[PATCH v2 1/5] tester/zynqmp: Limit the restarts to 3
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Sep 8 13:05:41 UTC 2021
Looks good.
On 9/6/2021 23:31, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 1 +
> 1 file changed, 1 insertion(+)
> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> index c4d091f..dff7d86 100644
> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> @@ -36,6 +36,7 @@ bsp = xilinx_zynqmp_lp64_zu3eg
> arch = aarch64
> tester = %{_rtscripts}/tftp.cfg
> jobs = 1
> +test_restarts = 3
> target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
> target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
> requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
