[PATCH 6/7] score: Always validate ticks in _TOD_Validate()
Sebastian Huber
Mon Sep 6 08:11:10 UTC 2021
On 06/09/2021 09:55, Chris Johns wrote:
> On 6/9/21 3:49 pm, Sebastian Huber wrote:
>> On 04/09/2021 06:20, Joel Sherrill wrote:
>>> > - sc = _TOD_Validate(&temp_tod, TOD_ENABLE_TICKS_VALIDATION);
>>> > + sc = _TOD_Validate(&temp_tod);
>>> This has leaked out of the internal implementation interface. Should it?
>>> I prefer this does not happen and BSPs use an API.
>>> I noticed this also. It needs an API.
>> There is no RTEMS API to support writing realtime clock drivers currently.
> Where did the RTC API connection comes from? I was only thinking of a call in
> `rtems/clock.h` to validate time. I would not expect an RTC API to result in the
> validate call being moved from where it is.
This is not the only _TOD_* stuff used by RTC drivers.
>> I am not that sure if this is really a high priority issue.
> If you mean an RTC API, sure I agree with that. If this is about dipping
> directly into the score, I do not agree, it is always a priority.
The _TOD_* stuff is probably used for decades in RTC drivers. Adding
RTEMS API functions is a bit of work and all core developers are busy. I
think it is unrealistic that someone will have time to work on this topic.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
