[PATCH v2 1/5] tester/zynqmp: Limit the restarts to 3
chrisj at rtems.org chrisj at rtems.org
Tue Sep 7 04:31:50 UTC 2021
 tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 1 +
 1 file changed, 1 insertion(+)
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
index c4d091f..dff7d86 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
@@ -36,6 +36,7 @@ bsp                = xilinx_zynqmp_lp64_zu3eg
 arch               = aarch64
 tester             = %{_rtscripts}/tftp.cfg
 jobs               = 1
+test_restarts      = 3
 target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
 target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
 requires           = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
2.24.1
