[PATCH 6/7] score: Always validate ticks in _TOD_Validate()
Chris Johns
chrisj at rtems.org
Tue Sep 7 03:11:04 UTC 2021
On 6/9/21 6:11 pm, Sebastian Huber wrote:
> On 06/09/2021 09:55, Chris Johns wrote:
>> On 6/9/21 3:49 pm, Sebastian Huber wrote:
>>> On 04/09/2021 06:20, Joel Sherrill wrote:
>>>> > - sc = _TOD_Validate(&temp_tod, TOD_ENABLE_TICKS_VALIDATION);
>>>> > + sc = _TOD_Validate(&temp_tod);
>>>> This has leaked out of the internal implementation interface. Should it?
>>>> I prefer this does not happen and BSPs use an API.
>>>> I noticed this also. It needs an API.
>>> There is no RTEMS API to support writing realtime clock drivers currently.
>> Where did the RTC API connection comes from? I was only thinking of a call in
>> `rtems/clock.h` to validate time. I would not expect an RTC API to result in the
>> validate call being moved from where it is.
> This is not the only _TOD_* stuff used by RTC drivers.
A check shows there are 2 calls used and the bfin bsp can be ignored. Maybe I am
missing something here. Am I?
>>> I am not that sure if this is really a high priority issue.
>> If you mean an RTC API, sure I agree with that. If this is about dipping
>> directly into the score, I do not agree, it is always a priority.
> The _TOD_* stuff is probably used for decades in RTC drivers. Adding RTEMS API
> functions is a bit of work and all core developers are busy. I think it is
> unrealistic that someone will have time to work on this topic.
I think our goals are not aligned. I am only asking the call be protected by an
API signature placed in rtems/clock.h. Is there a problem with doing this?
* @brief Validates the time of day.
* @param tod is the reference to the time of day structure to validate or
* NULL.
* @retval RTEMS_SUCCESSFUL @a tod references a valid time of day.
* @retval RTEMS_INVALID_CLOCK @a tod references an invalid time of day.
* @retval RTEMS_INVALID_ADDRESS @a tod reference is @c NULL.
rtems_status rtems_time_of_day_validate(rtems_time_of_day* tod);
And the implementation is:
return _TOD_Validate(tod);
