuites/sptests/spclock_err02/init.c
+++ b/testsuites/sptests/spclock_err02/init.c
@@ -89,7 +89,7 @@ rtems_task Init(
directive_failed( status, "rtems_clock_get_tod" );
print_time( "TA1 - rtems_clock_get_tod - ", &time, " - RTEMS_SUCCESSFUL\n" );
- build_time( &time, 12, 31, 2100, 23, 59, 59, 0 );
+ build_time( &time, 12, 31, 2099, 23, 59, 59, 0 );
status = rtems_clock_set( &time );
directive_failed( status, "rtems_clock_set" );
print_time( "TA1 - rtems_clock_set - ", &time, " - RTEMS_SUCCESSFUL\n" );
@@ -98,10 +98,10 @@ rtems_task Init(
- build_time( &time, 12, 31, 2099, 23, 59, 59, 0 );
+ build_time( &time, 1, 1, 2100, 0, 0, 0, 0 );
- directive_failed( status, "rtems_clock_set" );
- print_time( "TA1 - rtems_clock_set - ", &time, " - RTEMS_SUCCESSFUL\n" );
+ fatal_directive_status( status, RTEMS_INVALID_CLOCK, "rtems_clock_set" );
+ print_time( "TA1 - rtems_clock_set - ", &time, " - RTEMS_INVALID_CLOCK\n" );
status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
status = rtems_clock_get_tod( &time );
2.26.2
