[PATCH v2 4/5] tester: Count tester header errors
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 7 04:31:53 UTC 2021
- Remove the hard tester error and count the header errors.
tester/rt/config.py | 2 +-
tester/rt/report.py | 32 +++++++++++++++++++++++---------
tester/rt/test.py | 7 +++++--
3 files changed, 29 insertions(+), 12 deletions(-)
diff --git a/tester/rt/config.py b/tester/rt/config.py
index 2c36e14..a9adfd8 100644
--- a/tester/rt/config.py
+++ b/tester/rt/config.py
@@ -424,7 +424,7 @@ class file(config.file):
def exe_trace(self, flag):
dt = self.macros['exe_trace']
if dt:
- if flag in dt.split(','):
+ if 'all' in dt or flag in dt.split(','):
return True
return False
diff --git a/tester/rt/report.py b/tester/rt/report.py
index 0e19edc..38ac6f9 100644
--- a/tester/rt/report.py
+++ b/tester/rt/report.py
@@ -68,6 +68,7 @@ class report(object):
self.wrong_version = 0
self.wrong_build = 0
self.wrong_tools = 0
+ self.wrong_header = 0
self.results = {}
self.config = {}
self.name_max_len = 0
@@ -82,12 +83,14 @@ class report(object):
msg += 'Timeout: %*d%s' % (self.total_len, self.timeouts, os.linesep)
msg += 'Test too long: %*d%s' % (self.total_len, self.test_too_long, os.linesep)
msg += 'Invalid: %*d%s' % (self.total_len, self.invalids, os.linesep)
- msg += 'Wrong Version %*d%s' % (self.total_len, self.wrong_version, os.linesep)
- msg += 'Wrong Build %*d%s' % (self.total_len, self.wrong_build, os.linesep)
- msg += 'Wrong Tools %*d%s' % (self.total_len, self.wrong_tools, os.linesep)
+ msg += 'Wrong Version: %*d%s' % (self.total_len, self.wrong_version, os.linesep)
+ msg += 'Wrong Build: %*d%s' % (self.total_len, self.wrong_build, os.linesep)
+ msg += 'Wrong Tools: %*d%s' % (self.total_len, self.wrong_tools, os.linesep)
+ msg += 'Wrong Header: %*d%s' % (self.total_len, self.wrong_header, os.linesep)
return msg
def start(self, index, total, name, executable, bsp_arch, bsp, show_header):
+ wrong = self.wrong_version + self.wrong_build + self.wrong_tools + self.wrong_header
header = '[%*d/%*d] p:%-*d f:%-*d u:%-*d e:%-*d I:%-*d B:%-*d ' \
't:%-*d L:%-*d i:%-*d W:%-*d | %s/%s: %s' % \
(len(str(total)), index,
@@ -101,7 +104,7 @@ class report(object):
len(str(total)), self.timeouts,
len(str(total)), self.test_too_long,
len(str(total)), self.invalids,
- len(str(total)), self.wrong_version + self.wrong_build + self.wrong_tools,
+ len(str(total)), wrong,
bsp_arch,
bsp,
path.basename(name))
@@ -245,7 +248,8 @@ class report(object):
status = 'wrong-tools'
self.wrong_tools += 1
else:
- raise error.general('invalid test state: %s: %s' % (name, state))
+ status = 'wrong-header'
+ self.wrong_header += 1
self.results[name]['result'] = status
self.results[name]['output'] = prefixed_output
if self.name_max_len < len(path.basename(name)):
@@ -256,7 +260,8 @@ class report(object):
def log(self, name, mode):
status_fails = ['failed', 'timeout', 'test-too-long', 'invalid',
- 'wrong-version', 'wrong-build', 'wrong-tools']
+ 'wrong-version', 'wrong-build', 'wrong-tools',
+ 'wrong-header']
if mode != 'none':
self.lock.acquire()
if name not in self.results:
@@ -266,7 +271,12 @@ class report(object):
result = self.results[name]['result']
time = self.results[name]['end'] - self.results[name]['start']
failed = result in status_fails
- result = 'Result: %-10s Time: %s %s' % (result, str(time), exe)
+ out = ['Result: %-10s' % (result), 'Time: %s %s' % (str(time), exe)]
+ if result.startswith('wrong-'):
+ what_is_wrong = result.split('-', 1)[1]
