[PATCH v2 4/5] tester: Count tester header errors
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Sep 8 12:58:57 UTC 2021
Patch looks good except for one comment below.
On 9/6/2021 23:31, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Remove the hard tester error and count the header errors.
> tester/rt/config.py | 2 +-
> tester/rt/report.py | 32 +++++++++++++++++++++++---------
> tester/rt/test.py | 7 +++++--
> 3 files changed, 29 insertions(+), 12 deletions(-)
> diff --git a/tester/rt/config.py b/tester/rt/config.py
> index 2c36e14..a9adfd8 100644
> --- a/tester/rt/config.py
> +++ b/tester/rt/config.py
> @@ -424,7 +424,7 @@ class file(config.file):
> def exe_trace(self, flag):
> dt = self.macros['exe_trace']
> if dt:
> - if flag in dt.split(','):
> + if 'all' in dt or flag in dt.split(','):
This change doesn't seem related to the remainder of the patch.
> return True
> return False
> diff --git a/tester/rt/report.py b/tester/rt/report.py
> index 0e19edc..38ac6f9 100644
> --- a/tester/rt/report.py
> +++ b/tester/rt/report.py
> @@ -68,6 +68,7 @@ class report(object):
> self.wrong_version = 0
> self.wrong_build = 0
> self.wrong_tools = 0
> + self.wrong_header = 0
> self.results = {}
> self.config = {}
> self.name_max_len = 0
> @@ -82,12 +83,14 @@ class report(object):
> msg += 'Timeout: %*d%s' % (self.total_len, self.timeouts, os.linesep)
> msg += 'Test too long: %*d%s' % (self.total_len, self.test_too_long, os.linesep)
> msg += 'Invalid: %*d%s' % (self.total_len, self.invalids, os.linesep)
> - msg += 'Wrong Version %*d%s' % (self.total_len, self.wrong_version, os.linesep)
> - msg += 'Wrong Build %*d%s' % (self.total_len, self.wrong_build, os.linesep)
> - msg += 'Wrong Tools %*d%s' % (self.total_len, self.wrong_tools, os.linesep)
> + msg += 'Wrong Version: %*d%s' % (self.total_len, self.wrong_version, os.linesep)
> + msg += 'Wrong Build: %*d%s' % (self.total_len, self.wrong_build, os.linesep)
> + msg += 'Wrong Tools: %*d%s' % (self.total_len, self.wrong_tools, os.linesep)
> + msg += 'Wrong Header: %*d%s' % (self.total_len, self.wrong_header, os.linesep)
> return msg
> def start(self, index, total, name, executable, bsp_arch, bsp, show_header):
> + wrong = self.wrong_version + self.wrong_build + self.wrong_tools + self.wrong_header
> header = '[%*d/%*d] p:%-*d f:%-*d u:%-*d e:%-*d I:%-*d B:%-*d ' \
> 't:%-*d L:%-*d i:%-*d W:%-*d | %s/%s: %s' % \
> (len(str(total)), index,
> @@ -101,7 +104,7 @@ class report(object):
> len(str(total)), self.timeouts,
> len(str(total)), self.test_too_long,
> len(str(total)), self.invalids,
> - len(str(total)), self.wrong_version + self.wrong_build + self.wrong_tools,
> + len(str(total)), wrong,
> bsp_arch,
> bsp,
> path.basename(name))
> @@ -245,7 +248,8 @@ class report(object):
> status = 'wrong-tools'
> self.wrong_tools += 1
> else:
> - raise error.general('invalid test state: %s: %s' % (name, state))
> + status = 'wrong-header'
> + self.wrong_header += 1
> self.results[name]['result'] = status
> self.results[name]['output'] = prefixed_output
> if self.name_max_len < len(path.basename(name)):
> @@ -256,7 +260,8 @@ class report(object):
> def log(self, name, mode):
> status_fails = ['failed', 'timeout', 'test-too-long', 'invalid',
> - 'wrong-version', 'wrong-build', 'wrong-tools']
> + 'wrong-version', 'wrong-build', 'wrong-tools',
> + 'wrong-header']
> if mode != 'none':
> self.lock.acquire()
> if name not in self.results:
> @@ -266,7 +271,12 @@ class report(object):
> result = self.results[name]['result']
> time = self.results[name]['end'] - self.results[name]['start']
> failed = result in status_fails
> - result = 'Result: %-10s Time: %s %s' % (result, str(time), exe)
> + out = ['Result: %-10s' % (result), 'Time: %s %s' % (str(time), exe)]
