[PATCH v2 2/5] misc/tftprpoxy: Correctly scale the protocol timeout
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 7 04:31:51 UTC 2021
- Fix data decoding
- Fix get MAC call
misc/tools/tftpproxy.py | 13 +++++++------
1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/misc/tools/tftpproxy.py b/misc/tools/tftpproxy.py
index c0aebb0..a388912 100644
--- a/misc/tools/tftpproxy.py
+++ b/misc/tools/tftpproxy.py
@@ -113,10 +113,11 @@ class tftp_session(object):
block = (data[2] << 8) | data[3]
s += ' ' + self.opcodes[opcode] + ', '
s += '#' + str(block) + ', '
- if dlen > 4:
+ if dlen > 8:
s += '%02x%02x..%02x%02x' % (data[4], data[5], data[-2], data[-1])
else:
- s += '%02x%02x%02x%02x' % (data[4], data[5], data[6], data[6])
+ for i in range(4, dlen):
+ s += '%02x' % (data[i])
s += ',' + str(dlen - 4)
elif opcode == 4:
@@ -162,8 +163,8 @@ class tftp_session(object):
return None
def get_timeout(self, default_timeout, timeout_guard):
- if self.timeout == 0:
- return self.timeout + timeout_guard
+ if self.timeout != 0:
+ return self.timeout * timeout_guard
return default_timeout
def get_block_size(self):
@@ -178,7 +179,7 @@ class udp_handler(socketserver.BaseRequestHandler):
session = tftp_session()
finished = session.data(client_ip, client_port, self.request[0])
if not finished:
- timeout = session.get_timeout(self.server.proxy.session_timeout, 1)
+ timeout = session.get_timeout(self.server.proxy.session_timeout, 4)
host = self.server.proxy.get_host(client_ip)
if host is not None:
session_count = self.server.proxy.get_session_count()
@@ -325,7 +326,7 @@ class proxy_server(object):
if client in self.clients:
host = self.clients[client]
else:
- mac = getmac.get_mac_address(ip = client)
+ mac = misc.tools.getmac.get_mac_address(ip = client)
if mac in self.clients:
host = self.clients[mac]
finally:
2.24.1