+ if what_is_wrong in ['version', 'build', 'tools']:
+ out += ['Wrong %s: tested value: %s' % (what_is_wrong,
+ self.config[what_is_wrong])]
if mode != 'none':
header = self.results[name]['header']
if mode == 'all' or failed:
@@ -277,7 +287,7 @@ class report(object):
if header:
log.output(header)
if output:
- log.output(result)
+ log.output(out)
log.output(output)
def get_config(self, config, not_found = None):
@@ -287,7 +297,7 @@ class report(object):
def score_card(self, mode = 'full'):
if mode == 'short':
- wrongs = self.wrong_version + self.wrong_build + self.wrong_tools
+ wrongs = self.wrong_version + self.wrong_build + self.wrong_tools + self.wrong_header
return 'Passed:%d Failed:%d Timeout:%d Test-Too-long:%d Invalid:%d Wrong:%d' % \
(self.passed, self.failed, self.timeouts, self.test_too_long,
self.invalids, wrongs)
@@ -305,6 +315,7 @@ class report(object):
l += ['Wrong Version: %*d' % (self.total_len, self.wrong_version)]
l += ['Wrong Build: %*d' % (self.total_len, self.wrong_build)]
l += ['Wrong Tools: %*d' % (self.total_len, self.wrong_tools)]
+ l += ['Wrong Header: %*d' % (self.total_len, self.wrong_header)]
l += ['---------------%s' % ('-' * self.total_len)]
l += ['Total: %*d' % (self.total_len, self.total)]
return os.linesep.join(l)
@@ -352,6 +363,9 @@ class report(object):
if self.wrong_tools:
l += ['Wrong Tools:']
l += show_state(self.results, 'wrong-tools', self.name_max_len)
+ if self.wrong_header:
+ l += ['Wrong Headers:']
+ l += show_state(self.results, 'wrong-header', self.name_max_len)
def summary(self):
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 66f1756..113936c 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -240,6 +240,7 @@ def generate_json_report(args, reports, start_time, end_time,
json_log['summary']['wrong-version_count'] = reports.wrong_version
json_log['summary']['wrong-build_count'] = reports.wrong_build
json_log['summary']['wrong-tools_count'] = reports.wrong_tools
+ json_log['summary']['invalid-header_count'] = reports.wrong_header
json_log['summary']['total_count'] = reports.total
time_delta = end_time - start_time
json_log['summary']['average_test_time'] = str(time_delta / total)
@@ -248,7 +249,7 @@ def generate_json_report(args, reports, start_time, end_time,
result_types = [
'failed', 'user-input', 'expected-fail', 'indeterminate',
'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
- 'wrong-build', 'wrong-tools'
+ 'wrong-build', 'wrong-tools', 'wrong-header'
json_results = {}
for result_type in result_types:
@@ -313,6 +314,7 @@ def generate_junit_report(args, reports, start_time, end_time,
junit_prop['wrong-version_count'] = reports.wrong_version
junit_prop['wrong-build_count'] = reports.wrong_build
junit_prop['wrong-tools_count'] = reports.wrong_tools
+ junit_prop['wrong-header_count'] = reports.wrong_header
junit_prop['total_count'] = reports.total
junit_prop['average_test_time'] = str(time_delta / total)
@@ -367,6 +369,7 @@ def generate_yaml_report(args, reports, start_time, end_time,
yaml_log['summary']['wrong-version-count'] = reports.wrong_version
yaml_log['summary']['wrong-build-count'] = reports.wrong_build
yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
+ yaml_log['summary']['wrong-header-count'] = reports.wrong_header
yaml_log['summary']['total-count'] = reports.total
yaml_log['summary']['average-test-time'] = str(time_delta / total)
@@ -375,7 +378,7 @@ def generate_yaml_report(args, reports, start_time, end_time,
result_types = [
yaml_log['summary'][result_type] = []
2.24.1