> + if result.startswith('wrong-'):
> + what_is_wrong = result.split('-', 1)[1]
> + if what_is_wrong in ['version', 'build', 'tools']:
> + out += ['Wrong %s: tested value: %s' % (what_is_wrong,
> + self.config[what_is_wrong])]
> if mode != 'none':
> header = self.results[name]['header']
> if mode == 'all' or failed:
> @@ -277,7 +287,7 @@ class report(object):
> if header:
> log.output(header)
> if output:
> - log.output(result)
> + log.output(out)
> log.output(output)
> def get_config(self, config, not_found = None):
> @@ -287,7 +297,7 @@ class report(object):
> def score_card(self, mode = 'full'):
> if mode == 'short':
> - wrongs = self.wrong_version + self.wrong_build + self.wrong_tools
> + wrongs = self.wrong_version + self.wrong_build + self.wrong_tools + self.wrong_header
> return 'Passed:%d Failed:%d Timeout:%d Test-Too-long:%d Invalid:%d Wrong:%d' % \
> (self.passed, self.failed, self.timeouts, self.test_too_long,
> self.invalids, wrongs)
> @@ -305,6 +315,7 @@ class report(object):
> l += ['Wrong Version: %*d' % (self.total_len, self.wrong_version)]
> l += ['Wrong Build: %*d' % (self.total_len, self.wrong_build)]
> l += ['Wrong Tools: %*d' % (self.total_len, self.wrong_tools)]
> + l += ['Wrong Header: %*d' % (self.total_len, self.wrong_header)]
> l += ['---------------%s' % ('-' * self.total_len)]
> l += ['Total: %*d' % (self.total_len, self.total)]
> return os.linesep.join(l)
> @@ -352,6 +363,9 @@ class report(object):
> if self.wrong_tools:
> l += ['Wrong Tools:']
> l += show_state(self.results, 'wrong-tools', self.name_max_len)
> + if self.wrong_header:
> + l += ['Wrong Headers:']
> + l += show_state(self.results, 'wrong-header', self.name_max_len)
> def summary(self):
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 66f1756..113936c 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -240,6 +240,7 @@ def generate_json_report(args, reports, start_time, end_time,
> json_log['summary']['wrong-version_count'] = reports.wrong_version
> json_log['summary']['wrong-build_count'] = reports.wrong_build
> json_log['summary']['wrong-tools_count'] = reports.wrong_tools
> + json_log['summary']['invalid-header_count'] = reports.wrong_header
> json_log['summary']['total_count'] = reports.total
> time_delta = end_time - start_time
> json_log['summary']['average_test_time'] = str(time_delta / total)
> @@ -248,7 +249,7 @@ def generate_json_report(args, reports, start_time, end_time,
> result_types = [
> 'failed', 'user-input', 'expected-fail', 'indeterminate',
> 'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
> - 'wrong-build', 'wrong-tools'
> + 'wrong-build', 'wrong-tools', 'wrong-header'
> json_results = {}
> for result_type in result_types:
> @@ -313,6 +314,7 @@ def generate_junit_report(args, reports, start_time, end_time,
> junit_prop['wrong-version_count'] = reports.wrong_version
> junit_prop['wrong-build_count'] = reports.wrong_build
> junit_prop['wrong-tools_count'] = reports.wrong_tools
> + junit_prop['wrong-header_count'] = reports.wrong_header
> junit_prop['total_count'] = reports.total
> junit_prop['average_test_time'] = str(time_delta / total)
> @@ -367,6 +369,7 @@ def generate_yaml_report(args, reports, start_time, end_time,
> yaml_log['summary']['wrong-version-count'] = reports.wrong_version
> yaml_log['summary']['wrong-build-count'] = reports.wrong_build
> yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
> + yaml_log['summary']['wrong-header-count'] = reports.wrong_header
> yaml_log['summary']['total-count'] = reports.total
> yaml_log['summary']['average-test-time'] = str(time_delta / total)
> @@ -375,7 +378,7 @@ def generate_yaml_report(args, reports, start_time, end_time,
> result_types = [
> yaml_log['summary'][result_type] = []
