[PATCH] tester/zynqmp: Simpify the reasons to reset
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 7 04:38:27 UTC 2021
- Only reset if the bootloader error is hardware related.
tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini | 2 +-
tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
index 5fd2039..8fd2aae 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
@@ -36,6 +36,6 @@ bsp = xilinx_zynqmp_ilp32_zu3eg
arch = aarch64
tester = %{_rtscripts}/tftp.cfg
jobs = 1
-target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
+target_reset_regex = ^No ethernet found.*|^.+complete\.+ TIMEOUT.*|^.*: No link\..*
target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
index dff7d86..663e5de 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
@@ -37,6 +37,6 @@ arch = aarch64
jobs = 1
test_restarts = 3
+target_reset_regex = ^No ethernet found.*|^.*: No link\..*
2.24.1
